This problem is observed only on Disney+ and Netflix web-dl and only when playing over the network (NAS or DLNA PC), if run via usb, everything will work. If RESET_9999 knows the treatment method, it will be great, but as far as I know, when building mp4box, it will not be possible to make a working version, you need to build using ffmpegMithrandir wrote: ↑Fri May 05, 2023 7:47 pm
After converting I'm getting random audio dropouts during playback on LG CX (internal player).
I'm using latest scripts (1.8.3).
Did you had similar issues?
TheEqualizer
yeah , reason number 1222131545 why I don't use the mp4 container. I have never had any issues since I'm using the TS container with external SRT.
Mithrandir
I tried remuxing using ffmpeg - then I get weird blocking artifacts on 10-15 places in file, but only if subs are included.TheEqualizer wrote: ↑Fri May 05, 2023 8:29 pmThis problem is observed only on Disney+ and Netflix web-dl and only when playing over the network (NAS or DLNA PC), if run via usb, everything will work. If RESET_9999 knows the treatment method, it will be great, but as far as I know, when building mp4box, it will not be possible to make a working version, you need to build using ffmpeg
If i remux without subs, everything works fine.
I tried via Jellyfin and DLNA (Jellyfin DLNA). I'll try the USB also.
Thanks, I will try with .ts and report the results.RESET_9999 wrote: ↑Fri May 05, 2023 8:32 pmyeah , reason number 1222131545 why I don't use the mp4 container. I have never had any issues since I'm using the TS container with external SRT.
Mithrandir
@RESET_9999
I've tried TS workflow on LG CX
1. DLNA - native webOS player - works perfectly, 0 audio/video glitches. FF/REW is a bit slower than MP4, but that doesn't bother me
2. Jellyfin WebOS app - works perfectly. You can choose subs, but because they are PGS, they will cause an error.
I have 2 questions:
1. I have set on line 39 to export subs, but no subs were exported
2. Is there an option to mux no subs into TS stream. I've seen an option, but it only muxes all subs or just forced subs
Thanks for your great work and help RESET_9999
I have 2 questions:
1- yea that option is just for the forced subs which is only what I need but I could add an option to export also the full subs.
2- No
2- No
Mithrandir
I get it. I thought it will export all subs which are muxed into TS stream.RESET_9999 wrote: ↑Sat May 06, 2023 12:03 am1- yea that option is just for the forced subs which is only what I need but I could add an option to export also the full subs.
Thank you for your help but i need more when i go through all steps which you dicribe it shows me that it could not find a way what is wrong with it ? i m using MKV7 PROFILE DOLBY VISION files and it shows when i use mkv 7 dolby vision that file must be in 7 profile dolby vision but it is 7 profileRESET_9999 wrote: ↑Thu May 04, 2023 5:24 pmDownload this and export to a folder preferably without space or special characters.(don't move any files): https://drive.google.com/file/d/1g-nQY5 ... share_link
download this beta version of the script and put it in your DoVi_Scripts folder (this contains the latest version of the DT-DL mp4 workflow: https://drive.google.com/file/d/1SYnK9M ... share_link
Then if your input is a makemkv Profile 7 rip (7-3-1):
if your input is a bluray disc (7-3-2):
The command line is a single long line and the only spacing character allowed is the space.
You can help yourself with THIS online tool for removing line breaks.
Are you sure about that?
the script uses mediainfo to read the profile information so maybe your file doesn't have p7 DV or it's not muxed properly.
Yes i m sure it is 7 profile mkv 7 profile dolby vision remux from RARBG FGT tracker maybe you will show how to do it properly all the stepsRESET_9999 wrote: ↑Sun May 07, 2023 12:11 pmAre you sure about that?
Hello RESET_9999, tell me please, I made an mkv file with Dolby Vision. How do I get DV in HEVC file like it is made in UHD Blu-ray discs? Thanks in advance for your reply.
mediainfo of your file?
get the TS version of my script and disable the muxing at line 22 (set MUX=NO)
then use workflow (4-3) and when it's completed, select bluray folder (or iso) in tsmuxer and mux.
RESET_9999 wrote: ↑Sun May 07, 2023 2:24 pmmediainfo of your file?
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 35 min
Bit rate : 76.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.383
Stream size : 51.0 GiB (86%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium : Blu-ray
What does it mean disable the muxing at line 22 ?RESET_9999 wrote: ↑Sun May 07, 2023 2:26 pmget the TS version of my script and disable the muxing at line 22 (set MUX=NO)
