Mithrandir
#8251 Post by Mithrandir » Thu May 04, 2023 8:30 pm
afarvvik wrote:
Wed May 03, 2023 8:00 pm
thanks for the reply. can you please let me know what version of jellyfin you did this in? is FF/REW working for you with m2ts files in jellyfin? I had to move to Emby because FF/REW was not working for me with m2ts files in jellyfin and I can not use plex because it transcodes when SRT is enabled.
Latest Jellyfin Version: 10.8.10.
I didn't see you are using m2ts files.
I'm using MKV and MP4 files and FF/REW works completely fine.
I used ts few times but can't remember if FF/REW worked.
I never used m2ts.
Isn't m2ts designed to work only in disc players?
TheEqualizer
#8252 Post by TheEqualizer » Thu May 04, 2023 9:33 pm
RESET_9999 wrote:
Thu May 04, 2023 5:25 pm
P8 with EL is not standard and there's no need to use it since your TV support dual track dual layer Profile 7 FEL. See my reply to @valington
Yes, I know that my TV 2019 supports 7 FEL, but not since 2020, and I need a universal option for tv 2019 and newer, up to this point I have used P8 BL+RPU, but I saw this non-standard option and it confused me. I am also aware that dvi.08.06 BL+EL+RU is not a DV standard, but still the question was, why does TV reproduce this option correctly, does it ignore el or somehow reproduces it as in cases with a two-layer 7 profile? And how did manage to get such an option dvh.08.06 BL+EL+RU?
#8253 Post by RESET_9999 » Thu May 04, 2023 10:10 pm
Surprised that HEV1 works on the B9 since it doesn't work on the C8.
The only universal solution that works EVERYWHERE is the TS/M2TS container in P8.
I don't know but you can try to use this P7 file and remux it to P8 without removing the EL and see if FEL is used:
https://drive.google.com/file/d/1J5QnjW ... share_link
you can force P8 with the mp4muxer:
"%mp4muxer_path%" --dv-profile 8 --input-file ST-DL.hevc --output-file "output.mp4"
TheEqualizer
#8254 Post by TheEqualizer » Thu May 04, 2023 10:17 pm
I tested your video, extracted hevc from the TS container and got mp4, although the command that you gave lacks the -compatible-id parameter, it gave an error without it, I made all three options with -compatible-id 1 (2) (4) for full confidence. All three videos are strobed by the built-in player LG B9. I don't know why this doesn't happen on a particular movie...
Which specific version of tsMuxer do you recommend using?
begentle
#8255 Post by begentle » Thu May 04, 2023 11:25 pm
RESET_9999 wrote:
Mon Apr 10, 2023 9:44 pm
spl147 wrote:
Mon Apr 10, 2023 9:23 pm
So much info in the thread, so what i gather is by converting a DV mkv with FEL to profile 8.1 we loose FEL?
So it’s the same a playing a DV MKV on a zidoo or dune? FEL is discarded and only the rpu is used?
yes FEL is discarded but know that not every FEL movie can be converted to P8 (or played on non-fel devices) because some of them are expanding the picture brightness when BL and FEL are decoded by the player.
So the DV metadata in the RPU is meant to be played with the FEL brightness ONLY. Playing these FEL movies on a non-fel device will result in an image darker than the intended look.
Here's a list of FEL movies that expand brightness (still looking into my library to find more):
https://docs.google.com/spreadsheets/d/ ... sp=sharing
This is really interesting - and I'm extremely grateful for all the info you've gathered here.
What's the best way for me to check my own collection to see which FEL discs expand the picture brightness? What data should I be looking for?
#8256 Post by RESET_9999 » Fri May 05, 2023 12:01 am
Because I use the old mp4muxer that works on all the LG TVs and this parameter was implemented in the later versions of the mp4muxer.
the homemade FEL test file can indeed be buggy on some players.
The latest one should be fine.
https://github.com/justdan96/tsMuxer/releases
The only downside of using TS on LG TVs is that you have to use external SRT subs. Some comments here recently said that ext srt doesn't work but on my end (PLEX C2), it still works.
#8257 Post by RESET_9999 » Fri May 05, 2023 1:12 am
Usually, the HDR10 base layer mastering display lum metadata will say 1000nits, and the RPU metadata will say 4000nits but the two only ways to really know is by plotting DV/HDR10 or by exporting some screenshots with the dovi baker.
E.G. Deep Impact:
https://slow.pics/c/nU0W23sh
https://slow.pics/c/SwbE119u
You can do all of this with the script in my signature.
TheEqualizer
#8258 Post by TheEqualizer » Fri May 05, 2023 6:57 am
I redid it using the same old version that is in your tools folder, the result was the same, a strobe light, this suggests that the TV cannot correctly reproduce dvhe.08.06, BL+EL+RPU? If could, would I see a normal color scheme?
Mithrandir
#8259 Post by Mithrandir » Fri May 05, 2023 7:59 am
I think it works with Plex/Jellyfin, but it doesn't work with built-in WebOS player (if you trigger the file via DLNA).
Also, internal webOS doesn't support PGS subtitles (which are usually present in Bluray remuxes).
Is there an option in your script to convert PGS to SRT?
begentle
#8260 Post by begentle » Fri May 05, 2023 10:10 am
E.G. Deep Impact:
That's really helpful - thanks!
I guess the next step for me is to learn how to get DoviBaker to combine the BL and FEL (any tips would be welcome!) so I can do some test re-encodes...
#8261 Post by RESET_9999 » Fri May 05, 2023 11:00 am
The flashes are the mapping in the RPU. When fel is used, you're supposed to see a 2nd video in the background like this:
#8262 Post by RESET_9999 » Fri May 05, 2023 11:04 am
No, because it requires manual verification to be accurate. I use subtitle edit.
https://github.com/SubtitleEdit/subtitleedit/releases
or most of the time , someone already converted them to srt: https://subscene.com
TheEqualizer
#8263 Post by TheEqualizer » Fri May 05, 2023 12:28 pm
I checked again, dvhe.08.06, BL+EL+RPU is not supported from mp4, only TS dvhe.07.06, BL+EL+RPU it is supported, I see both images.
In general, as I understand it, what was tricked out in that mkv (dvhe.08.06, BL+EL+RPU) is not correct and it is not necessary to do so?
And the last question, did you have the opportunity to check TS (dvhe.07.06, BL+EL+RPU) on LG OLED TV 2016-2017-2018-2019-2020-2021-2022-2023 or else on some other, since you wrote that this is the only universal option.
#8264 Post by RESET_9999 » Fri May 05, 2023 1:01 pm
Well, it could be right as long as FEL doesn't expand the brightness. Looks like the dynamic metadata is used.
But better just convert P7 to true P8(no el and remove mapping) for playback on non-fel devices but once again, as long as FEL doesn't expand the brightness
2017-2019...
P7 ST-DL: TS or MP4, some files give black screen.
P7 DT-DL: Ts doesn't work but mp4 works. (some fel file may stutter)
P8/P5: TS and MP4 are fine
2020+ ...
P7 ST-DL: HDR10
P7 DT-DL: HDR10
Mithrandir
#8265 Post by Mithrandir » Fri May 05, 2023 7:47 pm
@RESET_9999 I've used MP4 workflow with DV P5 mkv (workflow 7 if i recall correctly).
After converting I'm getting random audio dropouts during playback on LG CX (internal player).
I'm using latest scripts (1.8.3).
Did you had similar issues?
I've used your scripts in the past (maybe a year ago) and didn't encounter similar issues.
MediaInfo of original file (shortened cause it has 25 subtitles).
General
Unique ID                                : 123878627500660741924601339876164737565 (0x5D3227E3A4B0E46A0170FAEAF2239A1D)
Complete name                            : The Mandalorian - S03E03 - Chapter 19 - The Convert WEBDL-2160p.mkv
File size                                : 6.69 GiB
Duration                                 : 56 min 11 s
Overall bit rate                         : 17.1 Mb/s
Frame rate                               : 24.000 FPS
Writing application                      : mkvmerge v74.0.0 ('You Oughta Know') 64-bit
Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
Video
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Bit rate                                 : 16.3 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.082
Stream size                              : 6.39 GiB (95%)
Color range                              : Full
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Bit rate                                 : 768 kb/s
Stream size                              : 309 MiB (5%)
Complexity index                         : 16
Number of dynamic objects                : 15
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 52 min 42 s
Bit rate                                 : 45 b/s
Frame rate                               : 0.175 FPS
Count of elements                        : 552
Stream size                              : 17.7 KiB (0%)
Text #2
Format                                   : UTF-8
Bit rate                                 : 53 b/s
Frame rate                               : 0.210 FPS
Count of elements                        : 664
Stream size                              : 20.5 KiB (0%)
Title                                    : SDH
Menu
00:00:04.000                             : en:Recap
00:01:02.083                             : en:Scene 1
00:01:02.125                             : en:Intro
00:01:26.417                             : en:Scene 2
00:19:07.583                             : en:Scene 3
00:30:18.917                             : en:Scene 4
00:38:05.333                             : en:Scene 5
00:53:14.458                             : en:Credits
Mediainfo of converted file:
General
Complete name                            : The Mandalorian - S03E03 - Chapter 19 - The Convert WEBDL-2160p_DoVi.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (iso4/mp42/dby1)
Encoded date                             : 2023-05-04 22:31:56 UTC
Tagged date                              : 2023-05-04 22:31:56 UTC
Writing application                      : GPAC-2.1-DEV-rev321-gc68d8a53-master
Video
Codec ID                                 : dvh1
Maximum bit rate                         : 40.3 Mb/s
Tagged date                              : 2023-05-04 22:32:15 UTC
Color range                              : Full
mdhd_Duration                            : 3371333
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Title                                    : DDP
Encoded date                             : 2023-05-04 22:32:11 UTC
Text #1
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 52 min 43 s
Bit rate                                 : 50 b/s
Frame rate                               : 0.283 FPS
Stream size                              : 19.5 KiB (0%)
Title                                    : SRT
Encoded date                             : 2023-05-04 22:32:13 UTC
Count of events                          : 552
Text #2
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 59 b/s
Frame rate                               : 0.344 FPS
Stream size                              : 22.7 KiB (0%)
Title                                    : SRT
Count of events                          : 664
