Blu-Ray BDMV FOlder
Radiocomms237
Re: Blu-Ray BDMV FOlder
Post by Radiocomms237 »
Billycar11 wrote: Fri May 05, 2023 7:06 am you dont even need to fake it being a disc just open the index under bdmv with makemkv's file open selection
Yes, but if you "open" the disc like that, the "backup" icon gets greyed-out and you can't make a backup from the backup, which I believe is what the OP was trying to do (for some reason).
If you trick MakeMKV into thinking it's an optical drive by creating a virtual disc, then you can make a backup from a disc image that was already copied.
