Trouble ripping Dune (2021)
butthefrench
#1 Post by butthefrench » Fri May 05, 2023 2:08 am
I am attempting to rip Dune (2021 reboot) Blu-ray using an ASUS BW-16D1X-U. It has ripped many Blu-ray discs without issue before. I'm noticing that CSS/CPPM protection is denoted in the "pre-rip" window. Here is a screenshot of the before and after a rip attempt.
Before:
After:
I have cleaned the disc, increased my number of read retries to 9, and attempted several iterations of source content ripping. All attempts end about 40% into the rip with an error message "0 titles saved, 1 failed".
The main errors are:
  • Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '3354787840'
  • Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '3354787840'
I'm curious if there's any additional troubleshooting I can perform? Has anyone successfully ripped the Blu-ray of this disc? Thank you for your time and assistance.
makemkv_error-log.txt
(3.35 KiB) Downloaded 313 times
Re: Trouble ripping Dune (2021)
#2 Post by Woodstock » Fri May 05, 2023 3:25 am
Is the drive powered by USB? If so, make sure it is plugged into a FULLY POWERED USB (if it's USB 3) or a pair of FULLY POWERED USB (for USB 2).
When drives start spinning at "top speed" (usually far out in the read), they can exceed the power fed by a single USB 2.x port.
#3 Post by dcoke22 » Fri May 05, 2023 5:19 am
It looks to be an ASUS BW-16D1X-U which appears to come with its own 12v 3A power brick.
What happens if you try to make a decrypted backup of the DVD? And then create your .mkv file from the backup?
butthefrench
#4 Post by butthefrench » Fri May 05, 2023 11:52 am
dcoke22 wrote: Fri May 05, 2023 5:19 am It looks to be an ASUS BW-16D1X-U which appears to come with its own 12v 3A power brick.
This is correct, it's an externally powered optical drive. It is a blu-ray disc, not a DVD. I am unfamiliar with making decrypted backups of a disc; this is done in MakeMKV or something else? I would be willing to try this, just need to know what to use.
#5 Post by dcoke22 » Fri May 05, 2023 1:05 pm
butthefrench wrote: Fri May 05, 2023 11:52 am This is correct, it's an externally powered optical drive. It is a blu-ray disc, not a DVD. I am unfamiliar with making decrypted backups of a disc; this is done in MakeMKV or something else? I would be willing to try this, just need to know what to use.
Your screenshot shows the disc type is DVD-ROM, not a blu-ray disc, hence my assumption.
In any case, making a backup is a thing you can do with MakeMKV. After you insert a disc into your drive, click the 2nd from the left icon at the top. It is the one that is a yellow folder with a green arrow. On the window that appears, make sure the decrypted box is checked.
For DVDs MakeMKV will create an .iso file and for blu-rays, it creates a folder (generally called a BDMV folder). Either way, it should be a complete copy of the contents of the disc, sans encryption. MakeMKV can open these backups and make .mkv files from them just like it does from the actual discs.
butthefrench
#6 Post by butthefrench » Fri May 05, 2023 1:23 pm
dcoke22 wrote: Fri May 05, 2023 1:05 pm
Thank you for the clarification. I have attempted to perform a backup of the blu-ray (not sure why it shows DVD-ROM). The result is here:
https://1drv.ms/i/s!AstrmUGJQYWTgx1qGWS ... G?e=dZybO1
I still receive the error "Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE ASUS BW-16D1X-U A104 KLEKCRF3753' at offset '3585015808'"
Any ideas?
butthefrench
#7 Post by butthefrench » Fri May 05, 2023 2:47 pm
Thank you very much for the assistance. I was able to figure this all out. The disc I received was from a blu-ray case, but not labeled. Upon further inspection, the disc was indeed a DVD, and not a blu-ray as marked. When I returned the disc and mentioned my trouble, the correct disc was provided to me. I tried the rip again, and it worked. Thanks dcoke22 for pointing out that little clue to help me figure it all out.
