TheEqualizer
Post by TheEqualizer »
I tested your video, extracted hevc from the TS container and got mp4, although the command that you gave lacks the -compatible-id parameter, it gave an error without it, I made all three options with -compatible-id 1 (2) (4) for full confidence. All three videos are strobed by the built-in player LG B9. I don't know why this doesn't happen on a particular movie...
RESET_9999 wrote: Thu May 04, 2023 10:10 pm The only universal solution that works EVERYWHERE is the TS/M2TS container in P8.
Which specific version of tsMuxer do you recommend using?
begentle
Post by begentle »
RESET_9999 wrote: Mon Apr 10, 2023 9:44 pm
spl147 wrote: Mon Apr 10, 2023 9:23 pm So much info in the thread, so what i gather is by converting a DV mkv with FEL to profile 8.1 we loose FEL?
So it’s the same a playing a DV MKV on a zidoo or dune? FEL is discarded and only the rpu is used?
yes FEL is discarded but know that not every FEL movie can be converted to P8 (or played on non-fel devices) because some of them are expanding the picture brightness when BL and FEL are decoded by the player.
So the DV metadata in the RPU is meant to be played with the FEL brightness ONLY. Playing these FEL movies on a non-fel device will result in an image darker than the intended look.
Here's a list of FEL movies that expand brightness (still looking into my library to find more):
https://docs.google.com/spreadsheets/d/ ... sp=sharing
This is really interesting - and I'm extremely grateful for all the info you've gathered here.
What's the best way for me to check my own collection to see which FEL discs expand the picture brightness? What data should I be looking for?
TheEqualizer wrote: Thu May 04, 2023 10:17 pm although the command that you gave lacks the -compatible-id parameter, it gave an error without it,
Because I use the old mp4muxer that works on all the LG TVs and this parameter was implemented in the later versions of the mp4muxer.
the homemade FEL test file can indeed be buggy on some players.
The latest one should be fine.
https://github.com/justdan96/tsMuxer/releases
The only downside of using TS on LG TVs is that you have to use external SRT subs. Some comments here recently said that ext srt doesn't work but on my end (PLEX C2), it still works.
begentle wrote: Thu May 04, 2023 11:25 pm What's the best way for me to check my own collection to see which FEL discs expand the picture brightness? What data should I be looking for?
Usually, the HDR10 base layer mastering display lum metadata will say 1000nits, and the RPU metadata will say 4000nits but the two only ways to really know is by plotting DV/HDR10 or by exporting some screenshots with the dovi baker.
E.G. Deep Impact:
https://slow.pics/c/nU0W23sh
https://slow.pics/c/SwbE119u
You can do all of this with the script in my signature.
TheEqualizer
RESET_9999 wrote: Fri May 05, 2023 12:01 am Because I use the old mp4muxer that works on all the LG TVs and this parameter was implemented in the later versions of the mp4muxer.
I redid it using the same old version that is in your tools folder, the result was the same, a strobe light, this suggests that the TV cannot correctly reproduce dvhe.08.06, BL+EL+RPU? If could, would I see a normal color scheme?
Mithrandir
Post by Mithrandir »
RESET_9999 wrote: Fri May 05, 2023 12:01 am The only downside of using TS on LG TVs is that you have to use external SRT subs. Some comments here recently said that ext srt doesn't work but on my end (PLEX C2), it still works.
I think it works with Plex/Jellyfin, but it doesn't work with built-in WebOS player (if you trigger the file via DLNA).
Also, internal webOS doesn't support PGS subtitles (which are usually present in Bluray remuxes).
Is there an option in your script to convert PGS to SRT?
begentle
Post by begentle »
RESET_9999 wrote: Fri May 05, 2023 1:12 am
E.G. Deep Impact:
That's really helpful - thanks!
I guess the next step for me is to learn how to get DoviBaker to combine the BL and FEL (any tips would be welcome!) so I can do some test re-encodes...
TheEqualizer wrote: Fri May 05, 2023 6:57 am I redid it using the same old version that is in your tools folder, the result was the same, a strobe light, this suggests that the TV cannot correctly reproduce dvhe.08.06, BL+EL+RPU? If could, would I see a normal color scheme?
The flashes are the mapping in the RPU. When fel is used, you're supposed to see a 2nd video in the background like this:
Mithrandir wrote: Fri May 05, 2023 7:59 am Is there an option in your script to convert PGS to SRT?
No, because it requires manual verification to be accurate. I use subtitle edit.
https://github.com/SubtitleEdit/subtitleedit/releases
or most of the time , someone already converted them to srt: https://subscene.com
TheEqualizer
RESET_9999 wrote: Fri May 05, 2023 11:00 am The flashes are the mapping in the RPU. When fel is used, you're supposed to see a 2nd video in the background like this:
I checked again, dvhe.08.06, BL+EL+RPU is not supported from mp4, only TS dvhe.07.06, BL+EL+RPU it is supported, I see both images.
In general, as I understand it, what was tricked out in that mkv (dvhe.08.06, BL+EL+RPU) is not correct and it is not necessary to do so?
And the last question, did you have the opportunity to check TS (dvhe.07.06, BL+EL+RPU) on LG OLED TV 2016-2017-2018-2019-2020-2021-2022-2023 or else on some other, since you wrote that this is the only universal option.
TheEqualizer wrote: Fri May 05, 2023 12:28 pm In general, as I understand it, what was tricked out in that mkv (dvhe.08.06, BL+EL+RPU) is not correct and it is not necessary to do so?
Well, it could be right as long as FEL doesn't expand the brightness. Looks like the dynamic metadata is used.
But better just convert P7 to true P8(no el and remove mapping) for playback on non-fel devices but once again, as long as FEL doesn't expand the brightness
2017-2019...
P7 ST-DL: TS or MP4, some files give black screen.
P7 DT-DL: Ts doesn't work but mp4 works. (some fel file may stutter)
P8/P5: TS and MP4 are fine
2020+ ...
P7 ST-DL: HDR10
P7 DT-DL: HDR10
Mithrandir
@RESET_9999 I've used MP4 workflow with DV P5 mkv (workflow 7 if i recall correctly).
After converting I'm getting random audio dropouts during playback on LG CX (internal player).
I'm using latest scripts (1.8.3).
Did you had similar issues?
I've used your scripts in the past (maybe a year ago) and didn't encounter similar issues.
MediaInfo of original file (shortened cause it has 25 subtitles).
General
Unique ID                                : 123878627500660741924601339876164737565 (0x5D3227E3A4B0E46A0170FAEAF2239A1D)
Complete name                            : The Mandalorian - S03E03 - Chapter 19 - The Convert WEBDL-2160p.mkv
File size                                : 6.69 GiB
Duration                                 : 56 min 11 s
Overall bit rate                         : 17.1 Mb/s
Frame rate                               : 24.000 FPS
Writing application                      : mkvmerge v74.0.0 ('You Oughta Know') 64-bit
Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
Video
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Bit rate                                 : 16.3 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.082
Stream size                              : 6.39 GiB (95%)
Color range                              : Full
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Bit rate                                 : 768 kb/s
Stream size                              : 309 MiB (5%)
Complexity index                         : 16
Number of dynamic objects                : 15
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 52 min 42 s
Bit rate                                 : 45 b/s
Frame rate                               : 0.175 FPS
Count of elements                        : 552
Stream size                              : 17.7 KiB (0%)
Text #2
Format                                   : UTF-8
Bit rate                                 : 53 b/s
Frame rate                               : 0.210 FPS
Count of elements                        : 664
Stream size                              : 20.5 KiB (0%)
Title                                    : SDH
Menu
00:00:04.000                             : en:Recap
00:01:02.083                             : en:Scene 1
00:01:02.125                             : en:Intro
00:01:26.417                             : en:Scene 2
00:19:07.583                             : en:Scene 3
00:30:18.917                             : en:Scene 4
00:38:05.333                             : en:Scene 5
00:53:14.458                             : en:Credits
Mediainfo of converted file:
General
Complete name                            : The Mandalorian - S03E03 - Chapter 19 - The Convert WEBDL-2160p_DoVi.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (iso4/mp42/dby1)
Encoded date                             : 2023-05-04 22:31:56 UTC
Tagged date                              : 2023-05-04 22:31:56 UTC
Writing application                      : GPAC-2.1-DEV-rev321-gc68d8a53-master
Video
Codec ID                                 : dvh1
Maximum bit rate                         : 40.3 Mb/s
Tagged date                              : 2023-05-04 22:32:15 UTC
Color range                              : Full
mdhd_Duration                            : 3371333
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Title                                    : DDP
Encoded date                             : 2023-05-04 22:32:11 UTC
Text #1
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 52 min 43 s
Bit rate                                 : 50 b/s
Frame rate                               : 0.283 FPS
Stream size                              : 19.5 KiB (0%)
Title                                    : SRT
Encoded date                             : 2023-05-04 22:32:13 UTC
Count of events                          : 552
Text #2
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 59 b/s
Frame rate                               : 0.344 FPS
Stream size                              : 22.7 KiB (0%)
Title                                    : SRT
Count of events                          : 664
TheEqualizer
Mithrandir wrote: Fri May 05, 2023 7:47 pm
This problem is observed only on Disney+ and Netflix web-dl and only when playing over the network (NAS or DLNA PC), if run via usb, everything will work. If RESET_9999 knows the treatment method, it will be great, but as far as I know, when building mp4box, it will not be possible to make a working version, you need to build using ffmpeg
yeah , reason number 1222131545 why I don't use the mp4 container. I have never had any issues since I'm using the TS container with external SRT.
Mithrandir
TheEqualizer wrote: Fri May 05, 2023 8:29 pm This problem is observed only on Disney+ and Netflix web-dl and only when playing over the network (NAS or DLNA PC), if run via usb, everything will work. If RESET_9999 knows the treatment method, it will be great, but as far as I know, when building mp4box, it will not be possible to make a working version, you need to build using ffmpeg
I tried remuxing using ffmpeg - then I get weird blocking artifacts on 10-15 places in file, but only if subs are included.
If i remux without subs, everything works fine.
I tried via Jellyfin and DLNA (Jellyfin DLNA). I'll try the USB also.
RESET_9999 wrote: Fri May 05, 2023 8:32 pm yeah , reason number 1222131545 why I don't use the mp4 container. I have never had any issues since I'm using the TS container with external SRT.
Thanks, I will try with .ts and report the results.
