German Terminator 2 HD-DVD Steelbook not ripping
epiicdave
#1 Post by epiicdave » Wed May 03, 2023 9:55 pm
Tried in v1.10.5 and v1.17.3 and both fail to open the disc. This is the German T2 HD-DVD steelbook running in an Xbox 360 HD-DVD player hooked up with USB. Not sure what the problem is.
v1.10.5
DEBUG: Code 0 at #ztvmDNJUZ?3N iP&:29393953
DEBUG: Code 0 at C/}W0SCE`%4Iy:213130007
v1.17.3
DEBUG: Code 0 at !#jRE6T$T.j g:213130007
Re: German Terminator 2 HD-DVD Steelbook not ripping
#2 Post by dcoke22 » Thu May 04, 2023 1:17 am
MakeMKV 1.17.3 not opening any HD DVD discs
Try version 1.17.2. It'll probably work.
epiicdave
#3 Post by epiicdave » Thu May 04, 2023 3:54 pm
Just tried v1.17.2. This is what I got.
DEBUG: Code 0 at *qa}1C&#G]{@U:213130007
Opens other HD-DVD discs fine, though. Not sure what's wrong with this disc specifically. The disc definitely works.
Waterman981
#4 Post by Waterman981 » Thu May 18, 2023 2:32 am
I'm have the same issue with that disc. I've tried in 1.15.3, 1.16.5, 1.17.1 as well, all also failing to open disc.
I'm trying other things now to get it off, but definitely not as easy as MakeMKV. I was able to extract a full ISO using AnyDVD, but that ISO, or mounting it and trying to open the files inside still give the same error in MakeMKV.
