German Terminator 2 HD-DVD Steelbook not ripping
epiicdave
Post by epiicdave »
Tried in v1.10.5 and v1.17.3 and both fail to open the disc. This is the German T2 HD-DVD steelbook running in an Xbox 360 HD-DVD player hooked up with USB. Not sure what the problem is.
v1.10.5
DEBUG: Code 0 at #ztvmDNJUZ?3N iP&:29393953
DEBUG: Code 0 at C/}W0SCE`%4Iy:213130007
v1.17.3
DEBUG: Code 0 at !#jRE6T$T.j g:213130007
Re: German Terminator 2 HD-DVD Steelbook not ripping
MakeMKV 1.17.3 not opening any HD DVD discs
Try version 1.17.2. It'll probably work.
epiicdave
Post by epiicdave »
Just tried v1.17.2. This is what I got.
DEBUG: Code 0 at *qa}1C&#G]{@U:213130007
Opens other HD-DVD discs fine, though. Not sure what's wrong with this disc specifically. The disc definitely works.
Waterman981
Post by Waterman981 »
I'm have the same issue with that disc. I've tried in 1.15.3, 1.16.5, 1.17.1 as well, all also failing to open disc.
I'm trying other things now to get it off, but definitely not as easy as MakeMKV. I was able to extract a full ISO using AnyDVD, but that ISO, or mounting it and trying to open the files inside still give the same error in MakeMKV.
