ntropy
Post by ntropy »
Is there a Ninite type tool to batch download all these tools needed for the tools folder of DoVi_Scripts?
valington
Post by valington »
Please give me simple steps for creating mp4 7 profile dolby vision for my oled e8
ntropy wrote: Tue May 02, 2023 6:32 am Is there a Ninite type tool to batch download all these tools needed for the tools folder of DoVi_Scripts?
Unfortunately no but check out the new version I will upload today (1.8.3). Only for this time, I will share the tools with the bat file because there are a lot of new tools/DLL to add.
I implemented the DoVi_Baker (FEL screenshot maker) into a workflow that index and creates an avisynth script that can be opened in avspmod or MPC.
ragico
Post by ragico »
@Reset_9999
Thank you for your advice and the excellent Dovi scripts/Tools
:D :D :D
afarvvik
Post by afarvvik »
RESET_9999 wrote: Wed Jan 25, 2023 10:45 pm
afarvvik wrote: Wed Jan 25, 2023 8:50 pm can you please confirm if you can FF/RW on the WebOS media player app with TS/m2ts files?
I just tested my C8 with DV TS files and I can confirm that FF/RW works on both PLEX and webOS app.
the file i tried had closed gop though
Hi @RESET_9999
Finally got round to testing this. can confirm FF/REW work in Plex & emby apps, so the issue was the jellyfin & webos inbuilt media player app.
Issue now is that in the Plex app if you select external srt subtitles it compulsorily transcodes even those files which otherwise play properly in "Direct Play" mode if subs are kept disabled. This is only happening with Plex, with emby everything plays ok even with subs.
I would've just stuck with emby & be done with it but for the bad UI design on the emby app on the tv where the subtitle toggle opens in full screen with a grey background & the movie keeps playing, so every time you disable or enable subs you also have to go back 10 seconds to see what you missed. Any clues of how to fix the Plex transcoding? I suspect it's a new issue in one of the latest plex versions as research seems to suggest this should not be occurring.
Thank you.
Mithrandir
Post by Mithrandir »
afarvvik wrote: Wed May 03, 2023 1:54 am
Hi @RESET_9999
Thank you.
Default LG WebOS profile is broken for transcoding in Jellyfin (at least for CX).
It starts transcoding even when file is available for directplay. I edited the default LG profile to allow all files without transcoding and checked in logs that it uses DirectPlay.
dom61
Post by dom61 »
@RESET_9999
Thank you for the latest release and the updated tools package.
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
afarvvik
Post by afarvvik »
Mithrandir wrote: Wed May 03, 2023 7:14 am
thanks for the reply. can you please let me know what version of jellyfin you did this in? is FF/REW working for you with m2ts files in jellyfin? I had to move to Emby because FF/REW was not working for me with m2ts files in jellyfin and I can not use plex because it transcodes when SRT is enabled.
TheEqualizer
Post by TheEqualizer »
How to get dvhe.08.06 BL+EL+RPU (Codec ID:hev1)?
Video
Format                 : HEVC
Format/Info               : High Efficiency Video Coding
Format profile             : Main 10@L5.1@High
HDR format               : Dolby Vision, Version 1.0, dvhe.08.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                : hev1
Codec ID/Info              : High Efficiency Video Coding
Duration                : 1 h 46 min
Source duration             : 1 h 46 min
Bit rate                : 80.1 Mb/s
Maximum bit rate            : 128 Mb/s
Width                  : 3 840 pixels
Height                 : 2 160 pixels
Display aspect ratio          : 16:9
Frame rate mode             : Constant
Frame rate               : 24.000 FPS
Good day to all dear, explain to me who is aware of how you can get dvhe.08.06 BL+EL+RPU?
I met today first .MKV in this version, I was shocked, after which I received .mp4 (MI attached) from it and was in double shock, since the movie works fine on the built-in LG TV player. But how? Does the TV player know how to ignore EL or do I get a full Dolby Vision?
P.S. My TV LG OLED B9 2019, the firmware is the last one that was given officially
rbjtech
Post by rbjtech »
@RESET_9999
First of all - thanks for your amazing DV scripts - I found them after writing a VERY basic script of my own only to find out you had done all the hard work. :D
I did make a couple of additions to it though which you may or may not want to include in a future update.
a) use a variable for the DDP Track title name instead of hard setting it in the code.
b) use a variable to set the DDP Track to default - current it sets it as Default but does not remove the existing one from the copied tracks. Having two Defaults is probably not desirable.
:: choose the title track name for the added Dolby Digital Plus Track
set DDP_Title=Dolby Digital+
:: do not set DDP track to Default=YES - keep the existing Track Audio Default as is.  Set to 1=Set Default - old Default will not be removed..
set DDP_Default=0
Also each usage is then modified ..
if exist "%output_path%%filename%_7.1.ec3" set DDP=--language 0:%lmkv% [b]--track-name 0:"%DDP_Title% 7.1" --default-track-flag 0:%DDP_Default%[/b] --compression 0:none %delay% ^"^(^" ^"%output_path%%filename%_7.1.ec3^" ^"^)^"
if exist "%output_path%%filename%_EC3.mkv" set DDP=--language 0:%lmkv% [b]--track-name 0:"%DDP_Title% 5.1" --default-track-flag 0:%DDP_Default%[/b] --compression 0:none ^"^(^" ^"%output_path%%filename%_EC3.mkv^" ^"^)^"
I'd also like to correct the track order during the mkvmerge write (as the DDP track is added at the end, not after the last Audio track) - easily done with --track-order but I need to test a lot more first
I hope these might help a few users out and save a manual edit post the process.
valington wrote: Tue May 02, 2023 1:45 pm Please give me simple steps for creating mp4 7 profile dolby vision for my oled e8
Download this and export to a folder preferably without space or special characters.(don't move any files): https://drive.google.com/file/d/1g-nQY5 ... share_link
download this beta version of the script and put it in your DoVi_Scripts folder (this contains the latest version of the DT-DL mp4 workflow: https://drive.google.com/file/d/1SYnK9M ... share_link
Then if your input is a makemkv Profile 7 rip (7-3-1):
if your input is a bluray disc (7-3-2):
TheEqualizer wrote: Thu May 04, 2023 7:14 am How to get dvhe.08.06 BL+EL+RPU (Codec ID:hev1)?
P8 with EL is not standard and there's no need to use it since your TV support dual track dual layer Profile 7 FEL. See my reply to @valington
Mithrandir
afarvvik wrote: Wed May 03, 2023 8:00 pm thanks for the reply. can you please let me know what version of jellyfin you did this in? is FF/REW working for you with m2ts files in jellyfin? I had to move to Emby because FF/REW was not working for me with m2ts files in jellyfin and I can not use plex because it transcodes when SRT is enabled.
Latest Jellyfin Version: 10.8.10.
I didn't see you are using m2ts files.
I'm using MKV and MP4 files and FF/REW works completely fine.
I used ts few times but can't remember if FF/REW worked.
I never used m2ts.
Isn't m2ts designed to work only in disc players?
TheEqualizer
RESET_9999 wrote: Thu May 04, 2023 5:25 pm P8 with EL is not standard and there's no need to use it since your TV support dual track dual layer Profile 7 FEL. See my reply to @valington
Yes, I know that my TV 2019 supports 7 FEL, but not since 2020, and I need a universal option for tv 2019 and newer, up to this point I have used P8 BL+RPU, but I saw this non-standard option and it confused me. I am also aware that dvi.08.06 BL+EL+RU is not a DV standard, but still the question was, why does TV reproduce this option correctly, does it ignore el or somehow reproduces it as in cases with a two-layer 7 profile? And how did manage to get such an option dvh.08.06 BL+EL+RU?
TheEqualizer wrote: Thu May 04, 2023 9:33 pm Yes, I know that my TV 2019 supports 7 FEL, but not since 2020, and I need a universal option for tv 2019 and newer,
Surprised that HEV1 works on the B9 since it doesn't work on the C8.
The only universal solution that works EVERYWHERE is the TS/M2TS container in P8.
I don't know but you can try to use this P7 file and remux it to P8 without removing the EL and see if FEL is used:
https://drive.google.com/file/d/1J5QnjW ... share_link
you can force P8 with the mp4muxer:
"%mp4muxer_path%" --dv-profile 8 --input-file ST-DL.hevc --output-file "output.mp4"
