Oh, you got one with the new nasty firmware. You may be waiting a while yet....executor999 wrote: Tue May 02, 2023 10:01 pm Drive Information
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number:
Firmware date: 2022-12-12
Highest AACS version: 77
Firmware version: ID43
LibreDrive for Pioneer drives
I recently updated the firmware revision of a BDR-XS07UHD UHD Blu-ray player from 1.02 (when I got it recently) to 1.03. When it was updated to 1.03, the feature seems to have been deactivated, but not removed. Is there any way to re-enable the feature. It seems to have removed the ability to specifically get content from 4K Blu-rays, as I was able to do it beforehand.
- Pioneer Update 4.PNG (13.38 KiB) Viewed 28516 times
- Pioneer Update 2.PNG (62.74 KiB) Viewed 28516 times
Silly bugger!!! Should have left it alone. Not possible to downgrade it at the moment and support cannot currently be added for that firmware. You could be waiting for a while…RiiTiiMii wrote: Wed May 03, 2023 2:31 am I recently updated the firmware revision of a BDR-XS07UHD UHD Blu-ray player from 1.02 (when I got it recently) to 1.03. When it was updated to 1.03, the feature seems to have been deactivated, but not removed. Is there any way to re-enable the feature. It seems to have removed the ability to specifically get content from 4K Blu-rays, as I was able to do it beforehand.
I don’t understand why people keep updating their drive firmware. There’s generally no benefit from updating firmware on optical drives anyway. If it works, leave the bloody thing alone!
I am getting this error. I only plugged the device into a USB C port and installed MKV software using the 30 day trail. Have no performed any updates or firmware upgrades. So this should be how it came out of the box unless windows auto updated it. but the firmware date shows before December 2022 so i assume that is good.
Saved AACS dump file as C:\Users\***/.MakeMKV/MKB20_v76_The_Hobbit-_An_Unexpected_Journey_(Theatrical)_9C61.tgz
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: **********
Firmware date: 2022-10-24
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8E21
Firmware version: 1.02/ID05
Disc Information
Label: THE HOBBIT AUJ THE
Timestamp: 2020-09-24 22:08:28
Protection: AACS2.0/C v76
Data capacity: 73.47 Gb
Disc type: BD-ROM UHD
Revision: 1.02
Disc Information
Enable internet access in Makemkv.
Interesting. Restarting the application fixed the issue i guess. i closed it and restarted it and now its working.
powin wrote: Mon May 08, 2023 9:11 pm I am getting this error. I only plugged the device into a USB C port and installed MKV software using the 30 day trail. Have no performed any updates or firmware upgrades. So this should be how it came out of the box unless windows auto updated it. but the firmware date shows before December 2022 so i assume that is good.
Revision: 1.02
Disc Information
Not interesting. Normal. Makemkv tells you to close the application after entering the key and restart the program.
gyrene2083
Hello, Just bought the Pioneer BDR-XS07U from Amazon and am getting this
OS device name: E:
Revision: 1.03
Serial number: CBDL010770UC
Firmware date: 2023-01-06
Highest AACS version: 68
Firmware version: ID05
Going to have to wait a while for an update?
OS device name: E:
Revision: 1.03
The last firmware currently supported by MakeMKV for this drive is 1.02.gyrene2083 wrote: Fri May 12, 2023 9:36 pm Hello, Just bought the Pioneer BDR-XS07U from Amazon and am getting this
OS device name: E:
Revision: 1.03
The guys are saying that a solution is being worked on but I understand that there is no official ETA as of yet.
Would you mind telling me the date of manufacture printed on the box? I'm just trying to figure out whether you received a completely new drive or were sent a return originally delivered to someone who updated the firmware, found it was then locked down and sent it back.
gyrene2083
Thanks for the response. The date is February 2023. I'm sending it back and getting a drive from Billy.
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: CBDL000194UC
Firmware version: ID29
Revision: 1.03
simplepanda
I'm in the exact situation. Exact drive platform and firmware. Brand new drive arrived from NewEgg today and can't be used.Konten wrote: Sat May 13, 2023 7:36 amThe last firmware currently supported by MakeMKV for this drive is 1.02.gyrene2083 wrote: Fri May 12, 2023 9:36 pm Hello, Just bought the Pioneer BDR-XS07U from Amazon and am getting this
OS device name: E:
Revision: 1.03
Manufacturing date on the box is "MFD MAY 2022", so I've definitely got a May 2022 build drive with a January 2023 firmware installed on it.
Hoping there's a workaround for this drive soon.
These dates to me indicate that your drive was a return. You might have better luck if you exchange it for a replacement.simplepanda wrote: Mon May 15, 2023 7:08 pmI'm in the exact situation. Exact drive platform and firmware. Brand new drive arrived from NewEgg today and can't be used.Konten wrote: Sat May 13, 2023 7:36 amThe last firmware currently supported by MakeMKV for this drive is 1.02.gyrene2083 wrote: Fri May 12, 2023 9:36 pm Hello, Just bought the Pioneer BDR-XS07U from Amazon and am getting this
OS device name: E:
Revision: 1.03
Hoping there's a workaround for this drive soon.![]()
simplepanda
That's my thought too.Konten wrote: Mon May 15, 2023 7:20 pm These dates to me indicate that your drive was a return. You might have better luck if you exchange it for a replacement.
I have an LG drive that I've been ripping with but I think it's getting a bit long in the tooth, age wise. Discs occasionally just don't rip (hash errors). I bought this Pioneer as a replacement.
You mentioned that this platform/firmware was being worked on by the MakeMKV/Libre team? I'm not in any rush really so I wonder if rather than rolling the dice on getting a replacement from Newegg I should just keep the drive and wait for support in the future.
That new firmware won't be supported with the initial release makemkv developer first is planing a downgrade method then will later try to support new firmware without flashingsimplepanda wrote: Mon May 15, 2023 7:33 pmThat's my thought too.Konten wrote: Mon May 15, 2023 7:20 pm These dates to me indicate that your drive was a return. You might have better luck if you exchange it for a replacement.
