UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Re: UHD Enabled Drives (Australia & NZ only) & DIY "Single Drive Flasher UI" available worldwide!!
Hi everyone,
Just letting you know, I have:
LG BP50NB40 (your choice of BP60NB10 or BU40N firmware for UHD readability!)
  • 0 available
  • 4 incoming
Pioneer BDR-XD07TB (cross-flashed to enable UHD readability!) ** Pioneer $199 Special **
  • 1 available
  • 2 incoming
Archgon BU40N flashed to BU40N 1.00 for use with all ripping software!
  • 2 available
  • 0 incoming
LG BH16NS55 (with your choice of firmware!)
  • 0 available
  • 1 incoming
**1 x Alxum SATA / USB powered adapter available to be purchased with any internal desktop drive.**
And don't forget, the "Single Drive Flasher UI" is available worldwide for the most common drives and firmwares!! Easily perform the drive flash yourself in your own time, whenever you are ready...
To ask a question, check pricing and availability or place an order, please go to https://uhdenableddrives.com
Hi everyone,
LG BP50NB40 (your choice of BP60NB10 or BU40N firmware for UHD readability!) ** LG $199 Special **
  • 2 available
  • 2 incoming
  • 2 available
  • 2 incoming
  • 2 available
  • 0 incoming
  • 0 available
  • 1 incoming
Hi everyone,
  • 1 available
  • 2 incoming
  • 2 available
  • 0 incoming
  • 2 available
  • 0 incoming
LG BU40N bare drive flashed to BU40N 1.00 for use with all ripping software! Also have a Vantec enclosure available!
  • 1 available
  • 0 incoming
  • 1 avaliable
  • 0 incoming
Hi everyone,
  • 2 available
  • 2 incoming
  • 1 available
  • 0 incoming
  • 1 available
  • 0 incoming
  • 1 available
  • 0 incoming
  • 1 avaliable
  • 0 incoming
Re: UHD Enabled Drives (Australia, NZ & Singapore only) & DIY "Single Drive Flasher UI" available worldwide!!
Hi everyone,
  • 3 available
  • 0 incoming
  • 0 available
  • 3 incoming
  • 1 available
  • 0 incoming
  • 1 available
  • 0 incoming
  • 1 avaliable
  • 0 incoming
Hi everyone,
  • 2 available
  • 0 incoming
  • 2 available
  • 2 incoming
  • 1 available
  • 0 incoming
  • 1 available
  • 0 incoming
  • 0 avaliable
  • 1 incoming
**The Alxum SATA / USB powered adapter is available to be purchased with any internal desktop drive.**
Hi everyone,
  • 1 available
  • 3 incoming
  • 3 available
  • 0 incoming
  • 0 available
  • 0 incoming (available to order)
  • 1 avaliable
  • 0 incoming
Hi everyone,
  • 4 available
  • 0 incoming
  • 3 available
  • 0 incoming
  • 0 available
  • 1 avaliable
  • 0 incoming
Hi everyone,
  • 0 available
  • 3 incoming
  • 1 available
  • 3 incoming
  • 0 available
  • 1 avaliable
  • 0 incoming
Re: UHD Enabled Drives (Australia, NZ & Singapore) & DIY "Single Drive Flasher UI" available worldwide!!
Hi everyone,
  • 0 available
  • 6 incoming
  • 0 available
  • 3 incoming
  • 0 available
  • 1 available
  • 0 incoming
Hi everyone,
  • 1 available
  • 6 incoming
  • 3 available
  • 0 incoming
  • 0 available
  • 1 available
  • 0 incoming
Hi everyone,
  • 3 available
  • 3 incoming
  • 0 available
  • 3 incoming
  • 0 available
  • 1 available
  • 0 incoming
Hi everyone,
  • 3 available
  • 3 incoming
  • 3 available
  • 0 incoming
  • 0 available
  • 1 available
  • 0 incoming
Hi everyone,
  • 6 available
  • 0 incoming
  • 3 available
  • 0 incoming
  • 0 available
  • 0 available
Hi everyone,
  • 5 available
  • 0 incoming
  • 3 available
  • 0 incoming
  • 0 available
  • 1 available
  • 0 incoming
**The Alxum SATA / USB powered adapter is also available for purchase with any internal desktop drive.**
**A compatible USB-C cable is also available for purchase with any external slim drive.**
