Have been using MakeMKV for a while with great success. I use the program to convert DVD to MKV format for my WD Live TV box. Upgraded to new version yesterday and now my WD Live TV can not read the MKV files? WD TV Live indicates the file is not the correct format?
Not sure what changed since the last version?
I upgraded the WD Live TV firmware to latest version and still it can not read the MKV file from MaleMKV version 1.6.9 for Windows. I'm running Windows 7 - 64 bit. Up to version 1.6.9 the program has been excellent!
Version 1.6.9 not compatable with WD Live TV
Go Canucks Go
crowfax
Re: Version 1.6.9 not compatable with WD Live TV
This is a bug, it is being looked into:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3626
For now you can just remux the streams with MKVmergeGUI (from the MKVToolnix package) and the MKV's will work again on your WD TV.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
1.6.10 is now available.
Go Canucks Go
Thanks for the quick update - I'll give it a try
dickie
I am also experiencing OP's problem i.e. incompatability with my WD TV live box.
I'm afraid that files made with 1.6.10 don't work either - I have tried two this evening, neither working.
If I can help (e.g. attempting to play test files?) please let me know.
Cheers,
D.
Cheers,
D.
crowfax
Same for me. Mike will fix it.
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3634
