Hello All,
I've ripped the blu-ray, "The Martian" and the chapter sequence is all out of whack. This is a purchased disc, "Blu-Ray + Digital HD". I didn't have any trouble ripping the film, but when you go to play, the chapters aren't in the right sequence. I did a search in this forum about this issue, but couldn't find a thread that addressed the issue. There's really only one suitable selection on the disc: 00800.mpls t02.mkv Have others had this problem, is there a solution?
The Martian blu-ray
Re: The Martian blu-ray
The Martian (2016) appears to be a 20th Century Fox movie. Usually it is Lionsgate that has playlist obfuscation.
How many playlists of the movie did MakeMKV find on your disc? If it was just the one playlist you mentioned, 00800.mpls, then that must be the one.
Maybe I don't understand what you mean by 'chapter sequence is all out of whack'. Do you mean the movie plays out of order? Or something else?
photousa
Thank you for your help, my fault, problem solved. 00800.mpls is the only playlist that MakeMKV finds that usable.I was mistaken when I thought that the chapters were out of sequence and they in fact, not.
