Brimstone (French version) Can't open disc
Amaury
Post by Amaury » Fri Apr 28, 2023 2:58 pm
I can't open the just released French version of Brimstone.
Any Idea ?
Thanks,
Amaury
Informations lecteur
Nom du lecteur SE : F:
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-S12U
Révision : 1.01
Numéro de série : BCDL006622WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 78
Drive platform: RS8F01
Firmware version: 1.01/ID43
Information du disque
Titre: BRIMSTONE
Horodatage: 2022-04-27 10:17:34
Protection: AACS2.0/C v70
Capacité de données : 84.48 Gb
Type de disque : BD-ROM UHD
Nombre de couches : 3
Marqueurs d'encryptage bus : 80
Re: Brimstone (French version) Can't open disc
Post by Woodstock » Fri Apr 28, 2023 3:23 pm
Not without the error message displayed.
Did it say it could not find the key, and say it wrote a file with the necessary information in it to obtain the key?
Amaury
Post by Amaury » Fri Apr 28, 2023 4:01 pm
Sorry I forgot to post the message :
Fichier de vidange AACS enregistré sous C:\Users\amaur/.MakeMKV/MKB20_v70_BLU-RAY_UHD_61ED.tgz
La clé de volume est inconnue pour ce dique - la vidéo ne peut être décryptée
Échec de l'ouverture du disque
It says missing key
Amaury
Post by Amaury » Fri Apr 28, 2023 4:23 pm
Sorry I forgot the error message.
Yes it says missing key. I saved the .tgz file
Post by Woodstock » Fri Apr 28, 2023 4:30 pm
OK, then you email MKB20_v70_BLU-RAY_UHD_61ED.tgz to svq@makemkv.com to be processed.
It may take a few days, but eventually the key for this disk will be posted, and your system should automatically download it when MakeMKV loads.
Amaury
Post by Amaury » Fri Apr 28, 2023 4:50 pm
Great ! Thanks for your help :D
