I don't remember the FEL doing much for No Time to Die.
If someone can figure out what timestamp they're talking about, maybe I'll take a look.
It's probably around 00:44:19.
Anyways, whatever difference they're seeing has nothing to do with FEL or the Dolby Vision metadata.
There's no difference with FEL.
This is why my script removes the default trims for the Resolve generated DV.
https://slow.pics/c/wxH1FjWA
@RESET_9999
Is there a way to disable all subtitles extraction in your script (even forced and full)?
By default, the script doesn't export subs unless you changed line 40
set export.subs=YES
TS version of the script may still extract them but it doesn't keep them in your output path if line40 is set to NO
So I'm trying to make sense of L2 now that I can plot it...
From the movies I plotted L2 so far, it seems the most important and used trims are ''slope'' and ''power'' and if we look at the Eagle Beak L2 pattern: https://drive.google.com/file/d/1qdHux6 ... share_link
power: values lower than 2048 make the image brighter.
slope: values lower than 2048 make the image darker.
offset: values lower than 2048 make the image darker.
chroma weight: affect the colors
trim_saturation_gain: no effect on all the devices I tested
ms_weight: no effect on all the devices I tested
M3GAN: The L2 trims on this movie make the image noticeably brighter than HDR10 or DV without trims even though the grade L1 maxcll is only 485nits (avg 284nits).
https://slow.pics/c/KzTUSbmB
eagle beak L2 trims in action video: https://www.youtube.com/watch?v=qSo-h-Rl-ps
original 600 and 1000nits values of the Eagle beak pattern:
"Level2": {
"target_max_pq": 2851,
"trim_slope": 1594,
"trim_offset": 1935,
"trim_power": 1515,
"trim_chroma_weight": 2474,
"trim_saturation_gain": 2036,
"ms_weight": 4095
"Level2": {
"target_max_pq": 3079,
"trim_slope": 1413,
"trim_offset": 1923,
"trim_power": 1353,
"trim_chroma_weight": 2720,
"trim_saturation_gain": 2308,
"ms_weight": 4095
}Re: Dolby Vision now possible through MP4 Mux.
I use the TS version with line 40 set to NO and it still muxes them into the TS file.By default, the script doesn't export subs unless you changed line 40
set export.subs=YES
sub muxing cannot be disabled but you can just disable the muxing(line 22)completely and it will launch tsmuxer with the output files in it at the end of the workflow so you can select any track you want this way.
That's perfect, thank you!RESET_9999 wrote: ↑Sat Apr 29, 2023 10:52 pmsub muxing cannot be disabled but you can just disable the muxing(line 22)completely and it will launch tsmuxer with the output files in it at the end of the workflow so you can select any track you want this way.
Is there a Ninite type tool to batch download all these tools needed for the tools folder of DoVi_Scripts?
Please give me simple steps for creating mp4 7 profile dolby vision for my oled e8
Unfortunately no but check out the new version I will upload today (1.8.3). Only for this time, I will share the tools with the bat file because there are a lot of new tools/DLL to add.
I implemented the DoVi_Baker (FEL screenshot maker) into a workflow that index and creates an avisynth script that can be opened in avspmod or MPC.
@Reset_9999
Thank you for your advice and the excellent Dovi scripts/Tools
Hi @RESET_9999RESET_9999 wrote: ↑Wed Jan 25, 2023 10:45 pmI just tested my C8 with DV TS files and I can confirm that FF/RW works on both PLEX and webOS app.
the file i tried had closed gop though
Finally got round to testing this. can confirm FF/REW work in Plex & emby apps, so the issue was the jellyfin & webos inbuilt media player app.
Issue now is that in the Plex app if you select external srt subtitles it compulsorily transcodes even those files which otherwise play properly in "Direct Play" mode if subs are kept disabled. This is only happening with Plex, with emby everything plays ok even with subs.
I would've just stuck with emby & be done with it but for the bad UI design on the emby app on the tv where the subtitle toggle opens in full screen with a grey background & the movie keeps playing, so every time you disable or enable subs you also have to go back 10 seconds to see what you missed. Any clues of how to fix the Plex transcoding? I suspect it's a new issue in one of the latest plex versions as research seems to suggest this should not be occurring.
Thank you.
Mithrandir
Default LG WebOS profile is broken for transcoding in Jellyfin (at least for CX).afarvvik wrote: ↑Wed May 03, 2023 1:54 amHi @RESET_9999RESET_9999 wrote: ↑Wed Jan 25, 2023 10:45 pmI just tested my C8 with DV TS files and I can confirm that FF/RW works on both PLEX and webOS app.
Thank you.
It starts transcoding even when file is available for directplay. I edited the default LG profile to allow all files without transcoding and checked in logs that it uses DirectPlay.
@RESET_9999
Thank you for the latest release and the updated tools package.
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
My PC Ryzen 7950X
