Dumb question
HomeAutomation
Dumb question
Post by HomeAutomation » Thu Apr 27, 2023 6:51 pm
Does the following mean that MakeMKV performs a micro-flash before ripping, or that I need to flash the firmware myself? My focus is just BluRay and DVDs.
Product: BD-RE WH14NS40
Revision: 1.03
Serial number: M66IA573423
Firmware date: 2117-11-21 16:58
Highest AACS version: 16
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Re: Dumb question
Post by Billycar11 » Thu Apr 27, 2023 6:52 pm
You have to do it yourself makemkv does not do it for you.
You don't need to do anything if your just using regular blu-ray and DVD
HomeAutomation
Re: Dumb question
Post by HomeAutomation » Thu Apr 27, 2023 7:01 pm
Thanks for the fast response. Just to make sure I understand, LibreDrive does not improve performance for blu-ray and DVDs?
Re: Dumb question
Post by Billycar11 » Thu Apr 27, 2023 8:00 pm
HomeAutomation wrote: Thu Apr 27, 2023 7:01 pm Thanks for the fast response. Just to make sure I understand, LibreDrive does not improve performance for blu-ray and DVDs?
Performance not unless you use the drive speed unlock in the registry for libredrive drives.
But there are a few cases where on new aacs version your drive will get locked without libredrive and you won't be able to copy any blurays until makemkv is updated but this is rare but libredrive would not let that happen
HomeAutomation
Re: Dumb question
Post by HomeAutomation » Fri Apr 28, 2023 12:09 am
Gotcha, so if I flashed the drives with LibreDrive drivers and applied a registry update, it may improve performance?
If my understanding is right, how much of a performance are we talking on average? Is it like 10-15% or closer to 50+%?
Re: Dumb question
Post by Billycar11 » Fri Apr 28, 2023 1:13 am
HomeAutomation wrote: Fri Apr 28, 2023 12:09 am Gotcha, so if I flashed the drives with LibreDrive drivers and applied a registry update, it may improve performance?
it could or it could blow up your discs seen that too would not recommend it
Re: Dumb question
Post by dcoke22 » Fri Apr 28, 2023 2:07 am
I assume you've read the thread about MakeMKV drive speed control.
At the end of the day, reading data faster from an optical disc requires the disc to spin faster. Spin it fast enough, and it'll break. Setting up unrestricted read speeds isn't likely to result in disc failure, but the chance is non-zero.
If you have a large number of discs to get through, a better solution is to use more than one drive at the same time. MakeMKV supports this with the 'Ask for single drive mode' checkbox in preferences. Personally, I have 3 drives and can use all 3 at the same time. This makes it relatively fast to ingest a whole season of a TV show, for example.
HomeAutomation
Re: Dumb question
Post by HomeAutomation » Tue Jun 13, 2023 1:28 pm
For anyone else coming back to this post, I just learned it's also needed for 4K Blu-rays.
