Hello, I am trying to rip the DVDs in One Piece Collection 3 but disc 1 and 2 (out of 4) wont find the "Play All" title. The collection seems to store all the EPs in a single title with EP selection just jumping into the play all title. Its a bit weird and inconvenient but I can split it up based on the chapters so it works. Except for the two discs which can only find the "Marathon" title which is like the play all title but skips the intro and outro, which is great for binging but not for discrete EPs. I can play the play all section in VLC no problem and I pulled the title and chapters from it to attempt to manually open the DVD but when I go to rip it returns an errors such as: 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_09_1.VOB' at offset '1335296'
I have attached debug logs from three different attempts, one is using the manual disc rip with 28:1-49, one is a manual disc rip with 28:1-7,8-14,15-21,22-28,29-35,36-42,43-49,50, and one is a manual disc rip of a disc backup file with 29:1-49. I also have attached the dumps from the discinfo script found on the forum, the disc and tree information. I can also provide backups for the two discs.
Thanks,
Redrip
Error/can't find main feature with two discs in a series
redrip
redrip
Re: Error/can't find main feature with two discs in a series
Realized my attachments did not go through so I am putting the logs here, sorry about that.
Debug log from manual rip with 28:1-49
Debug log from manual rip with 28:1-7,8-14,15-21,22-28,29-35,36-42,43-49,50
Debug log from backup manual rip with 28:1-49
Disc info:
Disc tree
Debug log started at Wed Apr 26 15:25:53 2023 , written by MakeMKV v1.17.3 win(x64-release)
001005:0000 MakeMKV v1.17.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\flemi/MakeMKV_log.txt
DEBUG: Code 3 at 'W5#or0UspRy]J7I('S_3yx3:29395310
SDF v098: PIONEER_BD-RW__BDR-XS07U_1.01_BCDL006096UC
001011:0000 Using LibreDrive mode (v01.0 id=1534D764B687)
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #5 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #6 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #7 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #8 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #9 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #10 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #11 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #12 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #13 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #14 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #15 does not match one in IFO header.
001012:0000 Open DVD manually : "28:1-49"
003028:0000 Title #28 was added (105 cell(s), 2:51:53)
005014:0000 Saving 1 titles into directory file://G:/Video/One Piece/Collection 3/Disc 1
001003:0020 DEBUG: Code 100864261 at [zsJFhLiL.aL`&tD:121271617
001003:0020 DEBUG: Code 100864261 at ff}a6SaY.jZ^~$g4:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_09_1.VOB' at offset '1335296'
DEBUG: Code 100864261 at %uGJTuF,((P}m#0s#v:29394896
001003:0020 DEBUG: Code 100864261 at %uGJTuF,((P}m#0s#v:213131502
001003:0020 DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:29395471
001003:0020 DEBUG: Code 0 at %UdSDL"Iejhui(`P~;&:29393562
001003:0020 DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:213131157
001003:0020 DEBUG: Code 0 at ;A,PZPR7U;07xNLh*7.1:121262647
001003:0020 DEBUG: Code 652 at ;A,PZPR7U;07xNLh*7.1:121261773
001003:0020 DEBUG: Code 0 at ZxpmVf&p,a\GzmEpFK%A(/:121263751
001003:0020 DEBUG: Code 0 at *M=d>ww icjnMH% jWIDk:213137068
001003:0020 DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:29394022
001003:0020 DEBUG: Code 0 at .0L`{hK,F(y]3Wp9_Ciy:121266764
001003:0020 DEBUG: Code 0 at *M=d>ww icjnMH% jWIDk:29400462
001003:0020 DEBUG: Code 0 at *M=d>ww icjnMH% jWIDk:213136700
001003:0020 DEBUG: Code 3 at V-jbD:ZD)C{vw|Io+n:29403429
001003:0020 DEBUG: Code 3 at V-jbD:ZD)C{vw|Io+n:121266580
001003:0020 DEBUG: Code 0 at V-jbD:ZD)C{vw|Io+n:29401244
001003:0020 DEBUG: Code 0 at V-jbD:ZD)C{vw|Io+n:29401819
005003:0000 Failed to save title 0 to file G:/Video/One Piece/Collection 3/Disc 1/title_t00.mkv
005004:0080 0 titles saved, 1 failed
Debug log started at Wed Apr 26 15:31:56 2023 , written by MakeMKV v1.17.3 win(x64-release)
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\flemi/MakeMKV_log_1.txt
001012:0000 Open DVD manually : "28:1-7,8-14,15-21,22-28,29-35,36-42,43-49,50"
003028:0000 Title #28 was added (106 cell(s), 2:52:03)
Debug log started at Wed Apr 26 15:35:54 2023 , written by MakeMKV v1.17.3 win(x64-release)
001012:0000 Open DVD manually : "29:1-49"
vobs=ZeNp7/35kgyBXRxcF16Ag/yAGBnYOxsPvR8EoGAWjYBSMghEAAHWrbRM=
001003:0020 DEBUG: Code 2752 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 2768 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 2784 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 1120551 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 1679401 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 1680745 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 1680777 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 1680793 at !S4-YvF<W=Zk-9:213132721
001003:0020 DEBUG: Code 0 at JC-Ys'h_3:>^]2L}jq:121273641
001003:0020 DEBUG: Code 0 at JC-Ys'h_3:>^]2L}jq:121274699
003015:0000 Title #29 (2:54:56) was skipped due to navigation error
Title skip vts=10 pgcn=3
Volume in drive D is ONEPIECE_S2_P1_D1
Volume Serial Number is 17F7-CF3C
Directory of D:\
04/30/2009 03:39 PM <DIR> AUDIO_TS
04/30/2009 03:39 PM <DIR> JACKET_P
04/30/2009 03:56 PM <DIR> VIDEO_TS
0 File(s) 0 bytes
Directory of D:\AUDIO_TS
04/30/2009 03:39 PM <DIR> .
04/30/2009 03:33 PM <DIR> ..
0 File(s) 0 bytes
Directory of D:\JACKET_P
04/30/2009 03:39 PM 184,320 J00___5L.MP2
04/30/2009 03:39 PM 14,336 J00___5M.MP2
04/30/2009 03:39 PM 6,144 J00___5S.MP2
3 File(s) 204,800 bytes
Directory of D:\VIDEO_TS
04/30/2009 03:56 PM <DIR> .
04/30/2009 03:56 PM 53,248 VIDEO_TS.BUP
04/30/2009 03:56 PM 53,248 VIDEO_TS.IFO
04/30/2009 03:56 PM 499,712 VIDEO_TS.VOB
04/30/2009 03:56 PM 18,432 VTS_01_0.BUP
04/30/2009 03:56 PM 18,432 VTS_01_0.IFO
04/30/2009 03:56 PM 16,384 VTS_01_0.VOB
04/30/2009 03:56 PM 11,079,680 VTS_01_1.VOB
04/30/2009 03:56 PM 18,432 VTS_02_0.BUP
04/30/2009 03:56 PM 18,432 VTS_02_0.IFO
04/30/2009 03:56 PM 16,384 VTS_02_0.VOB
04/30/2009 03:56 PM 49,117,184 VTS_02_1.VOB
04/30/2009 03:56 PM 18,432 VTS_03_0.BUP
04/30/2009 03:56 PM 18,432 VTS_03_0.IFO
04/30/2009 03:56 PM 16,384 VTS_03_0.VOB
04/30/2009 03:56 PM 1,204,224 VTS_03_1.VOB
04/30/2009 03:56 PM 18,432 VTS_04_0.BUP
04/30/2009 03:56 PM 18,432 VTS_04_0.IFO
04/30/2009 03:56 PM 16,384 VTS_04_0.VOB
04/30/2009 03:56 PM 1,605,632 VTS_04_1.VOB
04/30/2009 03:56 PM 163,840 VTS_05_0.BUP
04/30/2009 03:56 PM 163,840 VTS_05_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_05_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_05_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_05_8.VOB
04/30/2009 03:56 PM 163,840 VTS_06_0.BUP
04/30/2009 03:56 PM 163,840 VTS_06_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_06_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_06_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_06_8.VOB
04/30/2009 03:56 PM 163,840 VTS_07_0.BUP
04/30/2009 03:56 PM 163,840 VTS_07_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_07_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_07_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_07_8.VOB
04/30/2009 03:56 PM 163,840 VTS_08_0.BUP
04/30/2009 03:56 PM 163,840 VTS_08_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_08_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_08_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_08_8.VOB
04/30/2009 03:56 PM 153,600 VTS_09_0.BUP
04/30/2009 03:56 PM 153,600 VTS_09_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_09_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_09_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_09_8.VOB
04/30/2009 03:56 PM 163,840 VTS_10_0.BUP
04/30/2009 03:56 PM 163,840 VTS_10_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_10_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_10_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_10_8.VOB
04/30/2009 03:56 PM 163,840 VTS_11_0.BUP
04/30/2009 03:56 PM 163,840 VTS_11_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_11_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_11_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_11_8.VOB
04/30/2009 03:56 PM 196,608 VTS_12_0.BUP
04/30/2009 03:56 PM 196,608 VTS_12_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_12_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_12_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_12_8.VOB
04/30/2009 03:56 PM 163,840 VTS_13_0.BUP
04/30/2009 03:56 PM 163,840 VTS_13_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_13_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_13_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_13_8.VOB
04/30/2009 03:56 PM 163,840 VTS_14_0.BUP
04/30/2009 03:56 PM 163,840 VTS_14_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_14_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_14_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_14_8.VOB
04/30/2009 03:56 PM 131,072 VTS_15_0.BUP
04/30/2009 03:56 PM 131,072 VTS_15_0.IFO
04/30/2009 03:56 PM 7,452,672 VTS_15_0.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_1.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_2.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_3.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_4.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_5.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_6.VOB
04/30/2009 03:56 PM 1,073,739,776 VTS_15_7.VOB
04/30/2009 03:56 PM 517,283,840 VTS_15_8.VOB
04/30/2009 03:56 PM 20,480 VTS_16_0.BUP
04/30/2009 03:56 PM 20,480 VTS_16_0.IFO
04/30/2009 03:56 PM 16,384 VTS_16_0.VOB
04/30/2009 03:56 PM 4,014,080 VTS_16_1.VOB
04/30/2009 03:56 PM 20,480 VTS_17_0.BUP
04/30/2009 03:56 PM 20,480 VTS_17_0.IFO
04/30/2009 03:56 PM 16,384 VTS_17_0.VOB
04/30/2009 03:56 PM 4,014,080 VTS_17_1.VOB
04/30/2009 03:56 PM 20,480 VTS_18_0.BUP
04/30/2009 03:56 PM 20,480 VTS_18_0.IFO
04/30/2009 03:56 PM 16,384 VTS_18_0.VOB
04/30/2009 03:56 PM 4,014,080 VTS_18_1.VOB
04/30/2009 03:56 PM 20,480 VTS_19_0.BUP
04/30/2009 03:56 PM 20,480 VTS_19_0.IFO
04/30/2009 03:56 PM 16,384 VTS_19_0.VOB
04/30/2009 03:56 PM 4,014,080 VTS_19_1.VOB
156 File(s) 88,533,760,000 bytes
Total Files Listed:
159 File(s) 88,533,964,800 bytes
9 Dir(s) 0 bytes free
MSG:1005,0,1,"MakeMKV v1.17.3 win(x86-release) started","%1 started","MakeMKV v1.17.3 win(x86-release)"
MSG:1004,131072,1,"Debug logging enabled, log will be saved as file://C:\\Users\\flemi/MakeMKV_log.txt","Debug logging enabled, log will be saved as %1","file://C:\\Users\\flemi/MakeMKV_log.txt"
MSG:1011,0,1,"You are running a 32-bit (x86) version of a program. Eventually this will be deprecated in upcoming versions, please upgrade to a processor manufactured during last 10 years...","%1","You are running a 32-bit (x86) version of a program. Eventually this will be deprecated in upcoming versions, please upgrade to a processor manufactured during last 10 years..."
DRV:0,2,999,1,"BD-RE PIONEER BD-RW BDR-XS07U 1.01 BCDL006096UC","ONEPIECE_S2_P1_D1","D:"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v01.0 id=1534D764B687)","%1","Using LibreDrive mode (v01.0 id=1534D764B687)"
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:3002,0,2,"Calculated BUP offset for VTS #0 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","0"
MSG:3002,0,2,"Calculated BUP offset for VTS #5 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","5"
MSG:3002,0,2,"Calculated BUP offset for VTS #6 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","6"
MSG:3002,0,2,"Calculated BUP offset for VTS #7 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","7"
MSG:3002,0,2,"Calculated BUP offset for VTS #8 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","8"
MSG:3002,0,2,"Calculated BUP offset for VTS #9 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","9"
MSG:3002,0,2,"Calculated BUP offset for VTS #10 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","10"
MSG:3002,0,2,"Calculated BUP offset for VTS #11 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","11"
MSG:3002,0,2,"Calculated BUP offset for VTS #12 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","12"
MSG:3002,0,2,"Calculated BUP offset for VTS #13 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","13"
MSG:3002,0,2,"Calculated BUP offset for VTS #14 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","14"
MSG:3002,0,2,"Calculated BUP offset for VTS #15 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","15"
MSG:3025,16777216,3,"Title #1 has length of 13 seconds which is less than minimum title length of 60 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","1","13","60"
MSG:3028,0,3,"Title #3 was added (1 cell(s), 0:01:02)","Title #%1 was added (%2 cell(s), %3)","3","1","0:01:02"
MSG:3037,16777216,1,"Cells 1-98 were removed from title start","Cells 1-%1 were removed from title start","98"
MSG:3038,16777216,2,"Cells 107-107 were removed from title end","Cells %1-%2 were removed from title end","107","107"
MSG:3028,0,3,"Title #28 was added (8 cell(s), 0:24:42)","Title #%1 was added (%2 cell(s), %3)","28","8","0:24:42"
MSG:3038,16777216,2,"Cells 30-30 were removed from title end","Cells %1-%2 were removed from title end","30","30"
MSG:3028,0,3,"Title #52 was added (29 cell(s), 2:29:04)","Title #%1 was added (%2 cell(s), %3)","52","29","2:29:04"
MSG:5011,0,0,"Operation successfully completed","Operation successfully completed"
TCOUNT:3
CINFO:1,6206,"DVD disc"
CINFO:2,0,"ONEPIECE_S2_P1_D1"
CINFO:30,0,"ONEPIECE_S2_P1_D1"
CINFO:31,6119,"<b>Source information</b><br>"
CINFO:32,0,"ONEPIECE_S2_P1_D1"
CINFO:33,0,"0"
TINFO:0,8,0,"1"
TINFO:0,9,0,"0:01:02"
TINFO:0,10,0,"46.8 MB"
TINFO:0,11,0,"49117184"
TINFO:0,24,0,"03"
TINFO:0,25,0,"1"
TINFO:0,26,0,"1"
TINFO:0,27,0,"A1_t00.mkv"
TINFO:0,30,0,"1 chapter(s) , 46.8 MB (A1)"
TINFO:0,31,6120,"<b>Title information</b><br>"
TINFO:0,33,0,"0"
TINFO:0,49,0,"A1"
SINFO:0,0,1,6201,"Video"
SINFO:0,0,5,0,"V_MPEG2"
SINFO:0,0,6,0,"Mpeg2"
SINFO:0,0,7,0,"Mpeg2"
SINFO:0,0,13,0,"9 Mb/s"
SINFO:0,0,19,0,"720x480"
SINFO:0,0,20,0,"4:3"
SINFO:0,0,21,0,"29.97 (30000/1001)"
SINFO:0,0,22,0,"0"
SINFO:0,0,30,0,"Mpeg2"
SINFO:0,0,31,6121,"<b>Track information</b><br>"
SINFO:0,0,33,0,"0"
SINFO:0,0,38,0,""
SINFO:0,0,42,5088,"( Lossless conversion )"
SINFO:0,1,1,6202,"Audio"
SINFO:0,1,2,5091,"Stereo"
SINFO:0,1,3,0,"eng"
SINFO:0,1,4,0,"English"
SINFO:0,1,5,0,"A_AC3"
SINFO:0,1,6,0,"DD"
SINFO:0,1,7,0,"Dolby Digital"
SINFO:0,1,13,0,"192 Kb/s"
SINFO:0,1,14,0,"2"
SINFO:0,1,17,0,"48000"
SINFO:0,1,22,0,"0"
SINFO:0,1,30,0,"DD Stereo English"
SINFO:0,1,31,6121,"<b>Track information</b><br>"
SINFO:0,1,33,0,"90"
SINFO:0,1,38,0,"d"
SINFO:0,1,39,0,"Default"
SINFO:0,1,40,0,"stereo"
SINFO:0,1,42,5088,"( Lossless conversion )"
TINFO:1,8,0,"8"
TINFO:1,9,0,"0:24:42"
TINFO:1,10,0,"1.0 GB"
TINFO:1,11,0,"1148315648"
TINFO:1,24,0,"28"
TINFO:1,25,0,"2"
TINFO:1,26,0,"99-105,106"
TINFO:1,27,0,"B1_t01.mkv"
TINFO:1,30,0,"8 chapter(s) , 1.0 GB (B1)"
TINFO:1,31,6120,"<b>Title information</b><br>"
TINFO:1,33,0,"0"
TINFO:1,49,0,"B1"
SINFO:1,0,1,6201,"Video"
SINFO:1,0,5,0,"V_MPEG2"
SINFO:1,0,6,0,"Mpeg2"
SINFO:1,0,7,0,"Mpeg2"
SINFO:1,0,13,0,"9.2 Mb/s"
SINFO:1,0,19,0,"720x480"
SINFO:1,0,20,0,"4:3"
SINFO:1,0,21,0,"29.97 (30000/1001)"
SINFO:1,0,22,0,"0"
SINFO:1,0,30,0,"Mpeg2"
SINFO:1,0,31,6121,"<b>Track information</b><br>"
SINFO:1,0,33,0,"0"
SINFO:1,0,38,0,""
SINFO:1,0,42,5088,"( Lossless conversion )"
SINFO:1,1,1,6202,"Audio"
SINFO:1,1,2,0,"Surround 5.1"
SINFO:1,1,3,0,"eng"
SINFO:1,1,4,0,"English"
SINFO:1,1,5,0,"A_AC3"
SINFO:1,1,6,0,"DD"
SINFO:1,1,7,0,"Dolby Digital"
SINFO:1,1,13,0,"448 Kb/s"
SINFO:1,1,14,0,"6"
SINFO:1,1,17,0,"48000"
SINFO:1,1,22,0,"0"
SINFO:1,1,30,0,"DD Surround 5.1 English"
SINFO:1,1,31,6121,"<b>Track information</b><br>"
SINFO:1,1,33,0,"90"
SINFO:1,1,38,0,"d"
SINFO:1,1,39,0,"Default"
SINFO:1,1,40,0,"5.1(side)"
SINFO:1,1,42,5088,"( Lossless conversion )"
SINFO:1,2,1,6202,"Audio"
SINFO:1,2,2,5091,"Stereo"
SINFO:1,2,3,0,"eng"
SINFO:1,2,4,0,"English"
SINFO:1,2,5,0,"A_AC3"
SINFO:1,2,6,0,"DD"
SINFO:1,2,7,0,"Dolby Digital"
SINFO:1,2,13,0,"192 Kb/s"
SINFO:1,2,14,0,"2"
SINFO:1,2,17,0,"48000"
SINFO:1,2,22,0,"0"
SINFO:1,2,30,0,"DD Stereo English"
SINFO:1,2,31,6121,"<b>Track information</b><br>"
SINFO:1,2,33,0,"90"
SINFO:1,2,38,0,""
SINFO:1,2,40,0,"stereo"
SINFO:1,2,42,5088,"( Lossless conversion )"
SINFO:1,3,1,6202,"Audio"
SINFO:1,3,2,5091,"Stereo"
SINFO:1,3,3,0,"jpn"
SINFO:1,3,4,0,"Japanese"
SINFO:1,3,5,0,"A_AC3"
SINFO:1,3,6,0,"DD"
SINFO:1,3,7,0,"Dolby Digital"
SINFO:1,3,13,0,"192 Kb/s"
SINFO:1,3,14,0,"2"
SINFO:1,3,17,0,"48000"
SINFO:1,3,22,0,"0"
SINFO:1,3,30,0,"DD Stereo Japanese"
SINFO:1,3,31,6121,"<b>Track information</b><br>"
SINFO:1,3,33,0,"90"
SINFO:1,3,38,0,""
SINFO:1,3,40,0,"stereo"
SINFO:1,3,42,5088,"( Lossless conversion )"
SINFO:1,4,1,6203,"Subtitles"
SINFO:1,4,3,0,"eng"
SINFO:1,4,4,0,"English"
SINFO:1,4,5,0,"S_VOBSUB"
SINFO:1,4,6,0,""
SINFO:1,4,7,0,"Dvd Subtitles"
SINFO:1,4,22,0,"0"
SINFO:1,4,30,0," English"
SINFO:1,4,31,6121,"<b>Track information</b><br>"
SINFO:1,4,33,0,"90"
SINFO:1,4,38,0,"d"
SINFO:1,4,39,0,"Default"
SINFO:1,4,42,5088,"( Lossless conversion )"
TINFO:2,8,0,"29"
TINFO:2,9,0,"2:29:04"
TINFO:2,10,0,"6.1 GB"
TINFO:2,11,0,"6551261184"
TINFO:2,24,0,"52"
TINFO:2,25,0,"7"
TINFO:2,26,0,"1-5,6-9,10-13,14-17,18-21,22-25,26-29"
TINFO:2,27,0,"B2_t02.mkv"
TINFO:2,30,0,"29 chapter(s) , 6.1 GB (B2)"
TINFO:2,31,6120,"<b>Title information</b><br>"
TINFO:2,33,0,"0"
TINFO:2,49,0,"B2"
SINFO:2,0,1,6201,"Video"
SINFO:2,0,5,0,"V_MPEG2"
SINFO:2,0,6,0,"Mpeg2"
SINFO:2,0,7,0,"Mpeg2"
SINFO:2,0,13,0,"9.2 Mb/s"
SINFO:2,0,19,0,"720x480"
SINFO:2,0,20,0,"4:3"
SINFO:2,0,21,0,"29.97 (30000/1001)"
SINFO:2,0,22,0,"0"
SINFO:2,0,30,0,"Mpeg2"
SINFO:2,0,31,6121,"<b>Track information</b><br>"
SINFO:2,0,33,0,"0"
SINFO:2,0,38,0,""
SINFO:2,0,42,5088,"( Lossless conversion )"
SINFO:2,1,1,6202,"Audio"
SINFO:2,1,2,0,"Surround 5.1"
SINFO:2,1,3,0,"eng"
SINFO:2,1,4,0,"English"
SINFO:2,1,5,0,"A_AC3"
SINFO:2,1,6,0,"DD"
SINFO:2,1,7,0,"Dolby Digital"
SINFO:2,1,13,0,"448 Kb/s"
SINFO:2,1,14,0,"6"
SINFO:2,1,17,0,"48000"
SINFO:2,1,22,0,"0"
SINFO:2,1,30,0,"DD Surround 5.1 English"
SINFO:2,1,31,6121,"<b>Track information</b><br>"
SINFO:2,1,33,0,"90"
SINFO:2,1,38,0,"d"
SINFO:2,1,39,0,"Default"
SINFO:2,1,40,0,"5.1(side)"
SINFO:2,1,42,5088,"( Lossless conversion )"
SINFO:2,2,1,6202,"Audio"
SINFO:2,2,2,5091,"Stereo"
SINFO:2,2,3,0,"eng"
SINFO:2,2,4,0,"English"
SINFO:2,2,5,0,"A_AC3"
SINFO:2,2,6,0,"DD"
SINFO:2,2,7,0,"Dolby Digital"
SINFO:2,2,13,0,"192 Kb/s"
SINFO:2,2,14,0,"2"
SINFO:2,2,17,0,"48000"
SINFO:2,2,22,0,"0"
SINFO:2,2,30,0,"DD Stereo English"
SINFO:2,2,31,6121,"<b>Track information</b><br>"
SINFO:2,2,33,0,"90"
SINFO:2,2,38,0,""
SINFO:2,2,40,0,"stereo"
SINFO:2,2,42,5088,"( Lossless conversion )"
SINFO:2,3,1,6202,"Audio"
SINFO:2,3,2,5091,"Stereo"
SINFO:2,3,3,0,"jpn"
SINFO:2,3,4,0,"Japanese"
SINFO:2,3,5,0,"A_AC3"
SINFO:2,3,6,0,"DD"
SINFO:2,3,7,0,"Dolby Digital"
SINFO:2,3,13,0,"192 Kb/s"
SINFO:2,3,14,0,"2"
SINFO:2,3,17,0,"48000"
SINFO:2,3,22,0,"0"
SINFO:2,3,30,0,"DD Stereo Japanese"
SINFO:2,3,31,6121,"<b>Track information</b><br>"
SINFO:2,3,33,0,"90"
SINFO:2,3,38,0,""
SINFO:2,3,40,0,"stereo"
SINFO:2,3,42,5088,"( Lossless conversion )"
SINFO:2,4,1,6203,"Subtitles"
SINFO:2,4,3,0,"eng"
SINFO:2,4,4,0,"English"
SINFO:2,4,5,0,"S_VOBSUB"
SINFO:2,4,6,0,""
SINFO:2,4,7,0,"Dvd Subtitles"
SINFO:2,4,22,0,"0"
SINFO:2,4,30,0," English"
SINFO:2,4,31,6121,"<b>Track information</b><br>"
SINFO:2,4,33,0,"90"
SINFO:2,4,38,0,"d"
SINFO:2,4,39,0,"Default"
SINFO:2,4,42,5088,"( Lossless conversion )"
If you're experiencing rip errors, please read here first!
You might also try a different DVD opening mode. DVD opening modes - CellWalk, CellTrim, CellFull
redrip
Sorry I should have clarified, I did follow that guide, except for the new disc part (yet). I did also try the other walking methods to no avail. I have tried two different disc drives, one a Pioneer BDR-XS07U and the other and old Slimtype eSAU208 that I had laying around. I also just picked up an LG WH16NS40 but I haven't tested it yet (it just arrived last night). I guess I am kind of hoping that because VLC could play it just fine and Handbrake can see and rip the Play all title, that there might be something MakeMKV is missing or needs adjusting. Worst case I will just buy the set new or use handbrake once I figure out how I want to encode the show (keep having artifacting with it).
Thanks,
redrip
Thanks,
redrip
I see. You're pretty far down the track; you've tried cleaning the disc and you've tried multiple optical drives. Personally, I'm always pleasantly surprised when I'm having trouble with a disc in my main drive, but one of my other drives reads it without error.
Have you tried making a whole disc backup and then making .mkv files of the episodes from the backup? I don't expect you'll have different results, but it is probably worth trying.
There seems to be an active discussion of One Piece over at blu-ray.com. https://www.blu-ray.com/dvd/One-Piece-C ... DVD/14039/ Perhaps there's discussion of a bad batch of discs or something.
redrip
Yeah not my first rodeo with DVD ripping heh. I did make a backup if the disc using MakeMKV but it still gave me a failed to open disk error, the log is in my second post. Though it again works just fine in VLC. I am going to flash the new drive I got and try again with that tonight, but I suspect it wont fix anything :/
I will poke around the discussion and see if I can find any hints, maybe there is a lead. Though I will admit I am skeptical of a bad disc because I can rip other parts off the disc, it just can't find the Play all main feature, even though the marathon feature is made up of the same parts and can be ripped.
redrip
Well, as expected the new drive didn't change anything, it returns the same results. Guess my next step is to try an get another set of discs and see if it persists, or figure out the artifact in handbrake and use that.
-redrip
-redrip
JackOfAll
I want to add what ended up working for me for others that have the same issue.
I used makemkv and handbrake, when you first open makemkv there's the option to make a backup of the disc in the upper left (before you click on the image of the drive to open the files). I made a backup of the discs, mkv saved them as an .iso file and I dropped the .iso into handbrake and cut the episodes like I would've just ripping from the disc normally. The backup for me only made one file and it was the "play all" video file, the only difference this made when actually looking at the file in handbrake was an additional 1 second chapter at the very end. Otherwise everything was in the right order for me.
