If you're experiencing rip errors, please read here first!
Re: If you're experiencing rip errors, please read here first!
chuck_richie_99 wrote: Tue Apr 25, 2023 6:48 pm Hello.
Running MakeMKV v1.17.3 win(x64-release). No longer opening blu-rays. I get the "No disc inserted" error. Tried several different disc, a few of which I've successfully ripped in the past. Currently working just fine for standard def DVD (just completed a test rip - no errors, rip plays fine). This has only started in the last week.
Any suggestions?
Thanks in advance.
Does your os see the blurays.
Sounds like your blu-ray laser died it sadly very common on the LG/Asus desktop drives
chuck_richie_99
Post by chuck_richie_99 »
Billycar11 wrote: Tue Apr 25, 2023 7:53 pm Does your os see the blurays.
That could be it. I have an LG WH14NS40 that I got when I built the machine 5 years ago. I'll check it out. I had no idea the laser for the blu ray was separate from the DVD standard laser.
chuck_richie_99
Looks like I have a dead laser. Question: I have cannibalized from an old PC an LGWH12LS39 from 2011. Will the current version of MakeMKV work with this drive if I use it?
chuck_richie_99 wrote: Wed Apr 26, 2023 11:05 pm Looks like I have a dead laser. Question: I have cannibalized from an old PC an LGWH12LS39 from 2011. Will the current version of MakeMKV work with this drive if I use it?
should but that drive wont do UHD like the WH14NS40 NS50 was capable of doing
chuck_richie_99
Billycar11 wrote: Thu Apr 27, 2023 2:04 am
Humor me, because I'm an old guy who's still a little new to this. The WH12 is in and working. Very slow, but completed a few blu ray rips and everything works. Do appreciate your guidance there.
Regarding UHD and flashing, I've read through the FAQs and articles. It appears this means I can buy a new drive and update the firmware to allow it to rip 4K discs. And I further believe you sell either UHD flashed drives or a software kit to do it myself. If I only plan to do standard blu rays, there's no need to flash the drive. Do I have that all correct?
chuck_richie_99 wrote: Thu Apr 27, 2023 4:32 pm
Yes no need for any of that for regular blurays
mf222
Post by mf222 »
impala454 wrote: Wed Mar 01, 2023 4:52 am Hi, I have a stubborn disc in Star Trek: The Next Generation: Season 7 Disc 1 Episode 3 is failing to rip each time with read errors. I have cleaned the disc and tried again a few times, and I noticed the link of one of the errors says:
The simple workaround is to copy all files from the disc to the hard drive manually, without MakeMKV running. If you succeed in this, there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details.
I found I was able to copy the .m2ts file in question but not sure what all else I needed for the "See our forum for details" part.
I am wondering about this too; the mysterious instructions on how to create a "encrypted MakeMKV backup" from the files copied don’t seem to exist.
shrekswfl
Post by shrekswfl »
OK, So I am stumped. I have a Blu Ray, Black Adam, that Makemkv sees its name, start to open the disk, just freezes for a few seconds, and then fatal errors. Nothing in the debug log, no read errors, no clicking or grinding, 2 different drives, both are ripping other disks fine as i type this.
Debug log started at Tue May 16 03:32:38 2023 , written by MakeMKV v1.17.3 linux(x64-release)
001005:0000 MakeMKV v1.17.3 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/kris/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.81.0/OpenSSL/3.0.2/1.43.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at j)b;2hEW?9IdZYnmhdZN9y:29393631
SDF v098: ASUS_BW-16D1HT_3.10_211901041014_M69IAGI2046
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
DEBUG: Code 2147483648 at La!Nk}BgpS\O1`L<:121265499
Found java version=11.0.18 path=/usr/lib/jvm/java-11-openjdk-amd64/bin/java
Found java version=11.0.18 path=/usr/bin/java
Found java version=11.0.18 path=/bin/java
003344:0000 Using Java runtime from /usr/lib/jvm/java-11-openjdk-amd64/bin/java
DISCID=D4D18FC5D43E1580AB60B42175A75B92C0BD0419
003025:0000 Title #00000.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00068.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00059.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00058.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00060.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00063.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00064.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00065.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00066.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00067.mpls was added as title #0
003025:0000 Title #00077.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00078.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00079.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00005.mpls was added as title #1
ember1205
Post by ember1205 »
How long are you waiting for it to "do something"? Have you checked the tmp directory to see if it's creating a file there at all?
off_duty
Post by off_duty »
Somewhere here in the forum it says that problems with ripping are
ALWAYS due to the reading weaknesses of the Blu-ray player.
This is definitely WRONG!
I have three blu-rays here that cannot be ripped with makemkv:
- castaway
- Blues Brothers
- Mamma Mia
However, they can be played and viewed in the same reader WITHOUT ANY PROBLEMS
- Leawo Blu-ray Player - Windows 10
- VideoByte BD-DVD Ripper (Preview Mode) - Windows 10
They can even be ripped with these programs.
(Evaluation programs of these only rips 5 minutes)
So the weaknesses of makmkv must come from somewhere.
Don't get me wrong: I think makemkv is fantastic and am very grateful
to the programmer for the great job!
But the assertion that it is ALWAYS the device could tempt some makemkv
users to buy a new device/burner, although problems can obviously also result
from weaknesses in makemkv.
I'm curious about any answers
Greetings
ember1205
Post by ember1205 »
off_duty wrote: Fri Jun 09, 2023 3:16 pm Somewhere here in the forum it says that problems with ripping are
- castaway
- Blues Brothers
- Mamma Mia
However, they can be played in the same reader WITHOUT ANY PROBLEMS
Greetings
Not wrong at all. My BluRay copy of the Blues Brothers ripped with no issue at all. Using an older version of the software (which has only gotten more capable over time). The difference between your setup and mine is the BluRay drive we are each using.
Post by d00zah »
off_duty wrote: Fri Jun 09, 2023 3:16 pm However, they can be played in the same reader WITHOUT ANY PROBLEMS
People keep insisting this is somehow meaningful. Players, by design, ignore read problems when possible, although viewers MAY notice random glitches/artifacts. IMO the optical disc industry couldn't exist w/out this "feature".
MakeMKV attempts to make a bit-perfect copy, retrying on read errors (up to set limit) & fails out if it is unsuccessful. Some other rippers may be more "forgiving".
When encountering read errors, conventional wisdom is to "clean he disc", whether it looks clean to the eye, or not. Ability to read past haze/fingerprints/scratches is inversely proportional to how much data is stored on a disc.
off_duty
Post by off_duty »
They even rip these blu-rays succesfully!
So it is true, that other ripper software can do the job with these three blu-rays,
makemkv fails on.
Off course I do not know, if they have problems with other blu-rays
TK-24601
Post by TK-24601 »
After doing some reading here, it appears my LG WH16NS40 might be hitting the end of it's life. Getting a lot more "No disc inserted" with several 4K discs that was previously readable. When trying to copy full discs I am getting more of the hash read errors. It had a good long life. Rode hard and ripped a ton of discs.
Is there a current consensus on quality UHD friendly drive?
TK-24601 wrote: Mon Jun 19, 2023 10:51 pm After doing some reading here, it appears my LG WH16NS40 might be hitting the end of it's life. Getting a lot more "No disc inserted" with several 4K discs that was previously readable. When trying to copy full discs I am getting more of the hash read errors. It had a good long life. Rode hard and ripped a ton of discs.
pioneer for sure but you need to buy a flashed one for now as new ones dont work
they are slower but way more consistently reliable
