1.6.9 broke metadata?
Locked
testmetest
#1 Post by testmetest » Sat May 28, 2011 9:17 pm
Hi, just a head's up:
I went from 1.6.8 to 1.6.9
I tried 4 different blu rays and the meta data is only listing the video information.
It no longer is listing audio codec, audio language, audio channels, subtitle language, or duration listed in metadata.
Thanks.
High-Tech
Re: 1.6.9 broke metadata?
#2 Post by High-Tech » Sat May 28, 2011 10:47 pm
i have the same problem.
I remuxed some BDs in .mkv and then when i want to check this files with "MediaInfo" it doesn?t show any information about it.
if i play the .mkv with VLC it works fine but with MediaInfo i cant see any information now :(
Please fix it.
Best Regards.
BlackDragon24
#3 Post by BlackDragon24 » Sun May 29, 2011 12:01 am
Update to 1.6.9 today and I just ripped down Despicable Me. The resulting MKV file seemed to play back ok in WMP on windows 7, but mediainfo only reported the audio stream present. I remuxed into a new mkv using mkvmerge and now it sees all the video, audio, and chapters. So there is something that is wrong with the new version in the way it writes mkv files to be viewed by mediainfo.
#4 Post by mike admin » Sun May 29, 2011 11:24 am
Apparently a bug in new MKV writing code. Looking.
Qedinux
#5 Post by Qedinux » Sun May 29, 2011 11:35 am
I'm also experimenting such issue on Linux systems.
sundog_ak
#6 Post by sundog_ak » Sun May 29, 2011 9:49 pm
For comparison, here is a text file dump from MediaInfo from the same movie, same hardware, etc. First is from Version 1.6.8
Misery 168.txt
and the other is 1.6.9
Misery 169.txt
#7 Post by SamuriHL » Sun May 29, 2011 9:54 pm
Same issue here. I remuxed with mkvmerge and it fixed it. Hoping this gets fixed soon.
#8 Post by mike admin » Sun May 29, 2011 10:46 pm
Confirmed as fatal bug in 1.6.9 . The new version is available, MKV files generated by 1.6.9 are broken unless processed with mkvmerge.
Locked
