can't delete files
peteyx
can't delete files
#1 Post by peteyx » Sat May 28, 2011 8:38 pm
I used the current version of MakeMKV on my Win7 Ultimate PC to rip a Blu-ray (SALT) DVD. It saved the 30+ files in DIVX format. Whenever I click on any of the files, Windows Explorer quits. I tried opening DivX, then opening the files and DivX quits.
Any clue how I can delete these files?
Navvie
Re: can't delete files
#2 Post by Navvie » Sat May 28, 2011 9:17 pm
MakeMKV almost certainly didn't save anything in divx format.
I suspect you have .mkv file extension associated with the divx player, try viewing the files in VLC or MPC-HC instead. (I also have my suspicions that this is somehow related to explorer crashing. I can't be much more help, VLC and WinXP user.)
I can't answer regarding not deleting, but I have seen discussion here recently about an addition space added to the end of directory names that caused some problems.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK x2
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
peteyx
#3 Post by peteyx » Sun May 29, 2011 1:03 am
I wound up deleting them by command line. Even safe mode didn't do it.
Icetrips
#4 Post by Icetrips » Mon Jun 06, 2011 5:06 pm
What is your OS ?
Windows XP
Scandisk should fix it.
Windows 7
Run cmd as Administrator
takeown /f file_name /d y
icacls file_name /grant administrators:F
and delete your file.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
JimCameron
#5 Post by JimCameron » Tue Sep 11, 2012 11:05 am
Long Path Tool helped me in this situation. http://DeleteLongFile.com
