I read this viewtopic.php?f=8&t=15355
Here is the log.
https://pastes.io/xjcrf0xfxm
There is no movie title gets opened.
So makemkv does or does not support BD+?
[Solved]BD+ The Day After Tomorrow
HittiittitiH
HittiittitiH
Re: BD+ The Day After Tomorrow
Solved.
I checked create a dump file in preferences and opened disc again and it got opened, shu that scared me.
I don't know if reopening again did it or check create dump file
Kaubeu99
Re: [Solved]BD+ The Day After Tomorrow
Hello.
I have tried many times to copy my "The Day after Tomorrow" Bluray. Unfortunately, only opening the disc works. At some point the creation of the MKV stops.
Do you have an idea how I can create an MKV or an ISO from the Bluray?
Greetings Kaubeu
I created this text using Google Translate.
Greetings Kaubeu
