Blade Runner 2049 reports bad sectors BUT VLC can transcode the entire file
Jman9980
Post by Jman9980 »
Forgive if I am posting in the wrong place or if I am posting on a topic already sorted.
Hello, So I bought a pre flashed drive and wanted to try ripping a disk. I put in Blade runner 2045 and it ran for a bit and then reported a file error.
MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
File 00002.mpls was added as title #0
File 00009.mpls was added as title #1
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00033.mpls was added as title #2
Title 00020.mpls is equal to title 00033.mpls and was skipped
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Blade Runner 2049 using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:flac.mmcp.xml'
AV synchronization issues were found in file 'C:/Video/Blade Runner 2049/Blade Runner 2049_t02.mkv' (title #3)
AV sync issue in stream 5 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 6 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 7 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 5,6,7 at 0:00:00 with duration of 9ms : encountered overlapping frame, audio skew is +9ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '4965593088'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4965593088'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '5003476992'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '5003476992'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '5003931648'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '5003931648'
Failed to save title 2 to file C:/Video/Blade Runner 2049/Blade Runner 2049_t02.mkv
Encountered 49 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Per what I found on the form, I tried doing a file copy to hard disk and received a similar error. According to the artical on the form, I have a faulty disk.
Then to add some fun, I tossed the file at VLC Player Convert/Save and it ripped the entire file with no errors. Mind you it looked like trash but it ripped.
That raises the question of, If the disk is bad, How did VLC rip the file, I am suspecting a copy right trick like they did back in the day for Commodore 64 protection.
Any ideas? I am not really worried about Blade Runner 2049, It was just the only UHD I have handy for testing the new drive. and getting familiar with MakeMkv
- MakeMkv reports file errors. "Drive sounded ANGRY"
- Windows file copy reports errors on the disk when doing a file copy to local disk. "Drive sounded ANGRY"
- VLC player can trans code the entire file no errors. "Drive was silent. Quite happy doing its drive things"
Attached is a snip of what MakeMkv reports for the drive i am testing.
Re: Blade Runner 2049 reports bad sectors BUT VLC can transcode the entire file
What are you using for a drive? Does the offset change on different runs?
Jman9980
Post by Jman9980 »
My drive info from MakeMkv.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLBL75J3148
Bus encryption flags: 1F
Highest AACS version: 66
Firmware version: 3.10
Disc Information
Label: Blade_Runner_2049
Timestamp: 2017-11-29 11:24:04
Protection: AACS2.0/C v61
Data capacity: 83.57 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
I notice that VLC player was able to trans-code this same disk so that is interesting.
When MakeMkv attempts, the drive sounds ANGRY. When VLC attempted, the drive was silent. no head rattle.
The log from VLC looked like this. I used the profile Fast 1080P
main info: playlist is empty
libbluray info: First play: 1, Top menu: 0 HDMV Titles: 18, BD-J Titles: 2, Other: 2
libbluray info: Adding ES 4113 select 1
libbluray info: Adding ES 4352 select 1
libbluray info: Adding ES 4353 select 0
libbluray info: Adding ES 4354 select 0
libbluray info: Adding ES 4355 select 0
libbluray info: Adding ES 4356 select 0
libbluray info: Adding ES 4768 select 0
libbluray info: Adding ES 4769 select 0
libbluray info: Adding ES 4770 select 0
libbluray info: Adding ES 4771 select 0
libbluray info: Adding ES 4772 select 0
mlp info: MLP channels: 8 samplerate: 48000
x264 info: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x264 info: profile High, level 4.0
x264 info: final ratefactor: 21.06
chain error: Too high level of recursion (3)
main error: Failed to create video converter
d3d11va error: FindVideoServiceConversion failed
dxva2 error: FindVideoServiceConversion failed
x264 info: using SAR=1/1
avcodec info: Using D3D11VA (NVIDIA GeForce GTX 980 Ti, vendor 10de(NVIDIA), device 17c8, revision a1) for hardware decoding
avcodec error: more than 5 seconds of late video -> dropping frame (computer too slow ?)
The last message repeated for like ever so I did not post the entire log.
Jman9980
Post by Jman9980 »
In reply to the question, "Does the offset change on different runs?"
I will run a couple of runs and see.
Jman9980
Post by Jman9980 »
Well, Your support is fast. This is my first UHD.
I have done nothing, Not even reboot since my last attempt. I have to think that it downloaded a new hash
"Downloading latest HK to C:\Users\Dad/.MakeMKV ..."
What ever you did, If anything it worked. :) Now I feel like i need to donate to the cause.
Saving 3 titles into directory C:/Video/Blade Runner 2049
AV sync issue in stream 9 at 0:00:00 : Forced subtitles track #9 turned out to be empty and was removed from output file
AV sync issue in stream 11 at 0:00:00 : Forced subtitles track #11 turned out to be empty and was removed from output file
AV sync issue in stream 13 at 0:00:00 : Forced subtitles track #13 turned out to be empty and was removed from output file
AV sync issue in stream 15 at 0:00:00 : Forced subtitles track #15 turned out to be empty and was removed from output file
AV sync issue in stream 17 at 0:00:00 : Forced subtitles track #17 turned out to be empty and was removed from output file
3 titles saved
Now then Can I ask the best setting in Handbrake for movies like this?
Jman9980
Post by Jman9980 »
Ok so it copied the files, but now Handbrake tells me it is copy protected.
I need to sort that out.
Jman9980
Post by Jman9980 »
Im all good.
I want to thank you for your time on this.
MakeMkv really is a quality product.
The reason for asking if the error moved is that some external drives run out of power when they start spinning full speed (late in the run), which is what looked like was happening in your first run. The sector where things fail usually moves around when that happens. If it doesn't move... then it's likely the disk itself has a bad spot on it, and cleaning fixes that (usually).
VLC won't normally run the drive at full speed, so it didn't get that error, but it doesn't decrypt the file, either.
There ARE ways to slow MakeMKV down... I used to make it write to a USB drive to slow it down a long time ago. There is an official way to do it for non-UHD disks, too. But it's best to make sure your drive can make "full speed" by giving it full power.
