unable to save mkv of The A-Team
corvin
report as below, any ideas?
Saving 1 titles into directory /Volumes/media-2/Blu-Ray Movies/The_A-Team
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00331.m2ts' at offset '5111808'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00331.m2ts' at offset '9830400'
Failed to save title 1 to file /Volumes/media-2/Blu-Ray Movies/The_A-Team/title01.mkv
0 titles saved, 1 failed
Re: unable to save mkv of The A-Team
Looks like physically damaged disc. Please try making full disc backup and see if any errors show up.corvin wrote:report as below, any ideas?
corvin
back-up works fine
Backing up disc into folder "/Volumes/media-1/Blu-Ray Movies/backup/A_TEAM_F3"
Backup done
Backup done
Then you should be able to open a backup copy with MakeMKV ( Select File menu, then Open ) and convert from there. Looks like you had a glitch reading the file.corvin wrote:back-up works fine
Backup done
corvin
Ok thankls that seemed to work.
I did try converting from disk about 5 times???
I did see a number of currupt entries though, i have posted them below if you are interested in brousing them. Sorry i'm not sure if i could have just added them as an attechment
Opening files on harddrive at /Volumes/media-2/Blu-Ray Movies/backup/A_TEAM_F3/
Downloading latest SVQ(s) to /Volumes/media-1/Blu-Ray Movies ...
Loaded 14 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
BD+ code processed, got 1 FUT(s) for 57 clip(s)
File 00381.mpls was added as title #0
File 00801.mpls was added as title #1
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00802.mpls was added as title #2
Title #00020.mpls has length of 110 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
File 00800.mpls was added as title #3
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title #00890.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00377.m2ts has length of 91 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00303.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00357.m2ts has length of 79 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00387.m2ts has length of 368 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00394.m2ts has length of 99 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00309.m2ts has length of 85 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00335.m2ts has length of 51 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00011.m2ts has length of 9 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00316.m2ts has length of 120 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00333.m2ts has length of 142 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00328.m2ts has length of 80 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00891.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00350.m2ts has length of 367 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00347.m2ts has length of 103 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00379.m2ts has length of 439 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00334.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00355.m2ts has length of 114 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00319.m2ts has length of 164 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00390.m2ts has length of 72 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00338.m2ts has length of 475 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00327.m2ts has length of 368 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00358.m2ts has length of 186 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00359.m2ts has length of 248 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00360.m2ts has length of 209 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00311.m2ts has length of 115 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00345.m2ts has length of 209 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00393.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00356.m2ts has length of 164 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00336.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00378.m2ts has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00324.m2ts has length of 329 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00388.m2ts has length of 371 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00380.m2ts has length of 96 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00301.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00342.m2ts has length of 103 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00386.m2ts has length of 301 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00306.m2ts has length of 200 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00313.m2ts has length of 371 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00352.m2ts has length of 74 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00383.m2ts has length of 198 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00385.m2ts has length of 275 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00321.m2ts has length of 293 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00353.m2ts has length of 58 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00889.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00392.m2ts has length of 100 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00384.m2ts has length of 246 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00391.m2ts has length of 108 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00389.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00331.m2ts has length of 186 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00354.m2ts has length of 85 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/media-1/Blu-Ray Movies/The_A-Team
The source file '/BDMV/STREAM/00341.m2ts' is corrupt or invalid at offset 549322752, attempting to work around
Forced subtitles track #4 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
1 titles saved
1 titles saved
Hi. Please go to MakeMKV preferences, select "BD+" tab, make sure that "BD+ directory" is set and enable "always save BD+ dump". Then open this disc again, and send produced BD+ dump file to support@makemkv.com .
Thanks.
Thanks.
corvin wrote:Ok thankls that seemed to work.
I did see a number of currupt entries though, i have posted them below if you are interested in brousing them. Sorry i'm not sure if i could have just added them as an attechment![]()
1 titles saved
setarip_old
" A_TEAM_F3 " is indicative of a torrent download, which cannot be discussed at the MakeMKV Forums...
corvin
Hi Mike,
Below is the dump, however this time the mkv worked??? I had tried it many times prior, the only difference i know of is the dump file and i saved it to an alternate drive as the 1st one was full.
Oh and setarip_old u r wrong!!!
dump_The_A-Team_3A01E1251AE79C4F.tgz
reebok
I am having virtually the exact same problem with this movie. I'm not getting the corrupt errors like the original poster, but I am getting problems such as Error 'Scsi error - MEDIUM ERROR:1090'. maybe it's a bad disc, but it seemed odd we have the same problem.
reebok
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00311.m2ts' at offset '407562240'
This is physical disc error.reebok wrote:Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00311.m2ts' at offset '407562240'
reebok
is there a way to force skip a certain track? it fails on 00311.m2ts every time, which is only 1min 55sec long according to bdinfo. I would rather just rip it without it if I can. thanks.
nobix
Some of my blu-ray discs have physical damage. I am okay to lose a couple of seconds video data in a track. Not sure if makeMKV can ignore the disc error to continue.reebok wrote:is there a way to force skip a certain track? it fails on 00311.m2ts every time, which is only 1min 55sec long according to bdinfo. I would rather just rip it without it if I can. thanks.
It will try to do so, but if too much data is damaged then it will ultimately fail.nobix wrote:Some of my blu-ray discs have physical damage. I am okay to lose a couple of seconds video data in a track. Not sure if makeMKV can ignore the disc error to continue.
marky9074
Sorry to resurrect this thread. I'm getting the same with the A-Team (only played once - no damage). When doing a full disc backup I get the following:
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00338.m2ts' at offset '1429039104'
