New Disc Operation Fortune
willi3
Post by willi3 »
New UHD Dis Operation Fortune will not open. Log has been sent.
Danke
Harri
Re: New Disc Operation Fortune
Post by Harri »
metoo
Thank you very much in advance
Harri
willi3
Post by willi3 »
Geneo
Post by Geneo »
I have the same problem
jarrod2750
Post by jarrod2750 »
Same here
mikela
Post by mikela »
Has anyone gotten this to work?
makememe
Post by makememe »
I submitted Walmart non-steel book two days ago.
Thank you, Mike.
mikela
Post by mikela »
I'm also having the problem. I sent in a dump file and log file.
KENSAI
Post by KENSAI »
Thanks, will submit the file. Reboot didn't work after all for this disc.
Post by SamuriHL »
Email the dump to svq@makemkv.com
KENSAI
Post by KENSAI »
Same issue here. I submitted the dump a bit over a month ago, tried it again today, still can't open the disc.
What's the typical timeline to get the disc added? The first log was sent in April, so we're on month five. Is that normal, or is there perhaps something wrong, like not enough data to open the disc?
KENSAI
Post by KENSAI »
So it's been seven months since this thread was opened and someone submitted the first dump file.
I bought this disc three months ago and still can't watch it. I've emailed svq@ three times without any reply. I tried ripping it again today, same error as always.
Is there anything we can do? Does anyone know someone on the MakeMKV team that might be able to help?
No one has posted what the name of their dump file is, so we can't know if you're all submitting the same dump or not. Also, no one has posted if they've had any success.
In your case, KENSAI, none of that should matter. Assuming you've emailed the .tgz dump file to svq@makemkv.com and that your emails haven't bounced or failed for some reason, then the giant key generating machine in the sky should have your dump file.
Are you sure your system is able to download keys? Are you getting the "Automatic HK downloading is disabled or failed." message?
KENSAI
Post by KENSAI »
Indeed, it turned out the problem was on my side: earlier this year I'd used my Firewalla (a hardware firewall) to block all incoming/outgoing IP traffic to China. When I tried ripping two more 4K discs today, they failed, so I put my machine into a state where the Firewalla wouldn't block anything. And, of course, it worked. I can now rip Operation Fortune, and the problem was on my side all along. :?
While I do wish there was a more clear "Can't reach server" type message, ultimately this is all on me.
