I doubt it matters. The FTV Stick 4K Max also got CM v4.0 support through firmware upgrades.
AFAIK devices that support Dolby Vision in Android always bundle Dolby's proprietary library, and I guess it's not always kept up to date.
quietvoid
FonduemangVI
Right will do once I am actually allowed to send PMs hahaRESET_9999 wrote: Tue Apr 18, 2023 12:43 pmhi, just pm meFonduemangVI wrote: Tue Apr 18, 2023 12:17 pm Hey RESET_9999 what is the best way to contact you? I don't see you around on the IRCs I frequent.
3 more posts and you will be able to (I think)FonduemangVI wrote: Wed Apr 19, 2023 3:07 am Right will do once I am actually allowed to send PMs haha
lexyz
I'd like to notice that "RPU p8.1 L1.L2_cmv29.Edited.3696" test triggers picture adjustments for all trims except probably ms_weight on ShieldTV+Bravia in LLDV mode.
Not sure what ms_weight should change and where to look.
Other versions of L1.L2_cmv29 doesn't work on ShieldTV in LLDv properly.
L11 remains the same, without adjustments.
damn this is so strange... So 4000nits content works but not 1000nits.
chrisdm
Hey mate, question. Can your script inject DV metadata from a DV release into an HDR10+ release, is that possible? Or does HDR10+ have to be converted to DV?RESET_9999 wrote: Thu Apr 20, 2023 11:02 am damn this is so strange... So 4000nits content works but not 1000nits.
yes sure.chrisdm wrote: Thu Apr 20, 2023 6:05 pm Hey mate, question. Can your script inject DV metadata from a DV release into an HDR10+ release, is that possible?
The script can also be configured to remove HDR10plus while injecting in case someone use a device that don't like when the video has two dynamic metadata..
Big-rome
Reset, after baking the BL and EL (with DoViBaker, I presume), what are the steps to get the original RPU converted to P8?
Did you succeed with the conversion to P8?
Finally tested LLDV on the Shield(developer mode) + C2 and got some interesting results...lexyz wrote: Thu Apr 20, 2023 4:36 am RESET_9999
LLDV (player-led)
L2/L1 works fine
even L2 chroma weight works!!!!
CMV 4.0 (L8) no longer works(L2 works) but only for profile 8.1... strangely p8.4 works...
Multi-pattern performs much better in the colorspace conversion and clipping but blue still has banding (as noted before)
red push: no change, as bad as TV-LED
TV-LED
L1/L2 works fine except L2 chroma weight which has no effect
CMV4.0 works fine
Multi pattern has a lot of colorspace conversion/clipping issues.
So I think it's actually better to force LLDV on the Shield.
dom61
@RESET_9999
Sorry for the stupid question.
When I perform clip or file analysis in DaVinci, which color space do I choose P3 or BT 2020?
Having set the color space:
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
My PC Ryzen 7950X
Everything you need is in the tutorial video and BTW, that is not how your resolve project should be set.
or just import my resolve DV preset:
https://drive.google.com/file/d/10lYNFS ... share_link
dom61
Thank you
My PC Ryzen 7950X
My PC Ryzen 7950X
aboulfad
Can you please explain what Multi.Pattern.1000nits P8 DV HDR10-newTVs.mp4 color space conversion box is supposed to show ?RESET_9999 wrote: Sat Apr 22, 2023 2:59 pm Multi-pattern performs much better in the colorspace conversion and clipping but blue still has banding (as noted before)
Using ATV4k->Infuse (P8 to P5)->LG OLED E7, I see 2 rows green and red, with flashing squares inside that don't extend to the end, and the red row has a solid red patch roughly 1/3 the row size on the right. Is there an overall description of that test pattern somewhere ? Merci : )
explanation: https://spearsandmunsil.com/portfolio-i ... r-space-3/aboulfad wrote: Sun Apr 23, 2023 9:19 pmCan you please explain what Multi.Pattern.1000nits P8 DV HDR10-newTVs.mp4 color space conversion box is supposed to show ?RESET_9999 wrote: Sat Apr 22, 2023 2:59 pm Multi-pattern performs much better in the colorspace conversion and clipping but blue still has banding (as noted before)
how it looks on multiple devices: https://slow.pics/c/BgatG8CS
aboulfad
wowsa, merci beaucoup ; ) I guess buying the UHD4K S&M disc once it's available is a must. I will read the super long page and learn. I take it out of the 6 images, the x800 should be the reference ? is the x800 a camera shot of the C2 or C8 ?RESET_9999 wrote: Sun Apr 23, 2023 9:53 pm explanation: https://spearsandmunsil.com/portfolio-i ... r-space-3/
