betali
Re: Pioneer firmware update February 2023
Post by betali » Wed Apr 19, 2023 4:11 am
How do I enable my pioneer drive for Libredrive?
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-213U
Revision: 1.03
Serial number: BBDL000000WL
Firmware date: 2022-07-26
Highest AACS version: 76
Firmware version: ID58
TiKiMaN1
Post by TiKiMaN1 » Sat Apr 22, 2023 4:23 pm
Looking forward to any updates. I have been wondering if I should just buy a new drive, but holding out hope that a solution can be found. :mrgreen:
Post by Billycar11 » Sat Apr 22, 2023 5:31 pm
TiKiMaN1 wrote: Sat Apr 22, 2023 4:23 pm Looking forward to any updates. I have been wondering if I should just buy a new drive, but holding out hope that a solution can be found. :mrgreen:
What drive do you have post the makemkv drive info
Post by dcoke22 » Sun Apr 23, 2023 1:46 am
Billycar11 wrote: Sat Apr 22, 2023 5:31 pm What drive do you have post the makemkv drive info
viewtopic.php?f=19&t=30383&p=134716#p134716
TiKiMaN1 wrote: Sat Apr 08, 2023 3:50 pmI have a Pioneer BDR-212UBK and it was working awesome for ripping my UHD discs for almost a year. Unfortunately, just recently I stumbled into an issue with a couple of discs so I decided to "upgrade" :shock: to firmware 1.04 and like this forum is discussing it disabled the ability to rip UHD. Really looking forward to any type of solution. I'm grateful that my drive still rips DVD and Blu-ray, but I can't wait to have the ability to rip UHD to be restored to my drive. Thanks to everyone that is working on this, and I hope that a fix will be created soon.
TiKiMaN1
Post by TiKiMaN1 » Sun Apr 23, 2023 4:33 am
dcoke22 wrote: Sun Apr 23, 2023 1:46 am
I was just about to post this.Thanks for replying. Yes I have a I have a Pioneer BDR-212UBK.
TiKiMaN1
Post by TiKiMaN1 » Sun Apr 23, 2023 4:35 am
OS device name: E:
Product: BD-RW BDR-212U
Revision: 1.04
Serial number: AGDL002432WL
Firmware date: 2022-12-20
Highest AACS version: 77
Drive platform: Pioneer RS8F01
rafaelsmith
Post by rafaelsmith » Wed May 03, 2023 7:00 pm
I recently got a Pioneer BDR-XD08U with f/w 1.0 which thus far appears to be working fine.
I just wanted to make sure that I should refrain from updating the f/w.
Also, I am not sure but I assume f/w updates are manual? or do i need to do something to prevent it from updateing?
Thanks,
Post by dcoke22 » Wed May 03, 2023 8:27 pm
rafaelsmith wrote: Wed May 03, 2023 7:00 pm I recently got a Pioneer BDR-XD08U with f/w 1.0 which thus far appears to be working fine.
Don't update the firmware, just leave it alone.
Generally speaking, firmware updates are a manual process, so you don't have to do anything to prevent it.
Post by Coopervid » Wed May 03, 2023 9:50 pm
Newer doesn't mean better as you see. We had that before with LG firmware "upgrades". Just don't do this w/o knowing what you do.
Konten
Post by Konten » Sat May 13, 2023 7:39 am
Hi guys,
Has anyone got any thoughts on when a downgrade or other solution might become available yet?
Thank you!!
saywhen58
Post by saywhen58 » Sat May 13, 2023 3:54 pm
Looking forward to a future fix!
saywhen58 wrote: Sat May 13, 2023 2:16 pm Drive Information
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: CBDL000194UC
Firmware date: 2022-12-12
Firmware version: ID29
Krawk
Post by Krawk » Fri May 26, 2023 9:46 pm
Just received a shiny new BDR-S13UBK, manufactured October 2022. W00t.
GDMFS0B
Post by GDMFS0B » Fri Jun 02, 2023 4:10 am
I’ve got a Pioneer BDR-212V on hand and 2 BRXL-PT6U2VB-US’s on the way. Is the 212V patchable now?
edit: screen shot from MakeMKV with the 212V plugged in. After attempting to read, I end up with "No Disc Inserted".
domvar
Post by domvar » Thu Jun 08, 2023 1:24 pm
I'm a bit lost in these replies is there a solution to the 1.04 firmware issue yet ether by flashing or other? No problem if not but the thread seems to have drifted away form that.
Post by Billycar11 » Thu Jun 08, 2023 1:26 pm
domvar wrote: Thu Jun 08, 2023 1:24 pm I'm a bit lost in these replies is there a solution to the 1.04 firmware issue yet ether by flashing or other? No problem if not but the thread seems to have drifted away form that.
No solution yet
