quietvoid
Post by quietvoid » Tue Apr 18, 2023 5:47 pm
I doubt it matters. The FTV Stick 4K Max also got CM v4.0 support through firmware upgrades.
AFAIK devices that support Dolby Vision in Android always bundle Dolby's proprietary library, and I guess it's not always kept up to date.
FonduemangVI
Post by FonduemangVI » Wed Apr 19, 2023 3:07 am
RESET_9999 wrote: Tue Apr 18, 2023 12:43 pm
FonduemangVI wrote: Tue Apr 18, 2023 12:17 pm Hey RESET_9999 what is the best way to contact you? I don't see you around on the IRCs I frequent.
hi, just pm me
Right will do once I am actually allowed to send PMs haha
Post by RESET_9999 » Wed Apr 19, 2023 2:04 pm
FonduemangVI wrote: Wed Apr 19, 2023 3:07 am Right will do once I am actually allowed to send PMs haha
3 more posts and you will be able to (I think) :)
lexyz
Post by lexyz » Thu Apr 20, 2023 4:36 am
I'd like to notice that "RPU p8.1 L1.L2_cmv29.Edited.3696" test triggers picture adjustments for all trims except probably ms_weight on ShieldTV+Bravia in LLDV mode.
Not sure what ms_weight should change and where to look.
Other versions of L1.L2_cmv29 doesn't work on ShieldTV in LLDv properly.
L11 remains the same, without adjustments.
Post by RESET_9999 » Thu Apr 20, 2023 11:02 am
damn this is so strange... So 4000nits content works but not 1000nits.
chrisdm
Post by chrisdm » Thu Apr 20, 2023 6:05 pm
RESET_9999 wrote: Thu Apr 20, 2023 11:02 am damn this is so strange... So 4000nits content works but not 1000nits.
Hey mate, question. Can your script inject DV metadata from a DV release into an HDR10+ release, is that possible? Or does HDR10+ have to be converted to DV?
Post by RESET_9999 » Thu Apr 20, 2023 6:38 pm
chrisdm wrote: Thu Apr 20, 2023 6:05 pm Hey mate, question. Can your script inject DV metadata from a DV release into an HDR10+ release, is that possible?
yes sure.
The script can also be configured to remove HDR10plus while injecting in case someone use a device that don't like when the video has two dynamic metadata..
Big-rome
Post by Big-rome » Fri Apr 21, 2023 4:30 pm
danbez wrote: Sat Apr 15, 2023 7:55 pm
Reset, after baking the BL and EL (with DoViBaker, I presume), what are the steps to get the original RPU converted to P8?
Did you succeed with the conversion to P8?
Post by RESET_9999 » Sat Apr 22, 2023 2:59 pm
lexyz wrote: Thu Apr 20, 2023 4:36 am RESET_9999
Finally tested LLDV on the Shield(developer mode) + C2 and got some interesting results...
LLDV (player-led)
L2/L1 works fine
even L2 chroma weight works!!!!
CMV 4.0 (L8) no longer works(L2 works) but only for profile 8.1... strangely p8.4 works...
Multi-pattern performs much better in the colorspace conversion and clipping but blue still has banding (as noted before)
red push: no change, as bad as TV-LED
TV-LED
L1/L2 works fine except L2 chroma weight which has no effect
CMV4.0 works fine
Multi pattern has a lot of colorspace conversion/clipping issues.
So I think it's actually better to force LLDV on the Shield.
dom61
Post by dom61 » Sat Apr 22, 2023 9:22 pm
@RESET_9999
Sorry for the stupid question.
When I perform clip or file analysis in DaVinci, which color space do I choose P3 or BT 2020?
Having set the color space:
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
Post by RESET_9999 » Sat Apr 22, 2023 10:19 pm
Everything you need is in the tutorial video and BTW, that is not how your resolve project should be set.
or just import my resolve DV preset:
https://drive.google.com/file/d/10lYNFS ... share_link
dom61
Post by dom61 » Sat Apr 22, 2023 10:30 pm
Thank you
My PC Ryzen 7950X
aboulfad
Post by aboulfad » Sun Apr 23, 2023 9:19 pm
RESET_9999 wrote: Sat Apr 22, 2023 2:59 pm Multi-pattern performs much better in the colorspace conversion and clipping but blue still has banding (as noted before)
Can you please explain what Multi.Pattern.1000nits P8 DV HDR10-newTVs.mp4 color space conversion box is supposed to show ?
Using ATV4k->Infuse (P8 to P5)->LG OLED E7, I see 2 rows green and red, with flashing squares inside that don't extend to the end, and the red row has a solid red patch roughly 1/3 the row size on the right. Is there an overall description of that test pattern somewhere ? Merci : )
Post by RESET_9999 » Sun Apr 23, 2023 9:53 pm
aboulfad wrote: Sun Apr 23, 2023 9:19 pm
explanation: https://spearsandmunsil.com/portfolio-i ... r-space-3/
how it looks on multiple devices: https://slow.pics/c/BgatG8CS
aboulfad
Post by aboulfad » Sun Apr 23, 2023 10:54 pm
RESET_9999 wrote: Sun Apr 23, 2023 9:53 pm explanation: https://spearsandmunsil.com/portfolio-i ... r-space-3/
wowsa, merci beaucoup ; ) I guess buying the UHD4K S&M disc once it's available is a must. I will read the super long page and learn. I take it out of the 6 images, the x800 should be the reference ? is the x800 a camera shot of the C2 or C8 ?
