anyone tried the Amazon Basics External Ultra HD Blu-ray 6X burner?
stanice
#1 Post by stanice » Sun Apr 16, 2023 8:32 am
Found this $99 Amazon Basics 4K blu-ray drive in my new drive search, but went with a known brand since few reviews and no MakeMKV compatibility info here.
Just curious has anyone tried it?
$99 US, slim tray loading, Micro USB, nice looking dark brushed silver on black, comes with ye olde PowerDVD / Cyberlink suite. Model number BP62N.
Re: anyone tried the Amazon Basics External Ultra HD Blu-ray 6X burner?
#2 Post by Woodstock » Sun Apr 16, 2023 1:21 pm
Amazon does not manufacture drives, so you need to know who makes it. One thing to consider is that a third-party assembler can market multiple (basic) drives in the same packaging, so you might get different manufacturers at different times.
#3 Post by Billycar11 » Sun Apr 16, 2023 5:06 pm
Looks like a bp60nb10 rebrand
stanice
#4 Post by stanice » Sun Apr 16, 2023 7:03 pm
Interesting, if it is an LG BP60NB10 drive inside, doing a little searching it sounds like that would be a good price, it would be one of the fastest slim drives, but probably would need to have its firmware flashed to downgrade to be LibreDrive compatible, is that about right?
#5 Post by Billycar11 » Sun Apr 16, 2023 11:40 pm
but not really you can get a BP/WP50NB40 for $80-$90 and its the same drive except missing the aacs2 chip
but that dont matter for makemkv ripping 4k discs once flashed.
#6 Post by MartyMcNuts » Mon Apr 17, 2023 12:05 am
Yeah, I'd say so as the model says it is a BP62N. It looks exactly like a BP60NB10 (NB12).
TheMKVMaker
#7 Post by TheMKVMaker » Mon Apr 17, 2023 2:30 pm
man where can I get one of those USB C cables that has two USBs on the other end for more power?
Dennis in Venice
#8 Post by Dennis in Venice » Tue Apr 18, 2023 5:54 pm
Best Buy has the BP50NB40 NB52 external slim on sale now for $65 ... I just got done flashing it --- works great
Cortexgaming101
#9 Post by Cortexgaming101 » Sat Feb 03, 2024 6:51 pm
They apparently to now be out of stock. However I bought one the other day and successfully flashed it after looking at this forum.
stanice
#10 Post by stanice » Fri Aug 02, 2024 11:00 pm
I bought one here not too long ago. The one I bought is Mini-USB on one end, and two USB-A on the other end. Most older external optical drives are Mini-USB. But this Amazon model claims to be Micro-USB, I'm not sure about that one.
But you asked about USB-C, actual USB-C should be able to provide enough power over a single cable. The Pioneer USB-C drive I have works great with a Mac over one USB-C cable.
On that note, another great cable I got from that same vendor, is a Mini-USB to USB-C cable for use with an older OWC external blu-ray enclosure. I was hoping that one USB-C port would be able to supply enough power for the drive with a single cable, and it does!
