Windows VM will not recognize flashed drive
greatestguru
Post by greatestguru »
I currently own two WH14NS40. They are attached to my Unraid server via sata cables. The firmware flash is WH16NS60-1.02-MK from the Ultimate UHD Drives Flashing Guide Updated 2023. Device manager will not allow me to use them. What steps can I take to make this work again?
Thanks,
Guru
Re: Windows VM will not recognize flashed drive
work again? you had it working before?
you might need to pass through the whole sata controller
