danbez
#8176 Post by danbez » Sat Apr 15, 2023 7:55 pm
RESET_9999 wrote:
Sat Apr 15, 2023 3:41 pm
no, I mean the EL and BL are re-encoded together which results in a new BL that will work properly with the original RPU(converted to P8).
like this...
BL+EL baked + original rpu converted to P8:
https://drive.google.com/file/d/18OEcZP ... share_link
Reset, after baking the BL and EL (with DoViBaker, I presume), what are the steps to get the original RPU converted to P8?
#8177 Post by RESET_9999 » Sat Apr 15, 2023 9:16 pm
dovi_tool.exe -m 2 or with the script(1-1) in my signature
danbez
#8178 Post by danbez » Sat Apr 15, 2023 11:57 pm
DMDreview
#8179 Post by DMDreview » Sun Apr 16, 2023 4:35 pm
Hi, need help, trying to figure out the source of the red push problem on the Shield tv.
I need to do a DV test, but only with L1, remove the rest, how to do it right. Is there some kind of utility?
#8180 Post by RESET_9999 » Sun Apr 16, 2023 6:20 pm
it's not a metadata problem and anyway, the bluray Doctor Sleep only has a 100nits trim pass which is not used obviously in DV playback.
if you still want to try, just generate dv with madvr and this will get you metadata with just L1.
perfect sample to test it: https://drive.google.com/file/d/1PUwrol ... share_link
also very noticeable on quietvoid L11 test file: https://drive.google.com/file/d/1OwS0Te ... share_link
in fact, as soon as there's white, it's noticeable.
skull88
#8181 Post by skull88 » Sun Apr 16, 2023 11:56 pm
Unless you're an Nvidia dev or have means of reaching out to them, this problem will likely never get resolved. But good luck!
DMDreview
#8182 Post by DMDreview » Mon Apr 17, 2023 8:40 am
With L2 solved, the bug remains, in fact, I need a file for the test, which will be played as a DV. But it will not apply the dynamic data, even L1, or they will be prescribed so as not to interfere with the current characteristics of the film. Is this possible to do?
I want to understand if the dynamic data is to blame, or if the DV processing itself is defective.
DMDreview
#8183 Post by DMDreview » Mon Apr 17, 2023 8:45 am
Well I have already managed to find and prove to Nvidia a problem that has not been solved for 3 years and they fixed it. So nothing is impossible. Everything can be solved, I already have an idea about the source of the problem, but I want to go from the other side and check the alternatives for the origin of the problem.
lexyz
#8184 Post by lexyz » Mon Apr 17, 2023 11:17 am
deadchip12 wrote:
Thu Apr 13, 2023 12:56 am
Are sony bluray players still the ultimate devices to get for playing dolby vision remuxes?
True for TV-led mode only
#8185 Post by RESET_9999 » Mon Apr 17, 2023 1:21 pm
did you try again with the latest version (useless cmv4.0 metadata removed)? Maybe it was causing issues ?
https://drive.google.com/file/d/18PLzRP ... share_link
and the Eagle beak L2 test with original metadata removed 1 by 1 ?
https://drive.google.com/file/d/1qdHux6 ... share_link
#8186 Post by RESET_9999 » Mon Apr 17, 2023 4:30 pm
I don't know I never tried to make a sample without L1 but you can try to generate an rpu without it. Here's a json I use to test the metadata, you can try to modify it .
The problem in my opinion is most likely something the Shield does wrong outside of the Dolby black box engine since its the only device with this particular problem.
dovi_tool.exe generate -j json -o RPU_generated.bin
cmv2.9 json template (each block has 120frame of metadata:
    "cm_version": "V29",
    "profile": "8.1",
    "long_play_mode": false,
	"source_min_pq": 7,
    "source_max_pq": 3079,
    "level5": {
        "active_area_left_offset": 0,
        "active_area_top_offset": 0,
    "level6": {
        "max_content_light_level": 0,
        "max_frame_average_light_level": 0
    "shots": [
            "start": 0,
            "duration": 120,
            "metadata_blocks": [
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2081,
                        "avg_pq": 1229
                    "Level2": {
                        "target_max_pq": 2081,
                        "trim_slope": 2048,
                        "trim_offset": 2048,
                        "trim_power": 2048,
                        "trim_chroma_weight": 2048,
                        "trim_saturation_gain": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "target_max_pq": 2851,
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "target_max_pq": 3079,
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 120,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2281,
                        "avg_pq": 1429
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 240,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2581,
                        "avg_pq": 1629
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 360,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2781,
                        "avg_pq": 1829
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 480,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3079,
                        "avg_pq": 2029
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 600,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3200,
                        "avg_pq": 2229
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 720,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
						"max_pq": 3400,
                        "avg_pq": 2429
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 840,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3696,
                        "avg_pq": 2629
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 960,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 4095,
                        "avg_pq": 2829
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
cmv4.0 json template:
    "cm_version": "V40",
    "profile": "8.1",
	"source_min_pq": 62,
    "level5": {
        "active_area_top_offset": 276,
        "active_area_bottom_offset": 276
    "level6": {
        "min_display_mastering_luminance": 50,
    "shots": [
            "start": 0,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2423,
                        "trim_offset": 2149,
                        "trim_power": 2934,
                        "trim_saturation_gain": 1632,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2113,
                        "trim_offset": 2050,
                        "trim_power": 1957,
                        "trim_saturation_gain": 2004,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2226,
                        "trim_offset": 2044,
                        "trim_power": 1753,
                        "ms_weight": 2048
                    "Level3": {
                      "min_pq_offset": 2048,
                      "max_pq_offset": 2048,
                      "avg_pq_offset": 2048
                    "Level8": {
                        "length": 19,
                        "target_display_index": 1,
                        "trim_slope": 2038,
                        "trim_power": 2147,
                        "ms_weight": 2048,
                        "target_mid_contrast": 1470,
                        "clip_trim": 1968,
                        "saturation_vector_field0": 146,
                        "saturation_vector_field1": 128,
                        "saturation_vector_field2": 128,
                        "saturation_vector_field3": 128,
                        "saturation_vector_field4": 128,
                        "saturation_vector_field5": 128
            "start": 120,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2423,
                        "trim_power": 2934,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2113,
                        "trim_power": 1957,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2226,
                        "trim_power": 1753,
                        "ms_weight": 2048
                    "Level3": {
                    "Level8": {
                        "length": 19,
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 240,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2423,
                        "trim_power": 2934,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2113,
                        "trim_power": 1957,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2226,
                        "trim_power": 1753,
                        "ms_weight": 2048
                    "Level3": {
                    "Level8": {
                        "length": 19,
                        "trim_slope": 2038,
                        "trim_power": 2147,
                        "ms_weight": 2048,
                        "clip_trim": 1968,
            "start": 360,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level3": {
                    "Level8": {
                        "length": 19,
                        "trim_slope": 2038,
                        "trim_power": 2147,
                        "ms_weight": 2048,
                        "clip_trim": 1968,
lexyz
#8187 Post by lexyz » Mon Apr 17, 2023 6:11 pm
Nice test, thx :)
It seems UBP-X700 and Z9X (with VS10) aswell ignore chroma_weight trim in LLDV mode
https://slow.pics/c/8mQsP8E2
ref from Vincent's video https://ibb.co/L55yvNv
And yeah, I've seen your comment under video and can confirm the same with my equipment.
Anyway UBP-X700 tonemapp everything to 4000nit target in DV, thats cause noticable brightness loss for content < 4000 nit.
The infamous dim dolby vision from external sources on Sony's TV.
Hellboy.
#8188 Post by Hellboy. » Mon Apr 17, 2023 6:57 pm
In the picture the correct one is the right?
#8189 Post by RESET_9999 » Mon Apr 17, 2023 7:02 pm
left.
#8190 Post by RESET_9999 » Mon Apr 17, 2023 7:11 pm
Nice test, thx :)
yes exactly but this is not really a problem since 95% of the movie I tested NEVER use trim chroma_weight. Vincent should have tested real content before starting this lldv bug drama. The spears and munsil clip just happen to use chroma weight intensely. FYI, you can find out if it is used with my script (2-6):
EG of a recent movie that use it: https://drive.google.com/file/d/178p2Dh ... share_link
You can search ''Chroma'' in this list to find more: https://drive.google.com/drive/u/1/fold ... KFJwFxnDt-
Now, where it gets strange:
LG C2 internal player, chroma weight also doesn't work and looks like LLDV.
x700 + LG C2 TV-LED = chroma weight doesn't work and looks exactly like LLDV
firestick 4k MAX + C2 TV-LED = chroma weight WORKS!!! wtf?
https://slow.pics/c/HOZeP8Kw
LG C8 internal player = chroma weight works
LG C8 + x700 = chroma weight works
Chromecast + C8 LLDV = chroma weight doesn't work
Chromecast + C8 TV-LED = chroma weight doesn't work
https://www.youtube.com/watch?v=bokDQzHkEWc
