danbez wrote:
Sat Apr 15, 2023 7:55 pm
what are the steps to get the original RPU converted to P8?
dovi_tool.exe -m 2 or with the script(1-1) in my signature
danbez
Post by danbez »
RESET_9999 wrote:
Sat Apr 15, 2023 9:16 pm
DMDreview
Post by DMDreview »
Hi, need help, trying to figure out the source of the red push problem on the Shield tv.
I need to do a DV test, but only with L1, remove the rest, how to do it right. Is there some kind of utility?
DMDreview wrote:
Sun Apr 16, 2023 4:35 pm
it's not a metadata problem and anyway, the bluray Doctor Sleep only has a 100nits trim pass which is not used obviously in DV playback.
if you still want to try, just generate dv with madvr and this will get you metadata with just L1.
perfect sample to test it: https://drive.google.com/file/d/1PUwrol ... share_link
also very noticeable on quietvoid L11 test file: https://drive.google.com/file/d/1OwS0Te ... share_link
in fact, as soon as there's white, it's noticeable.
skull88
Post by skull88 »
Unless you're an Nvidia dev or have means of reaching out to them, this problem will likely never get resolved. But good luck!
DMDreview
Post by DMDreview »
RESET_9999 wrote:
Sun Apr 16, 2023 6:20 pm
With L2 solved, the bug remains, in fact, I need a file for the test, which will be played as a DV. But it will not apply the dynamic data, even L1, or they will be prescribed so as not to interfere with the current characteristics of the film. Is this possible to do?
I want to understand if the dynamic data is to blame, or if the DV processing itself is defective.
DMDreview
Post by DMDreview »
skull88 wrote:
Sun Apr 16, 2023 11:56 pm
Well I have already managed to find and prove to Nvidia a problem that has not been solved for 3 years and they fixed it. So nothing is impossible. Everything can be solved, I already have an idea about the source of the problem, but I want to go from the other side and check the alternatives for the origin of the problem.
lexyz
Post by lexyz »
deadchip12 wrote:
Thu Apr 13, 2023 12:56 am
Are sony bluray players still the ultimate devices to get for playing dolby vision remuxes?
True for TV-led mode only
lexyz wrote:
Mon Apr 17, 2023 11:17 am
did you try again with the latest version (useless cmv4.0 metadata removed)? Maybe it was causing issues ?
https://drive.google.com/file/d/18PLzRP ... share_link
and the Eagle beak L2 test with original metadata removed 1 by 1 ?
https://drive.google.com/file/d/1qdHux6 ... share_link
DMDreview wrote:
Mon Apr 17, 2023 8:40 am
I don't know I never tried to make a sample without L1 but you can try to generate an rpu without it. Here's a json I use to test the metadata, you can try to modify it .
The problem in my opinion is most likely something the Shield does wrong outside of the Dolby black box engine since its the only device with this particular problem.
dovi_tool.exe generate -j json -o RPU_generated.bin
cmv2.9 json template (each block has 120frame of metadata:
    "cm_version": "V29",
    "profile": "8.1",
    "long_play_mode": false,
	"source_min_pq": 7,
    "source_max_pq": 3079,
    "level5": {
        "active_area_left_offset": 0,
        "active_area_top_offset": 0,
    "level6": {
        "max_content_light_level": 0,
        "max_frame_average_light_level": 0
    "shots": [
            "start": 0,
            "duration": 120,
            "metadata_blocks": [
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2081,
                        "avg_pq": 1229
                    "Level2": {
                        "target_max_pq": 2081,
                        "trim_slope": 2048,
                        "trim_offset": 2048,
                        "trim_power": 2048,
                        "trim_chroma_weight": 2048,
                        "trim_saturation_gain": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "target_max_pq": 2851,
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "target_max_pq": 3079,
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 120,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2281,
                        "avg_pq": 1429
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 240,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2581,
                        "avg_pq": 1629
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 360,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 2781,
                        "avg_pq": 1829
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 480,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3079,
                        "avg_pq": 2029
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 600,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3200,
                        "avg_pq": 2229
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 720,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
						"max_pq": 3400,
                        "avg_pq": 2429
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 840,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3696,
                        "avg_pq": 2629
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 960,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 4095,
                        "avg_pq": 2829
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
cmv4.0 json template:
    "cm_version": "V40",
    "profile": "8.1",
	"source_min_pq": 62,
    "level5": {
        "active_area_top_offset": 276,
        "active_area_bottom_offset": 276
    "level6": {
        "min_display_mastering_luminance": 50,
    "shots": [
            "start": 0,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2423,
                        "trim_offset": 2149,
                        "trim_power": 2934,
                        "trim_saturation_gain": 1632,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2113,
                        "trim_offset": 2050,
                        "trim_power": 1957,
                        "trim_saturation_gain": 2004,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2226,
                        "trim_offset": 2044,
                        "trim_power": 1753,
                        "ms_weight": 2048
                    "Level3": {
                      "min_pq_offset": 2048,
                      "max_pq_offset": 2048,
                      "avg_pq_offset": 2048
                    "Level8": {
                        "length": 19,
                        "target_display_index": 1,
                        "trim_slope": 2038,
                        "trim_power": 2147,
                        "ms_weight": 2048,
                        "target_mid_contrast": 1470,
                        "clip_trim": 1968,
                        "saturation_vector_field0": 146,
                        "saturation_vector_field1": 128,
                        "saturation_vector_field2": 128,
                        "saturation_vector_field3": 128,
                        "saturation_vector_field4": 128,
                        "saturation_vector_field5": 128
            "start": 120,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2423,
                        "trim_power": 2934,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2113,
                        "trim_power": 1957,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2226,
                        "trim_power": 1753,
                        "ms_weight": 2048
                    "Level3": {
                    "Level8": {
                        "length": 19,
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
            "start": 240,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2423,
                        "trim_power": 2934,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2113,
                        "trim_power": 1957,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2226,
                        "trim_power": 1753,
                        "ms_weight": 2048
                    "Level3": {
                    "Level8": {
                        "length": 19,
                        "trim_slope": 2038,
                        "trim_power": 2147,
                        "ms_weight": 2048,
                        "clip_trim": 1968,
            "start": 360,
            "duration": 120,
                    "Level1": {
                        "min_pq": 0,
                        "max_pq": 3055,
                        "avg_pq": 1934
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level2": {
                        "trim_slope": 2048,
                        "trim_power": 2048,
                        "ms_weight": 2048
                    "Level3": {
                    "Level8": {
                        "length": 19,
                        "trim_slope": 2038,
                        "trim_power": 2147,
                        "ms_weight": 2048,
                        "clip_trim": 1968,
lexyz
Post by lexyz »
RESET_9999 wrote:
Mon Apr 17, 2023 1:21 pm
Nice test, thx :)
It seems UBP-X700 and Z9X (with VS10) aswell ignore chroma_weight trim in LLDV mode
https://slow.pics/c/8mQsP8E2
ref from Vincent's video https://ibb.co/L55yvNv
And yeah, I've seen your comment under video and can confirm the same with my equipment.
Anyway UBP-X700 tonemapp everything to 4000nit target in DV, thats cause noticable brightness loss for content < 4000 nit.
The infamous dim dolby vision from external sources on Sony's TV.
Hellboy.
Post by Hellboy. »
lexyz wrote:
Mon Apr 17, 2023 6:11 pm
In the picture the correct one is the right?
Hellboy. wrote:
Mon Apr 17, 2023 6:57 pm
left.
Nice test, thx :)
yes exactly but this is not really a problem since 95% of the movie I tested NEVER use trim chroma_weight. Vincent should have tested real content before starting this lldv bug drama. The spears and munsil clip just happen to use chroma weight intensely. FYI, you can find out if it is used with my script (2-6):
EG of a recent movie that use it: https://drive.google.com/file/d/178p2Dh ... share_link
You can search ''Chroma'' in this list to find more: https://drive.google.com/drive/u/1/fold ... KFJwFxnDt-
Now, where it gets strange:
LG C2 internal player, chroma weight also doesn't work and looks like LLDV.
x700 + LG C2 TV-LED = chroma weight doesn't work and looks exactly like LLDV
firestick 4k MAX + C2 TV-LED = chroma weight WORKS!!! wtf?
https://slow.pics/c/HOZeP8Kw
LG C8 internal player = chroma weight works
LG C8 + x700 = chroma weight works
Chromecast + C8 LLDV = chroma weight doesn't work
Chromecast + C8 TV-LED = chroma weight doesn't work
https://www.youtube.com/watch?v=bokDQzHkEWc
DMDreview
Post by DMDreview »
RESET_9999 wrote:
Mon Apr 17, 2023 4:30 pm
Thanks.
I think so too, I have confirmation of this theory.
But I want to put together all the available information, so as not to make a mistake.
