Support for *.dvdmedia DVD Images
alexkazik
Post by alexkazik »
some programs do store a DVD image as an folder of the DVD (with all files inside) and the extension ".dvdmedia" for the folder. Such folders are shown as a "dvd file" in the finder, and a double click do open it in the DVD Player.
So, it would great if MakeMKV would also recognize *.dvdmedia folders. (Should be simple: just allow to select those entries, and then scan xxx.dvdmedia/VIDEO_TS/VIDEO_TS.IFO).
Thanks in advance.
/ALeX.
ToxicDreamz
Re: Support for *.dvdmedia DVD Images
Post by ToxicDreamz »
If you delete the ".dvdmedia" file extension name off the end, it will turn into a regular folder.
alexkazik
Post by alexkazik »
Yes, I know that. But why not make it easy?
ToxicDreamz
That isn't easy?
And yes, I know that would be more convenient.
vdubgeek
Post by vdubgeek »
I would second the request to natively support the .dvdmedia extension. Granted it's easy to rename, but it would be nice if makemkv recognized it without having to take the extra step to rename.
Keep up the great work though, makemkv has become a major component of my dvd media server project.
