Trying to flash a BD-RE HL-DT-ST BD-RE BU40N 1.01 drive on OS Ventura?
iiayva?
Post by iiayva? »
I should preface this by saying that I am extremely computer illiterate. I got an Archgon external drive for my regular blurays last year and this year decided to purchase my first 4K bluray.
As you might expect, when I tried to rip it, I got a ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' notification.
I've looked up the excellent drive flashing guide, but as someone who has no knowledge about any of this stuff, it kind of made my head spin.
I did eventually manage to figure out that I probably need the HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 firmware file, but I'm just posting this because I want to double-check before I try anything and accidentally brick my drive.
OS device name: /dev/rdisk2
Product: BD-RE BU40N
Revision: 1.01
Firmware date: 2119-10-16 10:32
Bus encryption flags: 1F
Highest AACS version: 78
Harware support: Yes
Firmware support: No
Firmware version: 1.01
Re: Trying to flash a BD-RE HL-DT-ST BD-RE BU40N 1.01 drive on OS Ventura?
iiayva? wrote: Fri Apr 14, 2023 9:48 pm I should preface this by saying that I am extremely computer illiterate. I got an Archgon external drive for my regular blurays last year and this year decided to purchase my first 4K bluray.
Revision: 1.01
I suggest flashing your drive with DE_BU40N_1.00 firmware instead as it works with all ripping software. See the guide for instructions viewtopic.php?p=74718#p74718
iiayva?
Post by iiayva? »
MartyMcNuts wrote: Fri Apr 14, 2023 11:39 pm
I can't find a link for that on the page, sorry.
iiayva? wrote: Sat Apr 15, 2023 2:04 am
under the How To Flash Videos and commands:
section
1.00 is in the de pack
iiayva?
Post by iiayva? »
Billycar11 wrote: Sat Apr 15, 2023 5:15 am
section
Thanks. If I may ask, what are the main differences between that one and the one I listed in my initial post? I couldn't really grasp what they were.
Based off the guide it seemed like that was the correct one, though, of course, I defer to the judgement of the people on here.
Sorry for asking all these (no doubt, obvious) questions, but I just don't want to brick a $100 dollar machine by accident because I don't know much about LibreDrive and Terminal.
iiayva? wrote: Sat Apr 15, 2023 7:48 am
section
the simple answer is ripper compatibility as marty said 1.00 works on more
iiayva?
Post by iiayva? »
Billycar11 wrote: Sat Apr 15, 2023 8:42 am the simple answer is ripper compatibility as marty said 1.00 works on more
Thank you so much, I've now located the DE_LG_BP60NB10_1.00_MK_HBD file (which I assume is the correct one).
I guess I must have read the guide wrong because I thought that other piece of firmware was what a MD-8107S-U3-UHD drive needed.
Thanks again.
iiayva? wrote: Sat Apr 15, 2023 7:19 pm
Thanks again.
bu40n 1.00 not bp60
the guide bu40n 1.03 works too marty was just giving you bonus info since you have older fw you could go direct to bu40n 1.00 to have wider compatibility bp60 does not have wide ripper compatibility.
iiayva?
Post by iiayva? »
Billycar11 wrote: Sat Apr 15, 2023 7:25 pm
Thanks again.
bu40n 1.00 not bp60
Ah, thanks. I think I misunderstood. You meant the one in the Downgrade Enabled Firmware V.2.zip google drive folder?
iiayva? wrote: Sat Apr 15, 2023 7:58 pm
Thanks again.
bu40n 1.00 not bp60
yeah
iiayva?
Post by iiayva? »
Billycar11 wrote: Sat Apr 15, 2023 8:09 pm
bu40n 1.00 not bp60
yeah
Sorry for asking what I'm sure must be an obvious question, but does the information in the guide provided in the Mac commands to flash section, still apply for this (I'm assuming since the date doesn't list 2020) unencrypted firmware?
iiayva? wrote: Sat Apr 15, 2023 8:39 pm
yeah
yes there are unencrypted commands there to use.
iiayva?
Post by iiayva? »
Billycar11 wrote: Sat Apr 15, 2023 8:40 pm
yeah
Thanks, though I'm a bit confused about the video linked below the Mac section as it seems to be for PCs.
I only ask because I have no idea how to use Terminal so I don't want to fiddle around without seeing someone else visually demonstrate what to do.
Is there a video for Macintosh computers that I am not seeing?
iiayva?
Post by iiayva? »
iiayva? wrote: Sat Apr 15, 2023 9:29 pm
Thanks, though I'm a bit confused about the video linked below the Mac section of the How-To Guide as it seems to be for PCs.
no sorry dont have a mac to make a video for it
maybe just return your drive and buy a preflashed one then i and others offer them
