Ripping Blu-Ray to folders
mike23
Post by mike23 »
I could have sworn there was a functionality in the past to rip Blu-Ray's to folders and not .mkv's
I just can't seam to find it in the configuration, using the latest version as of date of posting on PC.
Here is an example of what I am trying to accomplish:
Screenshot 2023-04-12 235213.jpg (13.6 KiB) Viewed 6417 times
Sunoo
Re: Ripping Blu-Ray to folders
Post by Sunoo »
File->Backup, or the little icon with the arrow pointing at the folder.
mike23
Post by mike23 »
Sunoo wrote: Fri Apr 14, 2023 3:10 pm File->Backup, or the little icon with the arrow pointing at the folder.
Thank you, does that feature require registration or is it available in the trial?
Bluray backup is available "as a trial". Bluray features, in general, are limited to 30 days after the key is entered for MakeMKV.
Some people enter the key regularly, even when it doesn't change, to bypass the 30-day limitation.
mike23
Post by mike23 »
Thanks so much for the help!
