Hoping someone can help me out here. I bought what was advertised as an LG WH14NS40 and in my excitement jumped straight into flashing it to WH16NS60 1.02MK. The flash failed and after a couple of back and forths with the command line i pulled the drive out of my machine and it's actually an LG BH16NS40.
Is this recoverable or should i write this off to bad judgement?
Bricked BH16NS40
Re: Bricked BH16NS40
What do you mean recoverable. You said the flash failed, so shouldn't the drive still be on whatever firmware was on it when you got it?mkvnewb1 wrote: Thu Apr 13, 2023 2:48 pm Hoping someone can help me out here. I bought what was advertised as an LG WH14NS40 and in my excitement jumped straight into flashing it to WH16NS60 1.02MK. The flash failed and after a couple of back and forths with the command line i pulled the drive out of my machine and it's actually an LG BH16NS40.
mkvnewb1
Sorry poor description there. It did work but returned an error. The drive now won’t open and MakeMkv is showing BOOT next to the drive name instead of the full drive name and the info is very limited compared to what it used to be. I’m just setting up a windows machine to try the sdftool.MartyMcNuts wrote: Fri Apr 14, 2023 5:20 amWhat do you mean recoverable. You said the flash failed, so shouldn't the drive still be on whatever firmware was on it when you got it?mkvnewb1 wrote: Thu Apr 13, 2023 2:48 pm Hoping someone can help me out here. I bought what was advertised as an LG WH14NS40 and in my excitement jumped straight into flashing it to WH16NS60 1.02MK. The flash failed and after a couple of back and forths with the command line i pulled the drive out of my machine and it's actually an LG BH16NS40.
seen this a few times you got lucky if this is the case pull the drive and post the date it was built its likely pre 2016 and to old to do UHD.
mkvnewb1
Yeah i did that too. Its manufacture date is June 2015.Billycar11 wrote: Fri Apr 14, 2023 7:20 am seen this a few times you got lucky if this is the case pull the drive and post the date it was built its likely pre 2016 and to old to do UHD.
mkvnewb1
Here's what MakeMKV shows.
Just got the windows machine set up.
yeah its to old flash back to this: https://drive.google.com/file/d/1ZtdhSX ... RS_O9/viewmkvnewb1 wrote: Fri Apr 14, 2023 7:28 amYeah i did that too. Its manufacture date is June 2015.Billycar11 wrote: Fri Apr 14, 2023 7:20 am seen this a few times you got lucky if this is the case pull the drive and post the date it was built its likely pre 2016 and to old to do UHD.
in sdf gui with include bootloader checked
mkvnewb1
SDF Gui says it's not the right platform to flash it. I've managed to flash the original firmware back onto it using a tool from the LG site.Billycar11 wrote: Fri Apr 14, 2023 7:33 amyeah its to old flash back to this: https://drive.google.com/file/d/1ZtdhSX ... RS_O9/viewmkvnewb1 wrote: Fri Apr 14, 2023 7:28 amYeah i did that too. Its manufacture date is June 2015.Billycar11 wrote: Fri Apr 14, 2023 7:20 am seen this a few times you got lucky if this is the case pull the drive and post the date it was built its likely pre 2016 and to old to do UHD.
MakeMKV is now showing the below. If it rips OK I'll leave it as is. I bought it off eBay where it's been mislabled so i'll try and get my money back. Not what i was intending to buy. I already have a drive that can read blu-rays. I was looking for a new UHD drive. I had the LG BU40N previously and it was fine but the form factor annoyed me.
Would you have a recommended drive to go for?
the pioneer i sell
