Attempting to Flash for UHD
PandaMac
Post by PandaMac »
I have 2 new drives and purchased the Flash tool single drive flasher for both. Neither are seen and I get " Unable to find yourMakeMKV installation". Any suggestions would help. I was able to flash with the SDFtool but still no joy. I have included screen shots.
Processor Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz 3.00 GHz
Installed RAM 32.0 GB (31.8 GB usable)
After SDFtool Flash
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLHL75E4257
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Failed SDFtool Flash with command procedure error Oxff05c103
OS device name: U:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MOFM2QG5610
Firmware version: 1.02
Please help,
Scott
MKB20_v61_BLUE_PLANET_II_D1_447F.tgz
(106.65 KiB) Downloaded 1546 times
Drive 2 Help Flash 2023-04-11 162626.jpg (38.43 KiB) Viewed 22418 times
MVMakerPurchased 2023-04-11 162219.jpg (36.19 KiB) Viewed 22418 times
Re: Attempting to Flash for UHD
Reinstall makemkv to the default directory if it's not
PandaMac
Post by PandaMac »
No Change at all.
PandaMac wrote: Fri Apr 14, 2023 4:55 am No Change at all.
I've emailed you already about this. I assumed it was sorted as I never heard back from you.
Can you confirm:
1. You are running Windows 10 or 11 (64 bit)
2. You are NOT using a VM
3. You installed MakeMKV in the default directory (which is C:\Program Files (x86)\MakeMKV)
Also, how are your drives connected to your PC? What enclosures or adapters are you using?
moviewatcher22
Post by moviewatcher22 »
I am having this same error code, 0xff05c103
Using Win10, makemkv installed on c:, not running a VM. Any help would be appreciated. Image
moviewatcher22 wrote: Sat Jan 31, 2026 2:57 am Hi,
According to MakeMKV in your picture, your BU40N is at 1.03 with LibreDrive enabled. Why are you trying to flash it?
moviewatcher22
Because I don't know what I am doing. It shows up as you see but the drive does not open, the led does not light up. In MakeMKV it won't open when I hit eject. So I was thinking it needs to be flashed, it came this why from who I got it from online.
moviewatcher22 wrote: Sat Jan 31, 2026 5:29 am Because I don't know what I am doing. It shows up as you see but the drive does not open, the led does not light up. In MakeMKV it won't open when I hit eject. So I was thinking it needs to be flashed, it came this why from who I got it from online.
So what drive is it?
Make?
Model?
Manufacture date?
Then copy/paste the MakeMKV drive info & libredrive info sections.
That error code normally means there's a disc in the drive. Remove it.
moviewatcher22
It is a lg wh14ns40, product bd-re bu40n, this image has all the info. It won't open for me and MakeMKV says there is no disc.
https://www.flickr.com/photos/189419696 ... 069660621/
moviewatcher22
Revision: 1.03
Serial number: SIK9MG86E1343
Firmware version: 1.03
moviewatcher22 wrote: Sun Feb 01, 2026 1:43 am It is a lg wh14ns40, product bd-re bu40n, this image has all the info. It won't open for me and MakeMKV says there is no disc.
Who told you to flash bu40n fw to a wh14ns40
Use the recovery option quick back to the correct fw and don't keep the drive powered on when its flashed wrong
moviewatcher22
I have just been reading the forums and trying to figure it out. The why it is programed is how it came in the mail. I was just trying to flash it not knowing if it was already good or not.
I do not know or understand yet how to make it work. I requested a return from the ebay seller for the drive since it won't open. In theory I am thinking it should just be working like normal at least. I can't afford the preflashed drives yet but really want to back up all of my uhd discs and other older movies with it.
moviewatcher22 wrote: Sun Feb 01, 2026 4:47 am I have just been reading the forums and trying to figure it out. The why it is programed is how it came in the mail. I was just trying to flash it not knowing if it was already good or not.
it came flashed as a BU40N not a WH14NS40?
not impossible but im thinking you did it not the seller
Szary Kot
Post by Szary Kot »
Maybe it'll be useful to someone.
On Windows 7 Professional SP2 64-bit, SDFtool works like a charm.
I've used it to convert two drives: a Verbatim 43888 (BU40N) and an Asus BW-16D1HT.
Everything works perfectly. Many thanks to the program's creators.
Licensed User MakeMKV
