Makemkv stops while loading DVD
steve_weinrich
Post by steve_weinrich » Thu Apr 13, 2023 4:19 am
The disc is The Matrix. While scanning, MakeMKV stops early at VOB 21223. This seems to be related to seamless branching. I used IFOEdit to remove the seamless branching and MakeMKV was able to process the resultant files.
I have uploaded the entire DVD to my google account. Here is the link: https://drive.google.com/drive/folders/ ... sp=sharing
Noe: This is not due to a dirty disc. I have also tried two different discs, both extremely clean, and both yield the exact same problem.
Ezatoka
Re: Makemkv stops while loading DVD
Post by Ezatoka » Thu Apr 13, 2023 3:32 pm
Try to check a different viewtopic.php?f=7&t=28541 DVD opening mode
steve_weinrich
Post by steve_weinrich » Thu Apr 13, 2023 3:48 pm
ah! That did the trick. CellWalk fails but CellTrim works. Thank you very much.
