I'm not sure if this has been pointed out yet, but the option to edit the L6 MaxCLL/MaxFLL based on the HDR10 BL MaxCLL/MaxFLL values doesn't seem to work properly. It seems that it only copies the L1 RPU content light level and uses that for L6 rather than the light level from the HDR10 file.
It works as it should because static HDR10 maxcll/fall are often incorrect or not present.johnjon94 wrote: ↑Tue Apr 11, 2023 5:06 pmI'm not sure if this has been pointed out yet, but the option to edit the L6 MaxCLL/MaxFLL based on the HDR10 BL MaxCLL/MaxFLL values doesn't seem to work properly. It seems that it only copies the L1 RPU content light level and uses that for L6 rather than the light level from the HDR10 file.
I made this change a couple of versions ago when @quietvoid added the information in the rpu summary.
You can always use (2-1-1) and edit L6 with any value you want.
deadchip12
Are sony bluray players still the ultimate devices to get for playing dolby vision remuxes?
BublyOnFire
Thanks for your hard work @RESET_9999
LG C1 55'' OLED + Sonos Beam 2
BublyOnFire
Hi, Does this mean that we will never be able to put the profile 8 on the films you mention? Is there any way around it?RESET_9999 wrote: ↑Mon Apr 10, 2023 9:44 pmyes FEL is discarded but know that not every FEL movie can be converted to P8 (or played on non-fel devices) because some of them are expanding the picture brightness when BL and FEL are decoded by the player.
So the DV metadata in the RPU is meant to be played with the FEL brightness ONLY. Playing these FEL movies on a non-fel device will result in an image darker than the intended look.
Here's a list of FEL movies that expand brightness (still looking into my library to find more):
https://docs.google.com/spreadsheets/d/ ... sp=sharing
no , not without baking the EL into the BL. (require re-encoding)
yesdeadchip12 wrote: ↑Thu Apr 13, 2023 12:56 amAre sony bluray players still the ultimate devices to get for playing dolby vision remuxes?
BublyOnFire
What do you mean byRESET_9999 wrote: ↑Sat Apr 15, 2023 1:09 pmno , not without baking the EL into the BL. (require re-encoding)
putting the el in the bl? Are you talking about generating a DV XML file by resolve and re-injecting it? Like in this tutorial? https://youtu.be/ZdFiqATo_j8
no, I mean the EL and BL are re-encoded together which results in a new BL that will work properly with the original RPU(converted to P8).BublyOnFire wrote: ↑Sat Apr 15, 2023 2:07 pmAre you talking about generating a DV XML file by resolve and re-injecting it? Like in this tutorial? https://youtu.be/ZdFiqATo_j8
like this...
BL+EL baked + original rpu converted to P8:
https://drive.google.com/file/d/18OEcZP ... share_link
BL without EL baked + original rpu converted to P8 (WRONG):
https://drive.google.com/file/d/1g-SCg0 ... share_link
BL + Resolve generated RPU:
https://drive.google.com/file/d/13jBeX_ ... share_link
Original P7 ST-DL:
https://drive.google.com/file/d/1AflJT_ ... share_link
Original P7 DT-DL:
https://drive.google.com/file/d/15OcPsW ... share_link
BublyOnFire
Thank you for your explanation. I appreciate it.
Reset, after baking the BL and EL (with DoViBaker, I presume), what are the steps to get the original RPU converted to P8?RESET_9999 wrote: ↑Sat Apr 15, 2023 3:41 pmno, I mean the EL and BL are re-encoded together which results in a new BL that will work properly with the original RPU(converted to P8).
like this...
dovi_tool.exe -m 2 or with the script(1-1) in my signature
Thanks!RESET_9999 wrote: ↑Sat Apr 15, 2023 9:16 pmdovi_tool.exe -m 2 or with the script(1-1) in my signature
Hi, need help, trying to figure out the source of the red push problem on the Shield tv.
I need to do a DV test, but only with L1, remove the rest, how to do it right. Is there some kind of utility?
it's not a metadata problem and anyway, the bluray Doctor Sleep only has a 100nits trim pass which is not used obviously in DV playback.
if you still want to try, just generate dv with madvr and this will get you metadata with just L1.
perfect sample to test it: https://drive.google.com/file/d/1PUwrol ... share_link
also very noticeable on quietvoid L11 test file: https://drive.google.com/file/d/1OwS0Te ... share_link
in fact, as soon as there's white, it's noticeable.
Unless you're an Nvidia dev or have means of reaching out to them, this problem will likely never get resolved. But good luck!DMDreview wrote: ↑Sun Apr 16, 2023 4:35 pmRESET_9999 wrote: ↑Sat Apr 15, 2023 9:16 pmdovi_tool.exe -m 2 or with the script(1-1) in my signature
