can't rip old blu-ray
yfrzr
Post by yfrzr »
Hello everyone,
First of all sorry for English google translate...
can't rip old blu-ray, would it be possible to get help based on the debug history?
thank you for your feedback
Debug log started at Wed Apr 12 10:02:25 2023 , written by MakeMKV v1.17.3 darwin(x64-release)
001005:0000 MakeMKV v1.17.3 darwin(x64-release) started
001004:0000 Debug log is enabled, it will be logged under file:///Users/yannick/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.87.0/(SecureTransport) LibreSSL/3.3.6/1.51.0 (x86_64-apple-darwin22.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MO9M6180653d" is opened in SE access mode.
SDF v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO9M6180653
001003:0020 DEBUG: Code 100864261 at pmp)STcczo*'LGHH:121271617
001003:0020 DEBUG: Code 100864261 at *P_=i(6 2Zz:Fuh(:213130559
001003:0020 DEBUG: Code 100864261 at 77#CcTj4A$"2.pZ6@]:121263429
001003:0020 DEBUG: Code 100864261 at 77#CcTj4A$"2.pZ6@]:121262302
002003:0000 Error 'SCSI Error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO9M6180653' at offset '24642191360'
002003:0000 Error 'SCSI Error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO9M6180653' at offset '24642254848'
001012:0000 udf: node fe/efe failed!
Re: can't rip old blu-ray
The disk has flaws that make it unreadable at points. They could be because the drive doesn't have sufficient power to spin the speed it gets to, or they could be dirty parts of the disk (talking the disk itself, not the contents! :) ).
Do the errors change between runs, or occur at the same place?
