Failed to save title - 1.6.8 (1.6.7 worked fine)
BonzTM
#1 Post by BonzTM » Thu Apr 28, 2011 4:41 pm
I opened MakeMKV as I usually would, and was notified of 1.6.8. I closed the program, downloaded the update, and installed it as I always do.
I've tried ripping 3 BDs.
- Blow
- The Crazies
- Law Abiding Citizen
All three rip the entire thing through, then at the very end a popup says "Failed to save title" or something along those lines. I never get an error code, crash, or anything. Is there something fundamentally different with 1.6.8?
crowfax
Re: Failed to save title - 1.6.8 (1.6.7 worked fine)
#2 Post by crowfax » Thu Apr 28, 2011 9:09 pm
Turn on debug and post your log please.
gorbold
download 1.6.8
#3 Post by gorbold » Fri Apr 29, 2011 1:52 am
I tried to download 1.6.8 and when running the program, 1.6.7 still shows up
jkliop69
#4 Post by jkliop69 » Tue May 10, 2011 5:41 pm
FYI "failed to save title" is the error dialog that I'm getting with both the Planet of the Apes disks. I added the debug log here http://www.makemkv.com/forum2/viewtopic.php?f=8&t=3569
richwill
#5 Post by richwill » Mon May 16, 2011 11:13 pm
I have a second BR which will not rip in 1.6.8 which ripped successfully in 1.6.5. Has anyone tried re-ripping BR disks that worked on a previous version?
o_mega05
#6 Post by o_mega05 » Fri May 27, 2011 6:25 am
@ BonzTM
Just curious if your issue was resolved? I'm having the same issue since the latest update and I'm getting the same "save failed" message for every 3 out of 4 BD rip attempts. I just thought it had something to do with newer BD releases.
Thanks in advance to anyone who has some incite on this issue.
captain
#7 Post by captain » Sat May 28, 2011 5:10 am
same problem here with TransSiberian
#8 Post by mike admin » Sat May 28, 2011 11:58 am
Please try 1.6.9
richwill
#9 Post by richwill » Mon Jun 06, 2011 7:35 pm
I am having the same issue with 1.6.10. One thing to note is that the following is appearing in my dmesg during this process:
[74152.915919] sr 18:0:0:0: [sr2] Result: hostbyte=DID_OK driverbyte=DRIVER_OK
[74152.915922] end_request: I/O error, dev sr2, sector 28160
[74273.512891] sr 18:0:0:0: timing out command, waited 120s
[74273.512902] sr 18:0:0:0: [sr2] Unhandled error code
[74273.512903] sr 18:0:0:0: [sr2] Result: hostbyte=DID_OK driverbyte=DRIVER_OK
[74273.512907] end_request: I/O error, dev sr2, sector 29696
[74394.807483] sr 18:0:0:0: timing out command, waited 120s
[74394.807492] sr 18:0:0:0: [sr2] Unhandled error code
[74394.807494] sr 18:0:0:0: [sr2] Result: hostbyte=DID_OK driverbyte=DRIVER_OK
[74394.807498] end_request: I/O error, dev sr2, sector 31232
It's also worth noting that I know that 1.6.5 did not exhibit this issue, 1.6.8 has the same problem, and I'm using a BR drive over an iSCSI connection (which never affected this process in the past).
HTH
cfriedberg
#10 Post by cfriedberg » Thu Jun 09, 2011 11:08 pm
same problem, doesn't matter the version. Trying to rip BD of Harry Potter 2. Debug log attached. Any help greatly appreciated.
#11 Post by mike admin » Fri Jun 10, 2011 1:43 pm
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00037.m2ts' at offset '21229989888'
This is a physical disc error.
