Post by RESET_9999 » Thu Apr 06, 2023 10:57 pm
tjreis2 wrote:
Wed Apr 05, 2023 8:28 pm
I did but the file didn't open. Weirdly enough, when I open the MP4 it does work and displays the credits in bright white instead of grey, but maybe it's something because of the Dolby Vision on toggle...
I also noticed that some files without audio won't work as well.
Anyway, I already tested everything, and the x800m2 support FEL(TS/M2TS) just fine via the network.
EDIT:
try this: https://drive.google.com/file/d/1IlfoXQ ... share_link
chrisdm
Post by chrisdm » Fri Apr 07, 2023 3:09 am
RESET_9999 wrote:
Thu Apr 06, 2023 10:56 pm
chrisdm wrote:
Wed Apr 05, 2023 5:15 pm
Hi @RESET_9999,
Thank you for your Dolby Vision scripts, these things are pretty sick mate.
I am trying to use them as there are some WEB-DLs of a Disney+ show my wife and I like to watch, however the releases for the show are in 4K HDR and 4K Dolby Vision exclusively, there isn't a hybrid release with both sets of metadata. After watching your tutorial vids (as they are slightly old and differ a bit from your current scripts), I assume the workflow I want to use is:
1) MODE.I= DoVi Convert/Edit/Sync/Inject two inputs (P8 Hybrid maker)
1) Workflow.1= Base Layer file + ST P5/P8/P7 DoVi file (can also mux and convert audio)
(Drag and drop the HDR release, then the DV release)
After this is where some options differ from your tutorial clip. I assume I should be choosing 'no' for L6 edit, then the next option I am confused on what to choose. Should I be using duplicate or remove for re-sync the RPU? On my own try I didn't choose either and it spit out an MKV with what looks like both HDR and DV metadata when inspecting with MediaInfo, however I haven't had a chance yet to try it on my TV.
Would you be able to just confirm what I should be choosing for the re-sync RPU prompt if I want to just make a hybrid WEB-DL from the same P2P group that released separate DV and HDR releases?
yes (1-1) is the hybrid maker workflow and no need to resync nor edit L6/L5 if both versions comes from the same provider, they are most likely the same length (same frame order).
The tutorials are indeed old, I will re-do them when I find some free time.
Yeah that would be sick. Would you be able to guide me as to which workflow is needed to mux if one is from a different provider? Haven't had that pop up yet but it might.
As well, any plans to make a version of your script compatible with linux? I would love to be able to do this all from my hosted server that runs linux rather than have to download from my home machine, mux the content, then upload to my server. Looking st the script I might be able to convert it to PowerShell so it can run on PowerShell core in linux, but not sure if all tools come in a linux cli version.
Post by RESET_9999 » Fri Apr 07, 2023 10:38 pm
no sorry
it's the same workflow (1-1) but you have to resync the rpu to the new BL if needed.
chrisdm
Post by chrisdm » Fri Apr 07, 2023 10:53 pm
no sorry
So 1-1, then duplicate?
Gatorman
Post by Gatorman » Fri Apr 07, 2023 11:12 pm
You'll need to find the difference between the two sources. Watch the DV version and find a camera cut. Then find the same cut on the HDR version. Compare the frame count of the two files and duplicate or remove the necessary amount of frames so the DV version matches the HDR version. For example, DV = 120865, HDR = 120895. You would duplicate 30 frames.
chrisdm
Post by chrisdm » Sat Apr 08, 2023 12:23 am
How would I know whether to duplicate 30 or remove 30 from HDR? As in, (if this makes sense) what file is the duplicate/remove applied to?
Gatorman
Post by Gatorman » Sat Apr 08, 2023 12:47 am
You're manipulating the RPU. So you need to remove or duplicate the DV source to match the HDR source.
chrisdm
Post by chrisdm » Sat Apr 08, 2023 2:30 am
That makes perfect sense, I'll give that a go should I need to! Thank you for the help mate, appreciate it. I'll try and automate this part instead of comparing both videos side by side to get the matching frame, I should be able to figure out how to do this programatically.
spl147
Post by spl147 » Mon Apr 10, 2023 9:23 pm
So much info in the thread, so what i gather is by converting a DV mkv with FEL to profile 8.1 we loose FEL?
So it’s the same a playing a DV MKV on a zidoo or dune? FEL is discarded and only the rpu is used?
Amused
Post by Amused » Mon Apr 10, 2023 9:30 pm
Hey guys, did anyone find a USB to ethernet adapter that works with the X800m2?
UHD players: Sony X700, Zidoo Z1000 Pro
Audio system: Sony HT-A9
TV: Sony 77A80J
Post by RESET_9999 » Mon Apr 10, 2023 9:44 pm
yes FEL is discarded but know that not every FEL movie can be converted to P8 (or played on non-fel devices) because some of them are expanding the picture brightness when BL and FEL are decoded by the player.
So the DV metadata in the RPU is meant to be played with the FEL brightness ONLY. Playing these FEL movies on a non-fel device will result in an image darker than the intended look.
Here's a list of FEL movies that expand brightness (still looking into my library to find more):
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Post by RESET_9999 » Mon Apr 10, 2023 9:45 pm
I tried mine and it didn't work.
quietvoid
Post by quietvoid » Tue Apr 11, 2023 12:20 am
I had a look at the issues with Saving Private Ryan (1998) flickering without FEL devices: https://www.avsforum.com/threads/media- ... t-62474107
Might be interesting to some reading here too.
skull88
Post by skull88 » Tue Apr 11, 2023 3:09 am
Thanks for confirming and looking into SPR. I was also surprised that people just brushed this flickering off as purely a problem with playback of P7 DV w/FEL for media players/apps or something, and not the actual retail UHD BD authoring or DV metadata somehow, considering I've basically never come across something that flickered this much and so obviously from frame to frame, or at least it's super rare for a disc to have this. Re-doing my own L1 DV metadata in Resolve for this movie also fixed that issue playing back on Shield Pro for example, which shows it wasn't inherent to the HDR10 BL, but something to do with the FEL/DV and how it was implemented and/or how it's processed, as you confirmed. This movie deserves another pass maybe for an anniversary or Criterion even, so perhaps it will get fixed one day, as otherwise it's a fantastic 4K UHD. Cheers for the work and info!
codeXRes
Post by codeXRes » Tue Apr 11, 2023 11:30 am
Did anyone manage to test the FEL support in Ugoos by the kodi.monsoons build before it was sadly pulled?
https://forum.kodi.tv/showthread.php?tid=372504
