AACS host certificate revoked
Drew Peacock
Post by Drew Peacock » Thu May 26, 2011 4:17 am
While trying to backup a blu-ray on a newly purchased drive, I received the following error log. Can anyone help me out?
MakeMKV v1.6.8 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-ROM HL-DT-ST BD-RE UH12LS28 1.00" opened in OS access mode.
Evaluation version, 29 day(s) out of 30 remaining
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0D061A453EBDAF60F32C3A96565DAC61397 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..014768824DD065713C434DE1FC48071DC04 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..05777D90A8C075902F50606D9EA8BDFB63B to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..04D5838A52CF7C5541749740405CB1F71DC to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..01FFA1FB6924D0355A8F11B251512B8F4D3 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..06C77591FF93AA667546E5F975C064DDBEB to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0A4713695F9A6F9E0FFD5162FD3FF804876 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0F8BE0F5E62F96C71E697665E320560B510 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0FE738A5CE4CB96836CF1B3EBE462E2C937 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..079D71CED5829465E2B6D25374F290779AB to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0ECBEB57BAE782E4A7F5C0193A1BE848F73 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..071582AE0471F7AC60C9E0A3E274E65A2D6 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..01215CF03E249BDD9C06156F7E85810C6EF to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..08A2FC6D7A59C571CEEB2532E880C36A74F to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..098EB453422BB48780627BFB9F916FF1523 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0E528387CC30C47DEF1971186D80C561925 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0D279FCE5CC8AD6F7D426FD6BED235DA45E to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0AE1157DBA944E7FB32BFA5805141988E70 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..038F931FCDEC132E6F91B8A4908075CD704 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..073EFE0EE70E7B05B6672899C7A2A18DCC6 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..029F7F445173B9431D4E6249A1070E81403 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0D5E4DC3B8057E7B2E2629C965D3FEB1AA4 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0AD541B3EB1AFE3DF8562AB49FE7C2C0041 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..05CF6C27D44E6576C2F07B073DF5A7ACBC0 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0BF90918463CCDB3CD3E714B4BAFFC33167 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..055A1B2DDE36D7E44761BD9FD3465A322C1 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0EA0B3D75B888058181036B389EA12553BC to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0932AE1C6FF551BECC6576F02D6FC5CACFC to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..026580B18808F454269228C2DBD1F2BBEBF to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..068E66F640915E8F8AEE71D6FB1E8523283 to device 'OS:IOBDServices:9ef3161978247824:HL-DT-ST BD-RE UH12LS28 1.00'
setarip_old
Re: AACS host certificate revoked
Post by setarip_old » Thu May 26, 2011 7:57 pm
Hi!
Did you do the following (As stated in your log)?
Smithcraft
Post by Smithcraft » Thu May 26, 2011 9:17 pm
DASPI kernel isn't going to do anything.
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=3559
You can either wait till that issue has been overcome, or get a drive that isn't gimped by design.
SC
setarip_old
Post by setarip_old » Fri May 27, 2011 6:20 pm
@Smithcraft
You are correct! Good catch ;>}
Drew Peacock
Post by Drew Peacock » Fri May 27, 2011 7:15 pm
Thanks for the help!! I have quite a few blu-ray's and was hoping to copy them on to my NAS and then watch them from my mac mini. I was advised to buy my blu-ray drive from a friend; clearly he was misinformed. Could you tell me what drives I can buy to copy my blu-ray collection on to my NAS? Appreciate the quick responses to my first post.
setarip_old
Post by setarip_old » Sat May 28, 2011 6:10 am
Apparently anything OTHER THAN those listed in the link posted here by "Smithcraft"...
Smithcraft
Post by Smithcraft » Sat May 28, 2011 6:14 am
I use an older ASUS BR-04B2T. Works fine for me.
Just because a drive is not on that list, does not mean it's going to be a safe purchase.
SC
