Re: Pioneer firmware update February 2023
I wound up just ordering new drives. Ordered 4. All had 1.03 on it. Using two and I will keep the other two on hand as spares in case either of these ever fail.
- Contact:
Most likely both - it will be part of sdftool and also available as a separate utility.Coopervid wrote: Thu Mar 16, 2023 4:41 pm Good to hear Mike. Will the downgrade functionality be part of Makemkv or is the separate utility needed?
Hi all I'm new to the drive flashing could anyone tell what program is used in Windows to modify the binary file in the pioneer updater.exe please
Regards Darren.
Regards Darren.
computerlove
Unluckily, I have also flashed my BDR-S13J-X with 1.04 firmware before reading this thread. Any possibility to downgrade it to which support LibreDrive?pendell wrote: Sun Mar 05, 2023 6:22 pm Haha, unwittingly updated my brand new S13U-X to 1.04 before seeing this announcement, had to send it back in and get a replacement that was luckily still on 1.03. Will NOT be touching the firmware from now on lmao.
TeddyRaspin
You have to wait few weeks.
computerlove
Hope that it will be available soon.
computerlove
Waiting for your update on how to downgrade firmware of my Pioneer BDR-S13J-X from 1.04 to 1.03 owing to my oversight of the warning post on this forum.mike admin wrote: Thu Mar 16, 2023 4:06 pm Some status update. Unfortunately, this is taking much longer than expected. One think to note is that downgrade is possible on any version of firmware, and at the very least you would be able to downgrade, even a new drive that came with locked firmware.
I have a Pioneer BDR-212UBK and it was working awesome for ripping my UHD discs for almost a year. Unfortunately, just recently I stumbled into an issue with a couple of discs so I decided to "upgrade"
to firmware 1.04 and like this forum is discussing it disabled the ability to rip UHD. Really looking forward to any type of solution. I'm grateful that my drive still rips DVD and Blu-ray, but I can't wait to have the ability to rip UHD to be restored to my drive. Thanks to everyone that is working on this, and I hope that a fix will be created soon.
nokia768701
in 12 serials, it appears that all newly-released Pioneer firmwares contain updated kernel with downgrade protection.TiKiMaN1 wrote: Sat Apr 08, 2023 3:50 pm I have a Pioneer BDR-212UBK and it was working awesome for ripping my UHD discs for almost a year. Unfortunately, just recently I stumbled into an issue with a couple of discs so I decided to "upgrade"to firmware 1.04 and like this forum is discussing it disabled the ability to rip UHD. Really looking forward to any type of solution. I'm grateful that my drive still rips DVD and Blu-ray, but I can't wait to have the ability to rip UHD to be restored to my drive. Thanks to everyone that is working on this, and I hope that a fix will be created soon.
the developers of MakeMKV are working on the support of fw1.04.
please wait till new sdf release.
Hi! Sorry, but I am new to this party. I made the mistake and updated the Firmware of my BDR-XD07TUHD to the latest 1.05 and now lost LibreDrive thus unable to rip 4K BluRays. I still have a 1.03 firmware (the Windows executable) laying around and i tried changing the two appearances of "1.03' with "1.06" in a Hex Editor. But when I try to execute it, there is an Error thus it does not flash the old firm ware. What exactly has to be done (changed) in order to downgrade the firmware? Is there an alternative flashing tool that i could use?
no not available yet but its being worked onralphieg wrote: Thu Apr 13, 2023 7:16 am Hi! Sorry, but I am new to this party. I made the mistake and updated the Firmware of my BDR-XD07TUHD to the latest 1.05 and now lost LibreDrive thus unable to rip 4K BluRays. I still have a 1.03 firmware (the Windows executable) laying around and i tried changing the two appearances of "1.03' with "1.06" in a Hex Editor. But when I try to execute it, there is an Error thus it does not flash the old firm ware. What exactly has to be done (changed) in order to downgrade the firmware? Is there an alternative flashing tool that i could use?
computerlove
I have my Pioneer BDR-S13J-X firmware upgrade to 1.04 but have download firmware 1.03 elsewhere from internet. Can anybody advise whether it is possible for me to downgrade my drive firmware back to 1.03? Thanks!computerlove wrote: Sat Apr 08, 2023 2:15 pmWaiting for your update on how to downgrade firmware of my Pioneer BDR-S13J-X from 1.04 to 1.03 owing to my oversight of the warning post on this forum.mike admin wrote: Thu Mar 16, 2023 4:06 pm Some status update. Unfortunately, this is taking much longer than expected. One think to note is that downgrade is possible on any version of firmware, and at the very least you would be able to downgrade, even a new drive that came with locked firmware.
no not yetcomputerlove wrote: Sat Apr 15, 2023 3:35 am
For anyone scared off Amazon's BDR-X13U-S because of my earlier post, I can confirm it was a return. I ordered another last week (after returning the 1st because it was used -- all the rubber feet were already installed and the protective plastic cover on the front was missing), and got a unit manufactured in Nov 2022 (vs. Oct 2022) with firmware 1.01.outlier wrote: Thu Mar 16, 2023 7:39 am The BDR-X13U-S from Amazon seems to already be shipping with the latest 1.03 firmware (though I'm not entirely certain it was a virgin unit--the cables weren't bound with a wire and the plastic cover for the electric plug wasn't actually on the plug).
I suppose I can update the unit to 1.02 but a bit too afraid to do that at this point.
