Transformers Revenge Of The Fallen
nkhan
#1 Post by nkhan » Tue May 24, 2011 2:16 pm
Made a full MKV of the whole disc without making any changeds and the movie struggles to play and has no sound.
I am new to this, have i done something wrong.
Is it beneficial making a MKV of the whole disk or should i do just the movie file.
setarip_old
Re: Transformers Revenge Of The Fallen
#2 Post by setarip_old » Tue May 24, 2011 6:13 pm
Hi!
What are you using to playback your backup? (Standalone Blu-ray player, pc software, streaming, etc.)
nkhan
#3 Post by nkhan » Thu May 26, 2011 2:45 pm
I am using a WD Live media player to playback from a Netgear My Stora NAS.
richwill
#4 Post by richwill » Thu May 26, 2011 3:53 pm
The bit rate is really high on lots of action movies. I've found many devices just can't handle that amount of data sometimes. If you change the data stream from MPEG2 to h264, however it often works much better. It takes a long time to convert, but it seems to do the trick often times. Using Linux, transcode combined with the mkv tools, or Handbrake seem to work for the conversion just fine as well.
HTH
nkhan
#5 Post by nkhan » Thu May 26, 2011 4:04 pm
Not as simple as i thought it would be.
I thought i would be able to make a MKV file and just plug and play.
crowfax
#6 Post by crowfax » Thu May 26, 2011 4:08 pm
I have this movie and I also have a WD TV Live. It works fine when I play it back from an attached hard drive.
The problem is with your NAS or your network or both.
mfarlow
#7 Post by mfarlow » Fri Jun 10, 2011 1:33 pm
I guess you're all luckier than me. I'm getting a failed error on this BluRay.
When I get home, I'll grab the log file and post it.
