Hello @ RESET_9999!
I recently bought a sony x800m2 and I wanted to test if the player is playing FEL DV files correctly over network.
I tried looking at the files in your signature but the Power Rangers file is in MP4, which to my understanding, does not work over network.
Do you have any file that I can use to test this?
right, MP4 files don't work via the network. Did you try to remux it to TS?tjreis2 wrote: ↑Wed Apr 05, 2023 2:03 pmHello @ RESET_9999!
Hi @RESET_9999,
Thank you for your Dolby Vision scripts, these things are pretty sick mate.
I am trying to use them as there are some WEB-DLs of a Disney+ show my wife and I like to watch, however the releases for the show are in 4K HDR and 4K Dolby Vision exclusively, there isn't a hybrid release with both sets of metadata. After watching your tutorial vids (as they are slightly old and differ a bit from your current scripts), I assume the workflow I want to use is:
1) MODE.I= DoVi Convert/Edit/Sync/Inject two inputs (P8 Hybrid maker)
1) Workflow.1= Base Layer file + ST P5/P8/P7 DoVi file (can also mux and convert audio)
(Drag and drop the HDR release, then the DV release)
After this is where some options differ from your tutorial clip. I assume I should be choosing 'no' for L6 edit, then the next option I am confused on what to choose. Should I be using duplicate or remove for re-sync the RPU? On my own try I didn't choose either and it spit out an MKV with what looks like both HDR and DV metadata when inspecting with MediaInfo, however I haven't had a chance yet to try it on my TV.
Would you be able to just confirm what I should be choosing for the re-sync RPU prompt if I want to just make a hybrid WEB-DL from the same P2P group that released separate DV and HDR releases?
I did but the file didn't open. Weirdly enough, when I open the MP4 it does work and displays the credits in bright white instead of grey, but maybe it's something because of the Dolby Vision on toggle...
Taking screenshots
Sorry for this basic Q, what equipment or tools would be required to take DoVi/HDR screenshots: media/blu-ray player to TV ? not using a camera : ) & TV doesn't allow screenshots when in DoVi.
For PC based tools, I realize that one can use a ffmpeg or mpv,... I couldn't try mpv as it seems gpu-next is not supported or possible on macOS to properly decode DoVi (&P5). Does mpv/Win properly/adequately decode P5? Thank you.
yes (1-1) is the hybrid maker workflow and no need to resync nor edit L6/L5 if both versions comes from the same provider, they are most likely the same length (same frame order).chrisdm wrote: ↑Wed Apr 05, 2023 5:15 pmHi @RESET_9999,
The tutorials are indeed old, I will re-do them when I find some free time.
I also noticed that some files without audio won't work as well.
Anyway, I already tested everything, and the x800m2 support FEL(TS/M2TS) just fine via the network.
EDIT:
try this: https://drive.google.com/file/d/1IlfoXQ ... share_link
Yeah that would be sick. Would you be able to guide me as to which workflow is needed to mux if one is from a different provider? Haven't had that pop up yet but it might.RESET_9999 wrote: ↑Thu Apr 06, 2023 10:56 pmyes (1-1) is the hybrid maker workflow and no need to resync nor edit L6/L5 if both versions comes from the same provider, they are most likely the same length (same frame order).chrisdm wrote: ↑Wed Apr 05, 2023 5:15 pmHi @RESET_9999,
As well, any plans to make a version of your script compatible with linux? I would love to be able to do this all from my hosted server that runs linux rather than have to download from my home machine, mux the content, then upload to my server. Looking st the script I might be able to convert it to PowerShell so it can run on PowerShell core in linux, but not sure if all tools come in a linux cli version.
no sorry
it's the same workflow (1-1) but you have to resync the rpu to the new BL if needed.Yeah that would be sick. Would you be able to guide me as to which workflow is needed to mux if one is from a different provider? Haven't had that pop up yet but it might.
So 1-1, then duplicate?RESET_9999 wrote: ↑Fri Apr 07, 2023 10:38 pmno sorry
You'll need to find the difference between the two sources. Watch the DV version and find a camera cut. Then find the same cut on the HDR version. Compare the frame count of the two files and duplicate or remove the necessary amount of frames so the DV version matches the HDR version. For example, DV = 120865, HDR = 120895. You would duplicate 30 frames.
More reasons to collect physical media. 2019 Shield TV Pro.
How would I know whether to duplicate 30 or remove 30 from HDR? As in, (if this makes sense) what file is the duplicate/remove applied to?Gatorman wrote: ↑Fri Apr 07, 2023 11:12 pm
You're manipulating the RPU. So you need to remove or duplicate the DV source to match the HDR source.
That makes perfect sense, I'll give that a go should I need to! Thank you for the help mate, appreciate it. I'll try and automate this part instead of comparing both videos side by side to get the matching frame, I should be able to figure out how to do this programatically.
So much info in the thread, so what i gather is by converting a DV mkv with FEL to profile 8.1 we loose FEL?
So it’s the same a playing a DV MKV on a zidoo or dune? FEL is discarded and only the rpu is used?
