May Beta Key
MorningDawn75
May Beta Key
Post by MorningDawn75 » Thu Apr 06, 2023 11:10 pm
When will the key be updated for May? I can't wait until it is out of beta so I can buy it and not update the key monthly.
Re: May Beta Key
Post by Woodstock » Thu Apr 06, 2023 11:12 pm
You can buy it today (I bought it over 10 years ago) and get a permanent key.
Re: May Beta Key
Post by d00zah » Thu Apr 06, 2023 11:14 pm
Purchasing a key has always been an option...
https://www.makemkv.com/buy/
MorningDawn75
Re: May Beta Key
Post by MorningDawn75 » Fri Apr 07, 2023 12:50 pm
Thank you! I had not noticed that before. Order made.
Re: May Beta Key
Post by d00zah » Fri Apr 07, 2023 2:22 pm
When you access the MakeMKV 'Help' menu, that's the 'Purchase' option. When you get your key, copy/paste it via the 'Register' option.
dsb1126
Re: May Beta Key
Post by dsb1126 » Fri Apr 07, 2023 4:38 pm
Did you get a key yet? I ordered mine April 3rd but still don't have it and had no response to my inquiries.
Konten
Re: May Beta Key
Post by Konten » Fri Apr 07, 2023 6:04 pm
Go here:
https://payproglobal.com/customer-support
They should be able to help you out.
dsb1126
Re: May Beta Key
Post by dsb1126 » Fri Apr 07, 2023 7:53 pm
Go here:
Thanks. Just contacted them. Hopefully will hear from them soon.
dsb1126
Re: May Beta Key
Post by dsb1126 » Fri Apr 07, 2023 8:06 pm
Go here:
They were very quick to send the key. Thanks again!
Re: May Beta Key
Post by mike admin » Fri Apr 07, 2023 10:14 pm
Updated...
Konten
Re: May Beta Key
Post by Konten » Sat Apr 08, 2023 7:22 am
Go here:
Glad to hear it! :-)
