May Beta Key
May Beta Key
When will the key be updated for May? I can't wait until it is out of beta so I can buy it and not update the key monthly.
Re: May Beta Key
You can buy it today (I bought it over 10 years ago) and get a permanent key.
Re: May Beta Key
Purchasing a key has always been an option...MorningDawn75 wrote: ↑Thu Apr 06, 2023 11:10 pmWhen will the key be updated for May? I can't wait until it is out of beta so I can buy it and not update the key monthly.
https://www.makemkv.com/buy/
Re: May Beta Key
Thank you! I had not noticed that before. Order made.
Re: May Beta Key
When you access the MakeMKV 'Help' menu, that's the 'Purchase' option. When you get your key, copy/paste it via the 'Register' option.MorningDawn75 wrote: ↑Fri Apr 07, 2023 12:50 pmThank you! I had not noticed that before. Order made.
Re: May Beta Key
Did you get a key yet? I ordered mine April 3rd but still don't have it and had no response to my inquiries.MorningDawn75 wrote: ↑Fri Apr 07, 2023 12:50 pmThank you! I had not noticed that before. Order made.
Re: May Beta Key
Go here:dsb1126 wrote: ↑Fri Apr 07, 2023 4:38 pmDid you get a key yet? I ordered mine April 3rd but still don't have it and had no response to my inquiries.MorningDawn75 wrote: ↑Fri Apr 07, 2023 12:50 pmThank you! I had not noticed that before. Order made.
https://payproglobal.com/customer-support
They should be able to help you out.
Re: May Beta Key
Thanks. Just contacted them. Hopefully will hear from them soon.Konten wrote: ↑Fri Apr 07, 2023 6:04 pmGo here:dsb1126 wrote: ↑Fri Apr 07, 2023 4:38 pmDid you get a key yet? I ordered mine April 3rd but still don't have it and had no response to my inquiries.MorningDawn75 wrote: ↑Fri Apr 07, 2023 12:50 pmThank you! I had not noticed that before. Order made.
Re: May Beta Key
They were very quick to send the key. Thanks again!Konten wrote: ↑Fri Apr 07, 2023 6:04 pmGo here:dsb1126 wrote: ↑Fri Apr 07, 2023 4:38 pmDid you get a key yet? I ordered mine April 3rd but still don't have it and had no response to my inquiries.MorningDawn75 wrote: ↑Fri Apr 07, 2023 12:50 pmThank you! I had not noticed that before. Order made.
- Contact:
Re: May Beta Key
Updated...
Re: May Beta Key
Glad to hear it!dsb1126 wrote: ↑Fri Apr 07, 2023 8:06 pmThey were very quick to send the key. Thanks again!Konten wrote: ↑Fri Apr 07, 2023 6:04 pmGo here:
