May Beta Key
MorningDawn75
May Beta Key
Post by MorningDawn75 »
When will the key be updated for May? I can't wait until it is out of beta so I can buy it and not update the key monthly.
Re: May Beta Key
You can buy it today (I bought it over 10 years ago) and get a permanent key.
Re: May Beta Key
Post by d00zah »
MorningDawn75 wrote:
Thu Apr 06, 2023 11:10 pm
Purchasing a key has always been an option...
https://www.makemkv.com/buy/
MorningDawn75
Re: May Beta Key
Thank you! I had not noticed that before. Order made.
Re: May Beta Key
Post by d00zah »
Fri Apr 07, 2023 12:50 pm
When you access the MakeMKV 'Help' menu, that's the 'Purchase' option. When you get your key, copy/paste it via the 'Register' option.
dsb1126
Re: May Beta Key
Post by dsb1126 »
Did you get a key yet? I ordered mine April 3rd but still don't have it and had no response to my inquiries.
Konten
Re: May Beta Key
Post by Konten »
dsb1126 wrote:
Fri Apr 07, 2023 4:38 pm
Go here:
https://payproglobal.com/customer-support
They should be able to help you out.
dsb1126
Re: May Beta Key
Post by dsb1126 »
Konten wrote:
Fri Apr 07, 2023 6:04 pm
Go here:
Thanks. Just contacted them. Hopefully will hear from them soon.
dsb1126
Re: May Beta Key
Post by dsb1126 »
Go here:
They were very quick to send the key. Thanks again!
Re: May Beta Key
Post by mike admin »
Updated...
Konten
Re: May Beta Key
Post by Konten »
dsb1126 wrote:
Fri Apr 07, 2023 8:06 pm
Go here:
Glad to hear it! :-)
