Re: Flashing LG WH16NS40 back to original 1.03 firmware
jt5298 wrote: Thu Apr 06, 2023 7:36 pm Yes it's possible
Thank you. Is there a download on this site of the 1.03 firmware I can use? If not, will the 1.03 firmware from the LG website work? or is it encrypted.
The 1.03 from LGs site will work
jt5298
Post by jt5298 »
Billycar11 wrote: Thu Apr 06, 2023 7:46 pm
Great, thanks!
jt5298
Post by jt5298 »
Okay, probably a dumb question, but if I use the firmware from LG's website, I am going to follow their directions to flash my drive back to 1.03 correct?
jt5298 wrote: Thu Apr 06, 2023 9:31 pm Okay, probably a dumb question, but if I use the firmware from LG's website, I am going to follow their directions to flash my drive back to 1.03 correct?
You would need to flash the drive to WH16NS40 1.02-MK first as the official LG flasher for the WH16NS40 won't find your drive until it is on WH16NS40 firmware. Also, just so you are aware, if you flash it back to stock WH16NS40 1.03 firmware, it will no longer be able to read UHD discs.
jt5298
Post by jt5298 »
MartyMcNuts wrote: Thu Apr 06, 2023 11:12 pm
Okay, just so I am clear, it is possible to flash from WH16NS60 1.00 which is what I have now, back to WH16NS40 1.02MK using the SDFtool Flasher. Then use LG 1.03 firmware from their site and directions to flash back to 1.03. Yes, I am aware that it will no longer read UHD discs.
Thanks.
jt5298 wrote: Thu Apr 06, 2023 11:40 pm
Thanks.
Correct. I'm not sure if there is a WH16NS40 1.02-MK. I think it might be DE_WH16NS40_1.02. Anyway, you must flash to WH16NS40 1.02 or 1.01 firmware before you are able to use the original LG flasher to upgrade to stock 1.03.
jt5298
Post by jt5298 »
MartyMcNuts wrote: Fri Apr 07, 2023 12:03 am
Thanks.
Correct.
Thank you.
jt5298
Post by jt5298 »
jt5298 wrote: Fri Apr 07, 2023 12:04 am
Thanks.
Correct.
Thank you.
I flashed the drive back to 1.02MK using the SDFtool Flasher. I downloaded the 1.03 exe file from LG site. When I extract the zip file. It only opens in H-L Data Storage program, which I believe is the old flasher tool. I can't seem to open the file in another application. I can't find the H-L program on my computer to delete it. LG website says the exe file will open and I need to click the red update button. I can't get to this step because it keeps opening in this other program. It shows the file location but I can't find it there to delete it.
Post by d00zah »
The 1.03 exe file from LG IS the 'H-L program'. Vendor provided FW updates are an integrated package.
sdftool64.exe/SDFtool Flasher/discrete binaries should only be necessary when applying something other than a vendor provided FW.
jt5298
Post by jt5298 »
d00zah wrote: Fri Apr 07, 2023 4:17 pm The 1.03 exe file from LG IS the 'H-L program'. Vendor provided FW updates are an integrated package.
okay, thanks.
ILove3D
Help with LG BP50N40
Post by ILove3D »
Hi, I have an LG BP50NB40 SVC NB40, it has MT1959 and all the requirements. I flashed it to NB50 and then to BP60 but now the tray doesn't open. If I open it with a paper clip it doesn't read discs anymore, it doesn't even spin. MakeMKV recognizes the drive but not the discs. I restored the backup firmware and it's the same. I even used the official LG firmware installer and it's now on 1.03, MakeMKV says it has the original firmware again, but it still doesn't work. I just want it to work again, even if it doesn't support 4k Blurays, I just don't want to buy another one for my 3D blurays. Thanks in advance.
Captura de pantalla 2023-04-07 133125.png (105.9 KiB) Viewed 27342 times
NB 50+ on that one NB 40 it's bricked .
You can recover though with Marty's sdf gui and the nb40 fw
fenixreign
Post by fenixreign »
MartyMcNuts wrote: Sat Feb 04, 2023 8:07 pm
glc650 wrote: Sat Feb 04, 2023 2:45 pm I've been using an Asus BW-16D1HT drive (with 3.10 MK firmware) for a while now but I'm tired of dealing with the sleep bug so I want to switch firmware. Which firmware eliminates the sleep bug but also maintains AnyDVD compatibility?
WH16NS60 1.00 or 1.02-MK
I am also currently using the ASUS BW-16D1HT, and I was hoping for some confirmation before I follow the quoted advice (I am very cautious about crossflashing due to all of the warnings here and as a general "no-no" for most hardware).
Flashing to the WH16NS60 1.00 or 1.02-MK firmwares SHOULDN'T (I know there are no guarantees) brick my drive, correct?
Can I flash to the above firmwares then return to the proper ASUS 3.10-MK Firmware, with the expectation that the Sleep Bug will have been fixed and the drive should fully support UHD disc ripping?
fenixreign wrote: Sun Apr 09, 2023 11:31 pm
If you change back to ASUS 3.10-MK the sleep bug comes back with it.
fenixreign
MartyMcNuts wrote: Mon Apr 10, 2023 5:35 am
MartyMcNuts wrote: Sat Feb 04, 2023 8:07 pm WH16NS60 1.00 or 1.02-MK
Well, that’s just annoying (fix it already ASUS!). I assume that the info from the first post about how to fix the bug “permanently” doesn’t work if cross flashing or did I just read something wrong?
