The Maltese Falcon: 4K UHD
evbuk
#1 Post by evbuk » Sat Apr 01, 2023 11:55 am
Volume key unknown.
I have submitted the dump file to svq@makemkv.com this morning.
rkhollister
Re: The Maltese Falcon: 4K UHD
#2 Post by rkhollister » Wed Apr 05, 2023 12:22 am
Just tried the US disc and it is now working
evbuk
#3 Post by evbuk » Thu Apr 06, 2023 7:12 pm
Still not working for me.
I think there is a difference between the European release (which I have) and the US version.
htpc_rookie
#4 Post by htpc_rookie » Sat Apr 08, 2023 7:59 am
Just tried this disc with no success and submitted a dump file this morning,
MKB20_v77_The_Maltese_Falcon_B6E4.tgz
evbuk
#5 Post by evbuk » Sat Apr 08, 2023 4:09 pm
Working now for me.
Thanks all and whoever is in charge of updating the keys.
Elephen
#6 Post by Elephen » Wed Apr 26, 2023 5:32 pm
I received my copy of the U.S. version of The Maltese Falcon yesterday, but am having the same issue with the volume key. Are these volume keys unique to each member? I’ve only had the issue two or three times. By the way, I sent the dump file to the wrong address yesterday but to the correct address today. Thanks.
#7 Post by Woodstock » Wed Apr 26, 2023 5:55 pm
The volume keys are unique to a group of disks. Usually, that means they'll be the same across disks produced for a given country, but sometimes not.
Matching disks will come up with the same "hex digits" at the end of the file name, as in all of them created with "_ABCD" in the name will be the same, but "AEF3" will be different. That's why it's best if people post the name of the file being sent to svq@makemkv.com in their post here.
Elephen
#8 Post by Elephen » Wed Apr 26, 2023 7:08 pm
Thanks for your quick reply.
I just read the following post: viewtopic.php?f=12&t=24711
For your information, I received the first message, but not the second message, which is the reason I asked my question about volume keys. However, I do not understand what you mean by the "file name." I know the name of the film, but don't know where to look for the file name when I can't rip the disk and save the file. Are you referring to the name of the dump file? Thanks.
#9 Post by Woodstock » Wed Apr 26, 2023 7:25 pm
Yes, the name of the dump file. As in the example from that message:
Saved AACS dump file as C:\Users\xxxxxxxxx/.MakeMKV/New_UHD_Title_ABCD.tgz
The "_ABCD" is a checksum, calculated based on the file contents, so it changes when the encryption key changes. If you see where someone else has submitted the same checksum file as you have, there's less need to submit YOUR copy, but it doesn't HURT.
Seeing the second message is not usual... but it happens sometimes. It's when your system isn't getting the updates. A lot of people disable that for security reasons- automatic downloads are an issue for a lot of people. Trusting your antivirus programs is important.
TBill
#10 Post by TBill » Thu Apr 27, 2023 12:09 am
MakeMKV failed to load this U.S. disc. Just emailed the dump file:
MKB20_v77_The_Maltese_Falcon_B8FE.tgz
Bill
So, what are we watching tonight?
Elephen
#11 Post by Elephen » Thu Apr 27, 2023 1:00 am
Here's the missing link.
file:///Users/xxxxxxxx/Library/MakeMKV/MKB20_v77_The_Maltese_Falcon_B8FE.tgz
Elephen
#12 Post by Elephen » Fri Apr 28, 2023 1:14 pm
When I tried to rip the disk again today, I received the following familiar answer:
Saved AACS dump file as /Users/xxxxxxxx/Library/MakeMKV/MKB20_v77_The_Maltese_Falcon_B8FE.tgz
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:121264372
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:213131341
Usually, the volume-key problem is resolved within a couple of days. I am curious to learn why the problem still persists. Thanks.
TBill
#13 Post by TBill » Sun Apr 30, 2023 8:34 pm
Just tried again, and still unable to convert the disc.
(Sorry, too "new" to PM.)
Bill
