TV shows and episodes
cazzie98
Post by cazzie98 »
Does anyone have some best practices and tops for doing TV show and episodes?
Re: TV shows and episodes
In what way? Directories to use, naming conventions, ???
A lot depends on what you're using for a server and how you intend to watch things. Also, how many episodes are involved... Like Bleach has 360+ episodes spread out over years.
Lord_EDOX
Post by Lord_EDOX »
I only know about KODI which uses "S01E01 - The Venture Bros.mkv" as an example and if you want you can put it in a season folder for your convivence. You can also do "S00E01 - Letterkenny.mkv" for specials etc. I don't rip DVD/Blueray extras at all so I have no idea how you deal with those.
I am guessing other players like Plex may have a different format, but KODI has a great WIKI for any formatting of files you need, and I think you can also look at the site that does the scraping. It is easy to find if you search for KODI Scrapers.
cazzie98
Post by cazzie98 »
I have a PLEX server is there a specific naming convention?
Mirarora
Post by Mirarora »
cazzie98 wrote: Fri Apr 07, 2023 1:41 pm I have a PLEX server is there a specific naming convention?
for plex i use for name of show S01E01 and have never had a problem
jellyfin on the other hand doesn't like that format for some reason so it can't find any of my shows
Plex: Naming and Organizing Your TV Show Files
Plex: Naming and organizing your Movie files
There's a lot of capability and subtly in the naming conventions Plex and others use.
